Date/Time: Fri, 07 Feb 2025 12:19:32 +0000
Bar Based and Replay Fills Outside Candles.
View Count: 563
[2020-06-03 01:42:17] |
User950841 - Posts: 6 |
http://www.sierrachart.com/image.php?Image=159114816836.png Real time fills are perfect but I just can't get accurate backtests. |
[2020-06-03 03:19:45] |
This might be an issue with the particular version you are running. Could also be a CQG data issue. Update to the current version of Sierra Chart by following these instructions: Software Download: Fast Update And then re-download the data in the chart: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Part of the complexity of this, is support for replaying historical market depth data which creates complications with the best bid and ask prices. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-03 03:20:10
