Date/Time: Fri, 07 Feb 2025 14:19:54 +0000
Rithmic Conniction Question
View Count: 590
[2020-06-03 13:46:25] |
User433487 - Posts: 7 |
Hello Support, I know this may sound like a broken record but I just wanted your opinion on this subject, I applied your fix ( with the .zip file into the \Rim folder and the DTC bridge files and all) and still get connection errors, I will include the message log for your analysis if you so need , I'm also one of them people who are forced to use Rithmic with my funding / evaluating firm and my question to you is for a fee the company offers an extra session with rithmic along side RTrader Pro, if I order this extra session will I be able to connect to the server or will I still have the same problem ? Regards Hishaam |
[2020-06-03 18:07:27] |
We do not see the Message Log. for a fee the company offers an extra session with rithmic along side RTrader Pro, if I order this extra session will I be able to connect to the server or will I still have the same problem ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
