Date/Time: Fri, 07 Feb 2025 11:38:27 +0000
Is It possible to have 2 different data feeds with one instance of Sierra
View Count: 514
[2020-06-02 23:49:22] |
User434251 - Posts: 15 |
I am trading crypto with BitMex and want to also have a futures account with AMP/CQG - is it possible to have both loaded and switch back and forth? For example if I wanted to trade using BitMex from 12 -6 and then use AMP from 8-10, is that possible? Thanks! |
[2020-06-02 23:52:58] |
I found the following link: Using Multiple Data and Trading Services at the Same Time - I think it answers my question. Thanks! |
[2020-06-03 00:24:26] |
Yes that is the relevant documentation. You will need two installations of Sierra Chart.
