Date/Time: Fri, 07 Feb 2025 12:52:34 +0000
unable to connect to the server
View Count: 565
[2020-06-02 16:43:07]
User815301 - Posts: 2
Reading Internal Order ID file. | 2020-06-02 09:45:46.586
Reading Trade Orders file. | 2020-06-02 09:45:46.662
Reading Trade Positions file. | 2020-06-02 09:45:46.664
Reading Account Balance file. | 2020-06-02 09:45:46.667
UDPListener (1412). Port 22904 | Listening on UDP port 22904. | 2020-06-02 09:45:46.688
Software version: 2017 64-bit | 2020-06-02 09:45:46.690
Usage end date: 2020-06-23 | 2020-06-02 09:45:46.690
Enabled for: Sierra Chart Historical Data Service. | 2020-06-02 09:45:46.690
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-02 09:45:46.690
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-02 09:45:46.690
Current selected Data/Trading service: Rithmic Trading | 2020-06-02 09:45:46.690
Custom symbol settings values: enabled | 2020-06-02 09:45:46.690
Chart Update Interval: 500 | 2020-06-02 09:45:46.690
Intraday Data Storage Time Unit: 0 | 2020-06-02 09:45:46.690
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-06-02 09:45:46.690
2020-06-02 09:45:46 Local computer time | 2020-06-02 09:45:46.690
2020-06-02 13:45:46 Local computer time in UTC | 2020-06-02 09:45:46.690
2020-06-02 09:45:46 Local computer time in SC Time Zone | 2020-06-02 09:45:46.690
2020-06-02 13:45:45 Server time in UTC | 2020-06-02 09:45:46.690
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-06-02 09:45:46.690
Program path: C:\SierraChart\ | 2020-06-02 09:45:46.690
Data Files path: C:\SierraChart\Data\ | 2020-06-02 09:45:46.690
OS Version Number: 10.0 | 2020-06-02 09:45:46.690
Locale Setting: C | 2020-06-02 09:45:46.690
DLLs: UserContributedStudies_64.dll | 2020-06-02 09:45:46.690
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-06-02 09:45:46.711
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:45:46.730
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-02 09:45:46.863
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-02 09:45:46.863
Received 5 login tokens. | 2020-06-02 09:45:47.186
Symbol settings MD5 received. Request ID: 1. | 2020-06-02 09:45:47.471
Symbol settings are up-to-date for rithmic.trading. | 2020-06-02 09:45:47.471
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-06-02 09:45:50.349
Rithmic Trading | Port for executable: 56752 | 2020-06-02 09:45:52.364
Listening socket (1276). Port 56752 | Closed. | 2020-06-02 09:45:52.364
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:45:52.364
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56752. Current folder: C:\SierraChart\Rim | 2020-06-02 09:45:52.385
Rithmic Trading | Bridge process is running. | 2020-06-02 09:45:54.408
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56752 | 2020-06-02 09:45:54.408
DTC Client socket (1) | Creating socket. | 2020-06-02 09:45:54.408
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:45:54.408
Rithmic Trading | Connected to server. | 2020-06-02 09:45:54.409
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:45:54.409
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:45:54.410
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:45:54.411
Rithmic Trading | Sending logon request message. | 2020-06-02 09:45:54.411
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:45:54.413
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:45:54.414
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:45:54.414
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:45:54.729
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:45:54.877
Rithmic Trading | Received logon response. | 2020-06-02 09:45:54.877
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:45:54.877
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:45:54.877
Rithmic Trading | Logon error received from server | 2020-06-02 09:45:54.877
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:45:54.877
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:45:54.877
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:45:54.892
Rithmic Trading | Disconnected. | 2020-06-02 09:45:54.892
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:45:54.892
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:45:54.892
Rithmic Trading | Port for executable: 56765 | 2020-06-02 09:45:56.900
Listening socket (1440). Port 56765 | Closed. | 2020-06-02 09:45:56.900
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:45:56.902
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56765. Current folder: C:\SierraChart\Rim | 2020-06-02 09:45:57.218
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 09:45:57.475 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:45:57.475
DTC Client socket (1) | Closed. | 2020-06-02 09:45:57.475
ZBU0-CBOT 5 Min #6 | Reloading chart. | 2020-06-02 09:45:58.697
6EM0-CME 5 Min #1 | Reloading chart. | 2020-06-02 09:45:58.840
MGCQ0-COMEX 5 Min #3 | Reloading chart. | 2020-06-02 09:45:58.945
MESM0-CME 5 Min #5 | Reloading chart. | 2020-06-02 09:45:59.072
QMN0-NYMEX 5 Min #8 | Reloading chart. | 2020-06-02 09:45:59.172
ESM0-CME 5 Min #12 | Reloading chart. | 2020-06-02 09:45:59.377
NGN0-NYMEX 5 Min #13 | Reloading chart. | 2020-06-02 09:45:59.451
ZSN0-CBOT 5 Min #2 | Reloading chart. | 2020-06-02 09:45:59.654
6JM0-CME 5 Min #4 | Reloading chart. | 2020-06-02 09:45:59.817
GCQ0-COMEX 1.2 Range #7 | Reloading chart. | 2020-06-02 09:45:59.951
ESM0-CME 3.00 Range #9 | Reloading chart. | 2020-06-02 09:46:00.074
CLN0-NYMEX 0.12 Range #10 | Reloading chart. | 2020-06-02 09:46:00.227
CLN0-NYMEX 5 Min #11 | Reloading chart. | 2020-06-02 09:46:00.442
GCQ0-COMEX 5 Min #14 | Reloading chart. | 2020-06-02 09:46:00.577
CLN0-NYMEX 5 Min #15 | Reloading chart. | 2020-06-02 09:46:00.632
MGCQ0-COMEX 5 Min #3 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:00.694
QMN0-NYMEX 5 Min #8 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:00.706
6EM0-CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:00:00 | 2020-06-02 09:46:00.712
NGN0-NYMEX 5 Min #13 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:00:00 | 2020-06-02 09:46:00.726
ZSN0-CBOT 5 Min #2 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:00.734
6JM0-CME 5 Min #4 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:00:00 | 2020-06-02 09:46:00.741
GCQ0-COMEX 1.2 Range #7 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:00.746
GCQ0-COMEX 5 Min #14 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:00.787
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZBU0-CBOT | 2020-06-02 09:46:00.838
