Date/Time: Fri, 07 Feb 2025 13:21:13 +0000
Conexion con Rithmic Trading
View Count: 529
[2020-06-02 16:45:20] |
Monteclaro - Posts: 1 |
Estoy intentando conectarme a Rithmic Trading desde ayer. Siempre me aparece el mismo mensaje que adjunto. Gracias |
[2020-06-02 17:44:11] |
Refer to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
