Date/Time: Fri, 07 Feb 2025 12:00:16 +0000
Problem with Barchart's data
View Count: 582
[2020-06-03 05:45:32] |
ticinotrader - Posts: 401 |
Dear Support, When trying to open historical charts for any markets, I receive the following error message on the chart: Download Failed Error downloading historical Daily data for XY. ERROR: Blank response from Barchart This message appears for all markets. I'm subscribed to many exchanges realtime data through Barchart and Denali. No matter what exchange (or datafeed) I try to display a historical for, the same error message pops up mentioning Barchart The same happens when trying without realtime access as well - the exact same error message appears. I'm using v2113 and 2115. Can you please advise? thank you. |
[2020-06-03 15:31:13] |
John - SC Support - Posts: 37808 |
Refer to the information here: RESOLVED: Known Current Historical Daily Data Download Failure Issue For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