Starting DelayedDownloadMonitoringTimer | 2020-06-02 09:46:00.838
Starting HDTimeoutTimer | 2020-06-02 09:46:00.838
Added historical Intraday data request for ZBU0-CBOT to the queue. | 2020-06-02 09:46:00.839
Intraday data recording state for symbol ZBU0-CBOT is set to download 'Pending'. | 2020-06-02 09:46:00.839
Triggering next historical data download in queue. | 2020-06-02 09:46:00.840
HD Request # 1 | Downloading Intraday chart data for ZBU0-CBOT to the file ZBU0-CBOT.scid. Service: cbot | 2020-06-02 09:46:00.843
HD Request # 1 | Download start date-time: 2020-06-01 21:16:27.000 | 2020-06-02 09:46:00.844
HD Request # 1 | Using server: ds23.sierracharts.com port 10150 | 2020-06-02 09:46:00.844
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:46:00.850
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56765 | 2020-06-02 09:46:00.850
DTC Client socket (2) | Creating socket. | 2020-06-02 09:46:00.850
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:00.850
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6EM0-CME | 2020-06-02 09:46:00.859
Added historical Intraday data request for 6EM0-CME to the queue. | 2020-06-02 09:46:00.859
Intraday data recording state for symbol 6EM0-CME is set to download 'Pending'. | 2020-06-02 09:46:00.859
Triggering next historical data download in queue. | 2020-06-02 09:46:00.862
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: MGCQ0-COMEX | 2020-06-02 09:46:00.867
Added historical Intraday data request for MGCQ0-COMEX to the queue. | 2020-06-02 09:46:00.867
Intraday data recording state for symbol MGCQ0-COMEX is set to download 'Pending'. | 2020-06-02 09:46:00.867
Triggering next historical data download in queue. | 2020-06-02 09:46:00.867
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: MESM0-CME | 2020-06-02 09:46:00.876
Added historical Intraday data request for MESM0-CME to the queue. | 2020-06-02 09:46:00.876
Intraday data recording state for symbol MESM0-CME is set to download 'Pending'. | 2020-06-02 09:46:00.876
Triggering next historical data download in queue. | 2020-06-02 09:46:00.876
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: QMN0-NYMEX | 2020-06-02 09:46:00.881
Added historical Intraday data request for QMN0-NYMEX to the queue. | 2020-06-02 09:46:00.882
Intraday data recording state for symbol QMN0-NYMEX is set to download 'Pending'. | 2020-06-02 09:46:00.882
Triggering next historical data download in queue. | 2020-06-02 09:46:00.882
Socket (1) | Creating socket. | 2020-06-02 09:46:00.882
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-02 09:46:00.882
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESM0-CME | 2020-06-02 09:46:00.886
Added historical Intraday data request for ESM0-CME to the queue. | 2020-06-02 09:46:00.887
Intraday data recording state for symbol ESM0-CME is set to download 'Pending'. | 2020-06-02 09:46:00.887
Triggering next historical data download in queue. | 2020-06-02 09:46:00.887
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGN0-NYMEX | 2020-06-02 09:46:00.894
Added historical Intraday data request for NGN0-NYMEX to the queue. | 2020-06-02 09:46:00.894
Intraday data recording state for symbol NGN0-NYMEX is set to download 'Pending'. | 2020-06-02 09:46:00.894
Triggering next historical data download in queue. | 2020-06-02 09:46:00.895
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZSN0-CBOT | 2020-06-02 09:46:00.904
Added historical Intraday data request for ZSN0-CBOT to the queue. | 2020-06-02 09:46:00.904
Intraday data recording state for symbol ZSN0-CBOT is set to download 'Pending'. | 2020-06-02 09:46:00.904
Triggering next historical data download in queue. | 2020-06-02 09:46:00.904
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6JM0-CME | 2020-06-02 09:46:00.912
Added historical Intraday data request for 6JM0-CME to the queue. | 2020-06-02 09:46:00.912
Intraday data recording state for symbol 6JM0-CME is set to download 'Pending'. | 2020-06-02 09:46:00.912
Triggering next historical data download in queue. | 2020-06-02 09:46:00.927
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCQ0-COMEX | 2020-06-02 09:46:00.938
Added historical Intraday data request for GCQ0-COMEX to the queue. | 2020-06-02 09:46:00.938
Intraday data recording state for symbol GCQ0-COMEX is set to download 'Pending'. | 2020-06-02 09:46:00.938
Triggering next historical data download in queue. | 2020-06-02 09:46:00.938
HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:00.951
HD Request # 1 | Sending historical data logon request message. | 2020-06-02 09:46:00.951
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLN0-NYMEX | 2020-06-02 09:46:00.954
Added historical Intraday data request for CLN0-NYMEX to the queue. | 2020-06-02 09:46:00.954
Intraday data recording state for symbol CLN0-NYMEX is set to download 'Pending'. | 2020-06-02 09:46:00.954
Triggering next historical data download in queue. | 2020-06-02 09:46:00.961
HD Request # 1 | Requesting Intraday data. Start date-time: 2020-06-01 21:16:27. Record interval: 0. Symbol: ZBU20 | 2020-06-02 09:46:01.415
HD Request # 1 | Decompressing data. | 2020-06-02 09:46:01.452
HD Request # 1 | Receiving Intraday data for ZBU0-CBOT starting at 2020-06-01 21:16:27 | 2020-06-02 09:46:01.543
HD Request # 1 | Timestamp of first Intraday data file record written: 2020-06-01 21:20:07 | 2020-06-02 09:46:01.544
HD Request # 1 | Historical data for ZBU0-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:01.603
Socket (1) | CloseSocket call. | 2020-06-02 09:46:01.603
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:01.603
Historical data download thread signaled to stop. | 2020-06-02 09:46:01.603
HD Request # 1 | Received 28742 records from 2020-06-01 21:16:27.000 to 2020-06-02 09:35:58.000 (12.3 hours) and wrote 28741 records for ZBU0-CBOT | 2020-06-02 09:46:01.604
HD Request # 1 | Completion time: 0s | 2020-06-02 09:46:01.604
HD Request # 1 | Intraday data download complete for ZBU0-CBOT. Unique request ID: 1 | 2020-06-02 09:46:01.604
Removing historical data download ID 1. | 2020-06-02 09:46:01.604
Rithmic Trading | Using primary service for historical data for ZBU0-CBOT | 2020-06-02 09:46:01.604
Starting DelayedDownloadMonitoringTimer | 2020-06-02 09:46:01.604
Starting HDTimeoutTimer | 2020-06-02 09:46:01.604
Historical data service client indicated that downloads are not enabled. Symbol: ZBU0-CBOT. Data Type: Intraday data | 2020-06-02 09:46:01.604
Historical data download ID 12 not found when removing ID from outstanding request set. | 2020-06-02 09:46:01.604
