Date/Time: Fri, 07 Feb 2025 14:01:51 +0000
Trade Simulation ON
View Count: 562
[2020-06-03 01:57:14] |
User181709 - Posts: 1 |
When I use trade Simulation Mode ON, I can not use simbple bracket orders or use buy limit ordes the order automatically flat. I use versiĆ³n 2115 64 bits, When I trade live it's work well. What can I do? |
[2020-06-04 07:09:36] |
Check the Trade Activity Log and see why it is the Position goes flat: Trade Activity Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
