Date/Time: Fri, 07 Feb 2025 13:56:43 +0000
Different commissions for different symbols
View Count: 865
[2020-06-03 07:07:52] |
User957252 - Posts: 5 |
I am having trouble with setting different commissions values for different symbols... For e.g. I want to set round turn commisions to 2.84 for FDAX and 3.70 for NQ. However, when I change the 'Use Global Round Turn Commission' value for one symbol it automatically propagates to the other. How can I prevent this from happening and have different values for each symbol. Thanks in advance for your help |
[2020-06-04 11:39:54] |
You need to set this per individual symbol. Not using the global setting. Refer to: Global Symbol Settings: Use Global Round Turn Commission (Global Settings >> Symbol Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 11:40:38