HD Request # 1 | Download from primary service not started due to error. | 2020-06-02 09:46:01.604
Triggering next historical data download in queue. | 2020-06-02 09:46:01.604
HD Request # 2 | Downloading Intraday chart data for 6EM0-CME to the file 6EM0-CME.scid. Service: cme | 2020-06-02 09:46:01.604
HD Request # 2 | Download start date-time: 2020-06-01 21:18:58.000 | 2020-06-02 09:46:01.604
HD Request # 2 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 09:46:01.605
Socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:01.629
Socket (1) | Closed. | 2020-06-02 09:46:01.629
Socket (3) | Creating socket. | 2020-06-02 09:46:01.639
Socket (3) | Connecting to IP: 216.1.90.129. | 2020-06-02 09:46:01.639
HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:01.703
HD Request # 2 | Sending historical data logon request message. | 2020-06-02 09:46:01.703
CLN0-NYMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:00:00 | 2020-06-02 09:46:01.797
CLN0-NYMEX 5 Min #15 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:00:00 | 2020-06-02 09:46:01.960
CLN0-NYMEX 0.12 Range #10 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:02.034
HD Request # 2 | Requesting Intraday data. Start date-time: 2020-06-01 21:18:58. Record interval: 0. Symbol: 6EM20 | 2020-06-02 09:46:02.166
HD Request # 2 | Decompressing data. | 2020-06-02 09:46:02.190
MESM0-CME 5 Min #5 | StartDateTimeForLoadingOrderFills: 2020-06-01 09:30:00 | 2020-06-02 09:46:02.196
HD Request # 2 | Receiving Intraday data for 6EM0-CME starting at 2020-06-01 21:18:58 | 2020-06-02 09:46:02.259
HD Request # 2 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:18 | 2020-06-02 09:46:02.259
HD Request # 2 | Historical data for 6EM0-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:02.403
Socket (3) | CloseSocket call. | 2020-06-02 09:46:02.403
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:02.403
Historical data download thread signaled to stop. | 2020-06-02 09:46:02.403
HD Request # 2 | Received 74623 records from 2020-06-01 21:18:58.000 to 2020-06-02 09:36:00.002 (12.3 hours) and wrote 74622 records for 6EM0-CME | 2020-06-02 09:46:02.404
HD Request # 2 | Completion time: 0s | 2020-06-02 09:46:02.404
HD Request # 2 | Intraday data download complete for 6EM0-CME. Unique request ID: 2 | 2020-06-02 09:46:02.404
Removing historical data download ID 2. | 2020-06-02 09:46:02.404
Rithmic Trading | Using primary service for historical data for 6EM0-CME | 2020-06-02 09:46:02.404
Historical data service client indicated that downloads are not enabled. Symbol: 6EM0-CME. Data Type: Intraday data | 2020-06-02 09:46:02.404
Historical data download ID 13 not found when removing ID from outstanding request set. | 2020-06-02 09:46:02.404
HD Request # 2 | Download from primary service not started due to error. | 2020-06-02 09:46:02.404
Triggering next historical data download in queue. | 2020-06-02 09:46:02.404
HD Request # 3 | Downloading Intraday chart data for MGCQ0-COMEX to the file MGCQ0-COMEX.scid. Service: comex | 2020-06-02 09:46:02.404
HD Request # 3 | Download start date-time: 2020-06-01 21:18:57.000 | 2020-06-02 09:46:02.404
HD Request # 3 | Using server: ds23.sierracharts.com port 10150 | 2020-06-02 09:46:02.404
Socket (1) | Creating socket. | 2020-06-02 09:46:02.404
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-02 09:46:02.404
Socket (3) | Socket gracefully closed by remote side. | 2020-06-02 09:46:02.433
Socket (3) | Closed. | 2020-06-02 09:46:02.433
HD Request # 3 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:02.470
HD Request # 3 | Sending historical data logon request message. | 2020-06-02 09:46:02.470
HD Request # 3 | Requesting Intraday data. Start date-time: 2020-06-01 21:18:57. Record interval: 0. Symbol: MGCQ20 | 2020-06-02 09:46:02.512
HD Request # 3 | Decompressing data. | 2020-06-02 09:46:02.543
HD Request # 3 | Receiving Intraday data for MGCQ0-COMEX starting at 2020-06-01 21:18:57 | 2020-06-02 09:46:02.613
HD Request # 3 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:11 | 2020-06-02 09:46:02.614
HD Request # 3 | Historical data for MGCQ0-COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:02.676
Socket (1) | CloseSocket call. | 2020-06-02 09:46:02.676
Historical data download thread signaled to stop. | 2020-06-02 09:46:02.676
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:02.676
HD Request # 3 | Received 17622 records from 2020-06-01 21:18:57.000 to 2020-06-02 09:36:00.000 (12.3 hours) and wrote 17621 records for MGCQ0-COMEX | 2020-06-02 09:46:02.676
HD Request # 3 | Completion time: 0s | 2020-06-02 09:46:02.676
HD Request # 3 | Intraday data download complete for MGCQ0-COMEX. Unique request ID: 3 | 2020-06-02 09:46:02.676
Removing historical data download ID 3. | 2020-06-02 09:46:02.676
Rithmic Trading | Using primary service for historical data for MGCQ0-COMEX | 2020-06-02 09:46:02.676
Historical data service client indicated that downloads are not enabled. Symbol: MGCQ0-COMEX. Data Type: Intraday data | 2020-06-02 09:46:02.676
Historical data download ID 14 not found when removing ID from outstanding request set. | 2020-06-02 09:46:02.676
HD Request # 3 | Download from primary service not started due to error. | 2020-06-02 09:46:02.676
Triggering next historical data download in queue. | 2020-06-02 09:46:02.676
HD Request # 4 | Downloading Intraday chart data for MESM0-CME to the file MESM0-CME.scid. Service: cme | 2020-06-02 09:46:02.676
HD Request # 4 | Download start date-time: 2020-06-01 21:19:10.000 | 2020-06-02 09:46:02.677
HD Request # 4 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 09:46:02.677
Socket (3) | Creating socket. | 2020-06-02 09:46:02.677
Socket (3) | Connecting to IP: 216.1.90.129. | 2020-06-02 09:46:02.677
Socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:02.700
Socket (1) | Closed. | 2020-06-02 09:46:02.700
HD Request # 4 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:02.757
HD Request # 4 | Sending historical data logon request message. | 2020-06-02 09:46:02.757
HD Request # 4 | Requesting Intraday data. Start date-time: 2020-06-01 21:19:10. Record interval: 0. Symbol: MESM20 | 2020-06-02 09:46:02.781
HD Request # 4 | Decompressing data. | 2020-06-02 09:46:02.809
HD Request # 4 | Receiving Intraday data for MESM0-CME starting at 2020-06-01 21:19:10 | 2020-06-02 09:46:02.885
HD Request # 4 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:13 | 2020-06-02 09:46:02.886
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:46:02.911 *
