Date/Time: Fri, 07 Feb 2025 12:09:17 +0000
problom conectin to live account
View Count: 485
[2020-06-02 20:03:21] |
User103765 - Posts: 1 |
hwy guys i have a problem conecting to mi live acount , i get this message
Untitled.png / V - Attached On 2020-06-02 20:02:34 UTC - Size: 644.37 KB - 195 views Attachment Deleted. |
[2020-06-02 22:24:25] |
This is a Rithmic connection problem. Refer to this thread here about this: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward You need the updated files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
