Date/Time: Fri, 07 Feb 2025 11:51:09 +0000
cqg data problem
View Count: 596
[2020-06-03 12:04:18]
lagjan - Posts: 5
From ninjabrokerage i have a second CQG login for sierra. They tell me that on their side everything is set op correctly. yes a can login to the data feed but i dont have live data.
I ahave send them superiors email about this link,,,CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges
""You will also see Symbol is Unknown displayed on the chart for 30 seconds when a Symbol is not authorized on your CQG trading account"""
I am very disappointed given the problem and people refer to each other,,,, can you help me please check the atteched file
imagedata0001.png / V - Attached On 2020-06-03 12:03:55 UTC - Size: 43.82 KB - 239 views
[2020-06-03 15:14:12]
lagjan - Posts: 5
Problem is solved
[2020-06-03 16:44:08]
Reviewed.
