Date/Time: Fri, 07 Feb 2025 12:09:16 +0000
Historical Stock Data
View Count: 493
[2020-06-03 05:18:10] |
wingz - Posts: 121 |
What is the problem with the historical stock data? Every time I put a stock symbol on a chart, I get a red box with a message that says "Download Failed, Error from Barchart".
[2020-06-03 07:27:04] |
We are aware of the issue. We are working on this. It is due to an external provider problem.
