Date/Time: Fri, 07 Feb 2025 13:56:06 +0000
SP Data
View Count: 715
[2020-06-03 12:34:08]
John Ara - Posts: 125
I'm having problem downloading SP numbers bars data. When I change symbol to SP from any other symbol, numbers bars do not show up. Please help, this is strange.
Thank you.
[2020-06-03 17:31:04]
Provide an image of the chart or Trade DOM, by following these instructions:
[2020-06-03 23:00:14]
http://www.sierrachart.com/image.php?Image=1591224953808.png
[2020-06-03 23:13:41]
Are you not aware that symbol essentially does not trade? We should just remove it. You need to use ES instead.
SP is a scarcely traded symbol, so you will not see much information from the Numbers Bars. What you may see initially is just a bunch of dots. You need to work on the scaling to ensure that you are getting in close enough to actually see the values.
Refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
Date Time Of Last Edit: 2020-06-04 07:37:38