DTC Client socket (2) | CloseSocket call. | 2020-06-02 09:46:02.911
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:02.911
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:02.911
DTC Client socket (2) | Closed. | 2020-06-02 09:46:02.911
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:46:02.927
Rithmic Trading | Disconnected. | 2020-06-02 09:46:02.927
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:02.927
HD Request # 4 | Historical data for MESM0-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:03.089
Socket (3) | CloseSocket call. | 2020-06-02 09:46:03.090
Historical data download thread signaled to stop. | 2020-06-02 09:46:03.090
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:03.090
HD Request # 4 | Received 116897 records from 2020-06-01 21:19:10.000 to 2020-06-02 09:36:01.011 (12.3 hours) and wrote 116896 records for MESM0-CME | 2020-06-02 09:46:03.090
HD Request # 4 | Completion time: 0s | 2020-06-02 09:46:03.090
HD Request # 4 | Intraday data download complete for MESM0-CME. Unique request ID: 4 | 2020-06-02 09:46:03.090
Removing historical data download ID 4. | 2020-06-02 09:46:03.090
Rithmic Trading | Using primary service for historical data for MESM0-CME | 2020-06-02 09:46:03.090
Historical data service client indicated that downloads are not enabled. Symbol: MESM0-CME. Data Type: Intraday data | 2020-06-02 09:46:03.090
Historical data download ID 15 not found when removing ID from outstanding request set. | 2020-06-02 09:46:03.090
HD Request # 4 | Download from primary service not started due to error. | 2020-06-02 09:46:03.090
Triggering next historical data download in queue. | 2020-06-02 09:46:03.090
HD Request # 5 | Downloading Intraday chart data for QMN0-NYMEX to the file QMN0-NYMEX.scid. Service: nymex | 2020-06-02 09:46:03.090
HD Request # 5 | Download start date-time: 2020-06-01 21:18:15.000 | 2020-06-02 09:46:03.091
HD Request # 5 | Using server: ds23.sierracharts.com port 10150 | 2020-06-02 09:46:03.091
Socket (1) | Creating socket. | 2020-06-02 09:46:03.091
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-02 09:46:03.091
Socket (3) | Socket gracefully closed by remote side. | 2020-06-02 09:46:03.121
Socket (3) | Closed. | 2020-06-02 09:46:03.121
HD Request # 5 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:03.164
HD Request # 5 | Sending historical data logon request message. | 2020-06-02 09:46:03.164
HD Request # 5 | Requesting Intraday data. Start date-time: 2020-06-01 21:18:15. Record interval: 0. Symbol: QMN20 | 2020-06-02 09:46:03.202
HD Request # 5 | Decompressing data. | 2020-06-02 09:46:03.231
HD Request # 5 | Receiving Intraday data for QMN0-NYMEX starting at 2020-06-01 21:18:15 | 2020-06-02 09:46:03.324
HD Request # 5 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:18 | 2020-06-02 09:46:03.325
Socket (1) | CloseSocket call. | 2020-06-02 09:46:03.325
HD Request # 5 | Historical data for QMN0-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:03.325
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:03.325
Historical data download thread signaled to stop. | 2020-06-02 09:46:03.325
HD Request # 5 | Received 7032 records from 2020-06-01 21:18:15.000 to 2020-06-02 09:35:56.000 (12.3 hours) and wrote 7031 records for QMN0-NYMEX | 2020-06-02 09:46:03.326
HD Request # 5 | Completion time: 0s | 2020-06-02 09:46:03.326
HD Request # 5 | Intraday data download complete for QMN0-NYMEX. Unique request ID: 5 | 2020-06-02 09:46:03.326
Removing historical data download ID 5. | 2020-06-02 09:46:03.326
Rithmic Trading | Using primary service for historical data for QMN0-NYMEX | 2020-06-02 09:46:03.326
Historical data service client indicated that downloads are not enabled. Symbol: QMN0-NYMEX. Data Type: Intraday data | 2020-06-02 09:46:03.326
Historical data download ID 16 not found when removing ID from outstanding request set. | 2020-06-02 09:46:03.326
HD Request # 5 | Download from primary service not started due to error. | 2020-06-02 09:46:03.326
Triggering next historical data download in queue. | 2020-06-02 09:46:03.326
HD Request # 6 | Downloading Intraday chart data for ESM0-CME to the file ESM0-CME.scid. Service: cme | 2020-06-02 09:46:03.326
HD Request # 6 | Download start date-time: 2020-06-01 21:19:07.000 | 2020-06-02 09:46:03.326
HD Request # 6 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 09:46:03.326
Socket (2) | Creating socket. | 2020-06-02 09:46:03.326
Socket (2) | Connecting to IP: 216.1.90.129. | 2020-06-02 09:46:03.326
Socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:03.354
Socket (1) | Closed. | 2020-06-02 09:46:03.354
HD Request # 6 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:03.387
HD Request # 6 | Sending historical data logon request message. | 2020-06-02 09:46:03.387
HD Request # 6 | Requesting Intraday data. Start date-time: 2020-06-01 21:19:07. Record interval: 0. Symbol: ESM20 | 2020-06-02 09:46:03.413
HD Request # 6 | Decompressing data. | 2020-06-02 09:46:03.437
HD Request # 6 | Receiving Intraday data for ESM0-CME starting at 2020-06-01 21:19:07 | 2020-06-02 09:46:03.526
HD Request # 6 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:11 | 2020-06-02 09:46:03.526
HD Request # 6 | Historical data for ESM0-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:03.824
Socket (2) | CloseSocket call. | 2020-06-02 09:46:03.824
Historical data download thread signaled to stop. | 2020-06-02 09:46:03.824
Socket (2) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:03.824
HD Request # 6 | Received 208076 records from 2020-06-01 21:19:07.000 to 2020-06-02 09:36:01.069 (12.3 hours) and wrote 208075 records for ESM0-CME | 2020-06-02 09:46:03.825
HD Request # 6 | Completion time: 0s | 2020-06-02 09:46:03.825
HD Request # 6 | Intraday data download complete for ESM0-CME. Unique request ID: 6 | 2020-06-02 09:46:03.825
Removing historical data download ID 6. | 2020-06-02 09:46:03.825
Rithmic Trading | Using primary service for historical data for ESM0-CME | 2020-06-02 09:46:03.825
Historical data service client indicated that downloads are not enabled. Symbol: ESM0-CME. Data Type: Intraday data | 2020-06-02 09:46:03.825
Historical data download ID 17 not found when removing ID from outstanding request set. | 2020-06-02 09:46:03.825
HD Request # 6 | Download from primary service not started due to error. | 2020-06-02 09:46:03.825
Triggering next historical data download in queue. | 2020-06-02 09:46:03.826
