Date/Time: Fri, 07 Feb 2025 16:45:42 +0000
Request to Activate Real Time Data Feed Connection
View Count: 585
[2020-06-03 08:32:01] |
User281225 - Posts: 2 |
Hi there, I have subscribed and activated for the Real Time Data Feed Connection for HK Futures. However, it's not showing on my chart. Please kindly assist in activating it. Regards, Richard Date Time Of Last Edit: 2020-06-04 07:35:21
[2020-06-04 07:35:08] |
We apologize for the delay. It is already active on your account. Restart Sierra Chart according to the instructions here: Sierra Chart - Software Login Instructions: Forced Login And make sure you are using the correct Hong Kong futures symbols in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-05 03:55:05] |
ok thank you. Furthermore, i would like to know how to set up Overnight high low and standard deviation for a symbol on the chart |
[2020-06-08 02:58:09] |
Refer to these studies: High/Low for Time Period - Extended Standard Deviation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
