Date/Time: Fri, 07 Feb 2025 14:04:58 +0000
real-time data $VVIX
View Count: 931
[2020-06-03 02:45:42] |
Bedhog - Posts: 179 |
Hello Team, I'm using the Denali data feed and it's awesome. There are no references to enable realtime data for the $VVIX CBOE Indices on this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed I also do not see VIX(anything) as a selection from my broker in the Available Symbols list. Is having realtime data for $VVIX possible when using Denali? If no, is there an alternate symbol that follows VIX? Thank you. Date Time Of Last Edit: 2020-06-04 07:22:22
[2020-06-04 07:22:18] |
$VVIX is in the CBOE Indices exchange, which is available through the Sierra Chart Exchange Data Feed. You can use both the Sierra Chart Exchange Data Feed and the Denali Exchange Data Feed at the same time. In any month where you are using both, you will receive a $12.00 USD credit to your account. Refer to the information on the following page, and note the Setup Instructions on that page as well if you wish to subscribe to that data: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