HD Request # 7 | Downloading Intraday chart data for NGN0-NYMEX to the file NGN0-NYMEX.scid. Service: nymex | 2020-06-02 09:46:03.826
HD Request # 7 | Download start date-time: 2020-06-01 21:18:50.000 | 2020-06-02 09:46:03.826
HD Request # 7 | Using server: ds23.sierracharts.com port 10150 | 2020-06-02 09:46:03.826
Socket (1) | Creating socket. | 2020-06-02 09:46:03.826
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-02 09:46:03.826
Socket (2) | Socket gracefully closed by remote side. | 2020-06-02 09:46:03.851
Socket (2) | Closed. | 2020-06-02 09:46:03.851
HD Request # 7 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:03.901
HD Request # 7 | Sending historical data logon request message. | 2020-06-02 09:46:03.901
HD Request # 7 | Requesting Intraday data. Start date-time: 2020-06-01 21:18:50. Record interval: 0. Symbol: NGN20 | 2020-06-02 09:46:03.922
HD Request # 7 | Decompressing data. | 2020-06-02 09:46:03.958
HD Request # 7 | Receiving Intraday data for NGN0-NYMEX starting at 2020-06-01 21:18:50 | 2020-06-02 09:46:04.055
HD Request # 7 | Timestamp of first Intraday data file record written: 2020-06-01 21:20:10 | 2020-06-02 09:46:04.055
HD Request # 7 | Historical data for NGN0-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:04.116
Socket (1) | CloseSocket call. | 2020-06-02 09:46:04.116
Historical data download thread signaled to stop. | 2020-06-02 09:46:04.116
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:04.116
HD Request # 7 | Received 24926 records from 2020-06-01 21:18:50.000 to 2020-06-02 09:36:02.004 (12.3 hours) and wrote 24916 records for NGN0-NYMEX | 2020-06-02 09:46:04.117
HD Request # 7 | Completion time: 1s | 2020-06-02 09:46:04.117
HD Request # 7 | Intraday data download complete for NGN0-NYMEX. Unique request ID: 7 | 2020-06-02 09:46:04.117
Removing historical data download ID 7. | 2020-06-02 09:46:04.117
Rithmic Trading | Using primary service for historical data for NGN0-NYMEX | 2020-06-02 09:46:04.117
Historical data service client indicated that downloads are not enabled. Symbol: NGN0-NYMEX. Data Type: Intraday data | 2020-06-02 09:46:04.117
Historical data download ID 18 not found when removing ID from outstanding request set. | 2020-06-02 09:46:04.117
HD Request # 7 | Download from primary service not started due to error. | 2020-06-02 09:46:04.117
Triggering next historical data download in queue. | 2020-06-02 09:46:04.117
HD Request # 8 | Downloading Intraday chart data for ZSN0-CBOT to the file ZSN0-CBOT.scid. Service: cbot | 2020-06-02 09:46:04.117
HD Request # 8 | Download start date-time: 2020-06-01 21:18:58.000 | 2020-06-02 09:46:04.118
HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 09:46:04.118
Socket (2) | Creating socket. | 2020-06-02 09:46:04.118
Socket (2) | Connecting to IP: 216.1.90.129. | 2020-06-02 09:46:04.118
Socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:04.148
Socket (1) | Closed. | 2020-06-02 09:46:04.148
HD Request # 8 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:04.176
HD Request # 8 | Sending historical data logon request message. | 2020-06-02 09:46:04.176
HD Request # 8 | Requesting Intraday data. Start date-time: 2020-06-01 21:18:58. Record interval: 0. Symbol: ZSN20 | 2020-06-02 09:46:04.199
HD Request # 8 | Decompressing data. | 2020-06-02 09:46:04.263
HD Request # 8 | Receiving Intraday data for ZSN0-CBOT starting at 2020-06-01 21:18:58 | 2020-06-02 09:46:04.324
HD Request # 8 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:13 | 2020-06-02 09:46:04.325
HD Request # 8 | Historical data for ZSN0-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:04.326
Socket (2) | CloseSocket call. | 2020-06-02 09:46:04.326
Socket (2) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:04.326
Historical data download thread signaled to stop. | 2020-06-02 09:46:04.326
HD Request # 8 | Received 9658 records from 2020-06-01 21:18:58.000 to 2020-06-02 09:36:02.013 (12.3 hours) and wrote 9657 records for ZSN0-CBOT | 2020-06-02 09:46:04.326
HD Request # 8 | Completion time: 0s | 2020-06-02 09:46:04.326
HD Request # 8 | Intraday data download complete for ZSN0-CBOT. Unique request ID: 8 | 2020-06-02 09:46:04.326
Removing historical data download ID 8. | 2020-06-02 09:46:04.326
Rithmic Trading | Using primary service for historical data for ZSN0-CBOT | 2020-06-02 09:46:04.326
Historical data service client indicated that downloads are not enabled. Symbol: ZSN0-CBOT. Data Type: Intraday data | 2020-06-02 09:46:04.326
Historical data download ID 19 not found when removing ID from outstanding request set. | 2020-06-02 09:46:04.326
HD Request # 8 | Download from primary service not started due to error. | 2020-06-02 09:46:04.326
Triggering next historical data download in queue. | 2020-06-02 09:46:04.326
HD Request # 9 | Downloading Intraday chart data for 6JM0-CME to the file 6JM0-CME.scid. Service: cme | 2020-06-02 09:46:04.326
HD Request # 9 | Download start date-time: 2020-06-01 21:19:11.000 | 2020-06-02 09:46:04.327
HD Request # 9 | Using server: ds23.sierracharts.com port 10150 | 2020-06-02 09:46:04.327
Socket (1) | Creating socket. | 2020-06-02 09:46:04.327
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-02 09:46:04.327
Socket (2) | Socket gracefully closed by remote side. | 2020-06-02 09:46:04.359
Socket (2) | Closed. | 2020-06-02 09:46:04.359
HD Request # 9 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:04.396
HD Request # 9 | Sending historical data logon request message. | 2020-06-02 09:46:04.396
HD Request # 9 | Requesting Intraday data. Start date-time: 2020-06-01 21:19:11. Record interval: 0. Symbol: 6JM20 | 2020-06-02 09:46:04.418
HD Request # 9 | Decompressing data. | 2020-06-02 09:46:04.445
HD Request # 9 | Receiving Intraday data for 6JM0-CME starting at 2020-06-01 21:19:11 | 2020-06-02 09:46:04.545
HD Request # 9 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:21 | 2020-06-02 09:46:04.545
ESM0-CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2020-06-02 09:30:00 | 2020-06-02 09:46:04.569
HD Request # 9 | Historical data for 6JM0-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:04.639
Socket (1) | CloseSocket call. | 2020-06-02 09:46:04.639
Historical data download thread signaled to stop. | 2020-06-02 09:46:04.639
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:04.639
HD Request # 9 | Received 43070 records from 2020-06-01 21:19:11.000 to 2020-06-02 09:36:02.001 (12.3 hours) and wrote 43067 records for 6JM0-CME | 2020-06-02 09:46:04.639
HD Request # 9 | Completion time: 0s | 2020-06-02 09:46:04.639
