Date/Time: Fri, 07 Feb 2025 11:37:42 +0000
Historical Data Download Error
View Count: 512
[2020-06-03 11:03:34] |
User332203 - Posts: 20 |
My Daily charts are not updating with candles correctly. I am getting a download error from Barchart. It says Blank response from Barchart. The symbol is SPY.
2020-06-03_06-44-05.jpg / V - Attached On 2020-06-03 11:03:19 UTC - Size: 23.05 KB - 204 views |
[2020-06-03 11:05:17] |
Refer to: RESOLVED: Known Current Historical Daily Data Download Failure Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