HD Request # 9 | Intraday data download complete for 6JM0-CME. Unique request ID: 9 | 2020-06-02 09:46:04.639
Removing historical data download ID 9. | 2020-06-02 09:46:04.639
Rithmic Trading | Using primary service for historical data for 6JM0-CME | 2020-06-02 09:46:04.639
Historical data service client indicated that downloads are not enabled. Symbol: 6JM0-CME. Data Type: Intraday data | 2020-06-02 09:46:04.639
Historical data download ID 20 not found when removing ID from outstanding request set. | 2020-06-02 09:46:04.639
HD Request # 9 | Download from primary service not started due to error. | 2020-06-02 09:46:04.639
Triggering next historical data download in queue. | 2020-06-02 09:46:04.639
HD Request # 10 | Downloading Intraday chart data for GCQ0-COMEX to the file GCQ0-COMEX.scid. Service: comex | 2020-06-02 09:46:04.639
HD Request # 10 | Download start date-time: 2020-06-01 21:19:08.000 | 2020-06-02 09:46:04.640
HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2020-06-02 09:46:04.640
Socket (2) | Creating socket. | 2020-06-02 09:46:04.640
Socket (2) | Connecting to IP: 216.1.90.129. | 2020-06-02 09:46:04.640
Socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:04.671
Socket (1) | Closed. | 2020-06-02 09:46:04.671
HD Request # 10 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:04.712
HD Request # 10 | Sending historical data logon request message. | 2020-06-02 09:46:04.712
HD Request # 10 | Requesting Intraday data. Start date-time: 2020-06-01 21:19:08. Record interval: 0. Symbol: GCQ20 | 2020-06-02 09:46:04.788
HD Request # 10 | Decompressing data. | 2020-06-02 09:46:04.835
HD Request # 10 | Receiving Intraday data for GCQ0-COMEX starting at 2020-06-01 21:19:08 | 2020-06-02 09:46:04.900
HD Request # 10 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:12 | 2020-06-02 09:46:04.900
Rithmic Trading | Port for executable: 56785 | 2020-06-02 09:46:04.952
Listening socket (1616). Port 56785 | Closed. | 2020-06-02 09:46:04.952
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:04.953
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56785. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:04.961
HD Request # 10 | Historical data for GCQ0-COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:05.018
Socket (2) | CloseSocket call. | 2020-06-02 09:46:05.019
Historical data download thread signaled to stop. | 2020-06-02 09:46:05.019
Socket (2) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:05.019
HD Request # 10 | Received 55749 records from 2020-06-01 21:19:08.000 to 2020-06-02 09:36:03.005 (12.3 hours) and wrote 55748 records for GCQ0-COMEX | 2020-06-02 09:46:05.019
HD Request # 10 | Completion time: 0s | 2020-06-02 09:46:05.020
HD Request # 10 | Intraday data download complete for GCQ0-COMEX. Unique request ID: 10 | 2020-06-02 09:46:05.020
Removing historical data download ID 10. | 2020-06-02 09:46:05.020
Rithmic Trading | Using primary service for historical data for GCQ0-COMEX | 2020-06-02 09:46:05.020
Historical data service client indicated that downloads are not enabled. Symbol: GCQ0-COMEX. Data Type: Intraday data | 2020-06-02 09:46:05.020
Historical data download ID 21 not found when removing ID from outstanding request set. | 2020-06-02 09:46:05.020
HD Request # 10 | Download from primary service not started due to error. | 2020-06-02 09:46:05.020
Triggering next historical data download in queue. | 2020-06-02 09:46:05.020
HD Request # 11 | Downloading Intraday chart data for CLN0-NYMEX to the file CLN0-NYMEX.scid. Service: nymex | 2020-06-02 09:46:05.021
HD Request # 11 | Download start date-time: 2020-06-01 21:19:11.000 | 2020-06-02 09:46:05.021
HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2020-06-02 09:46:05.022
Socket (1) | Creating socket. | 2020-06-02 09:46:05.022
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-06-02 09:46:05.022
Socket (2) | Socket gracefully closed by remote side. | 2020-06-02 09:46:05.060
Socket (2) | Closed. | 2020-06-02 09:46:05.060
HD Request # 11 | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:05.100
HD Request # 11 | Sending historical data logon request message. | 2020-06-02 09:46:05.100
HD Request # 11 | Requesting Intraday data. Start date-time: 2020-06-01 21:19:11. Record interval: 0. Symbol: CLN20 | 2020-06-02 09:46:05.139
HD Request # 11 | Decompressing data. | 2020-06-02 09:46:05.165
HD Request # 11 | Receiving Intraday data for CLN0-NYMEX starting at 2020-06-01 21:19:11 | 2020-06-02 09:46:05.241
HD Request # 11 | Timestamp of first Intraday data file record written: 2020-06-01 21:19:12 | 2020-06-02 09:46:05.242
HD Request # 11 | Historical data for CLN0-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-06-02 09:46:05.419
Socket (1) | CloseSocket call. | 2020-06-02 09:46:05.419
Historical data download thread signaled to stop. | 2020-06-02 09:46:05.419
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:05.419
HD Request # 11 | Received 99253 records from 2020-06-01 21:19:11.000 to 2020-06-02 09:36:03.015 (12.3 hours) and wrote 99251 records for CLN0-NYMEX | 2020-06-02 09:46:05.419
HD Request # 11 | Completion time: 0s | 2020-06-02 09:46:05.420
HD Request # 11 | Intraday data download complete for CLN0-NYMEX. Unique request ID: 11 | 2020-06-02 09:46:05.420
Removing historical data download ID 11. | 2020-06-02 09:46:05.420
Rithmic Trading | Using primary service for historical data for CLN0-NYMEX | 2020-06-02 09:46:05.420
Historical data service client indicated that downloads are not enabled. Symbol: CLN0-NYMEX. Data Type: Intraday data | 2020-06-02 09:46:05.420
Historical data download ID 22 not found when removing ID from outstanding request set. | 2020-06-02 09:46:05.420
HD Request # 11 | Download from primary service not started due to error. | 2020-06-02 09:46:05.420
Triggering next historical data download in queue. | 2020-06-02 09:46:05.420
Socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:05.449
Socket (1) | Closed. | 2020-06-02 09:46:05.449
ESM0-CME 3.00 Range #9 | StartDateTimeForLoadingOrderFills: 2020-06-02 09:30:00 | 2020-06-02 09:46:06.358
Rithmic Trading | Bridge process is running. | 2020-06-02 09:46:06.944
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56785 | 2020-06-02 09:46:06.944
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:06.944
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:06.944
Rithmic Trading | Connected to server. | 2020-06-02 09:46:06.945
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:46:06.945
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:46:06.946
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:06.946
Rithmic Trading | Sending logon request message. | 2020-06-02 09:46:06.946
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:46:06.947
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:46:06.949
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:46:06.949
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:46:07.250
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:46:07.407
Rithmic Trading | Received logon response. | 2020-06-02 09:46:07.407
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:46:07.407
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:46:07.407
Rithmic Trading | Logon error received from server | 2020-06-02 09:46:07.407
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:07.407
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:07.407
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:07.420
Rithmic Trading | Disconnected. | 2020-06-02 09:46:07.420
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:07.420
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:07.421
Rithmic Trading | Port for executable: 56802 | 2020-06-02 09:46:09.412
Listening socket (1540). Port 56802 | Closed. | 2020-06-02 09:46:09.412
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:09.413
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56802. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:09.421
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:10.054
DTC Client socket (1) | Closed. | 2020-06-02 09:46:10.054
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:46:11.418
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56802 | 2020-06-02 09:46:11.418
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:11.418
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:11.418
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:46:13.457 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:13.457
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:13.457
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:13.457
DTC Client socket (1) | Closed. | 2020-06-02 09:46:13.457
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:46:13.473
Rithmic Trading | Disconnected. | 2020-06-02 09:46:13.473
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:13.473
Rithmic Trading | Port for executable: 56804 | 2020-06-02 09:46:15.494
Listening socket (1496). Port 56804 | Closed. | 2020-06-02 09:46:15.494
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:15.496
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56804. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:15.505
Rithmic Trading | Bridge process is running. | 2020-06-02 09:46:17.521
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56804 | 2020-06-02 09:46:17.521
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:17.521
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:17.521
Rithmic Trading | Connected to server. | 2020-06-02 09:46:17.522
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:46:17.522
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:46:17.522
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:17.523
Rithmic Trading | Sending logon request message. | 2020-06-02 09:46:17.523
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:46:17.524
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:46:17.525
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:46:17.525
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:46:17.808
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:46:17.941
Rithmic Trading | Received logon response. | 2020-06-02 09:46:17.941
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:46:17.941
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:46:17.941
Rithmic Trading | Logon error received from server | 2020-06-02 09:46:17.941
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:17.941
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:17.941
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:17.944
Rithmic Trading | Disconnected. | 2020-06-02 09:46:17.944
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:17.944
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:17.944
Rithmic Trading | Port for executable: 56828 | 2020-06-02 09:46:19.948
Listening socket (1496). Port 56828 | Closed. | 2020-06-02 09:46:19.948
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:19.948
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56828. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:19.961
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:20.590
DTC Client socket (1) | Closed. | 2020-06-02 09:46:20.590
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:46:21.940
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56828 | 2020-06-02 09:46:21.940
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:21.940
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:21.940
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:46:24.002 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:24.002
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:24.002
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:24.002
DTC Client socket (1) | Closed. | 2020-06-02 09:46:24.002
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:46:24.017
Rithmic Trading | Disconnected. | 2020-06-02 09:46:24.018
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:24.018
Rithmic Trading | Port for executable: 56839 | 2020-06-02 09:46:26.029
Listening socket (1448). Port 56839 | Closed. | 2020-06-02 09:46:26.029
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:26.031
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56839. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:26.040
Rithmic Trading | Bridge process is running. | 2020-06-02 09:46:28.042
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56839 | 2020-06-02 09:46:28.042
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:28.042
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:28.042
Rithmic Trading | Connected to server. | 2020-06-02 09:46:28.043
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:46:28.043
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:46:28.044
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:28.045
Rithmic Trading | Sending logon request message. | 2020-06-02 09:46:28.045
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:46:28.046
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:46:28.047
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:46:28.047
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:46:28.292
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:46:28.423
Rithmic Trading | Received logon response. | 2020-06-02 09:46:28.423
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:46:28.423
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:46:28.423
Rithmic Trading | Logon error received from server | 2020-06-02 09:46:28.423
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:28.423
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:28.423
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:28.438
Rithmic Trading | Disconnected. | 2020-06-02 09:46:28.438
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:28.438
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:28.438
Rithmic Trading | Port for executable: 56853 | 2020-06-02 09:46:30.447
Listening socket (1448). Port 56853 | Closed. | 2020-06-02 09:46:30.447
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:30.448
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56853. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:30.457
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:31.118
DTC Client socket (1) | Closed. | 2020-06-02 09:46:31.118
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:46:32.445
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56853 | 2020-06-02 09:46:32.445
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:32.445
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:32.446
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:46:34.482 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:34.482
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:34.482
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:34.482
DTC Client socket (1) | Closed. | 2020-06-02 09:46:34.482
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:46:34.498
Rithmic Trading | Disconnected. | 2020-06-02 09:46:34.498
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:34.498
Rithmic Trading | Port for executable: 56858 | 2020-06-02 09:46:36.509
Listening socket (1592). Port 56858 | Closed. | 2020-06-02 09:46:36.509
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:36.511
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56858. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:36.519
Rithmic Trading | Bridge process is running. | 2020-06-02 09:46:38.533
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56858 | 2020-06-02 09:46:38.533
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:38.533
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:38.533
Rithmic Trading | Connected to server. | 2020-06-02 09:46:38.534
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:46:38.534
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:46:38.535
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:38.536
Rithmic Trading | Sending logon request message. | 2020-06-02 09:46:38.536
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:46:38.537
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:46:38.538
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:46:38.538
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:46:38.792
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:46:38.947
Rithmic Trading | Received logon response. | 2020-06-02 09:46:38.947
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:46:38.947
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:46:38.947
Rithmic Trading | Logon error received from server | 2020-06-02 09:46:38.947
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:38.947
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:38.947
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:38.962
Rithmic Trading | Disconnected. | 2020-06-02 09:46:38.962
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:38.962
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:38.962
Rithmic Trading | Port for executable: 56872 | 2020-06-02 09:46:40.965
Listening socket (1592). Port 56872 | Closed. | 2020-06-02 09:46:40.965
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:40.966
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56872. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:40.975
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 09:46:41.594 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:41.594
DTC Client socket (1) | Closed. | 2020-06-02 09:46:41.594
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:46:42.996
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56872 | 2020-06-02 09:46:42.996
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:42.996
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:42.997
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:46:45.040 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:45.040
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:45.040
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:45.040
DTC Client socket (1) | Closed. | 2020-06-02 09:46:45.040
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:46:45.055
Rithmic Trading | Disconnected. | 2020-06-02 09:46:45.055
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:45.055
Rithmic Trading | Port for executable: 56876 | 2020-06-02 09:46:47.079
Listening socket (1676). Port 56876 | Closed. | 2020-06-02 09:46:47.079
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:47.080
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56876. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:47.089
Rithmic Trading | Bridge process is running. | 2020-06-02 09:46:49.077
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56876 | 2020-06-02 09:46:49.077
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:49.078
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:49.078
Rithmic Trading | Connected to server. | 2020-06-02 09:46:49.081
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:46:49.081
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:46:49.083
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:49.085
Rithmic Trading | Sending logon request message. | 2020-06-02 09:46:49.085
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:46:49.087
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:46:49.091
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:46:49.091
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:46:49.357
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:46:49.473
Rithmic Trading | Received logon response. | 2020-06-02 09:46:49.473
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:46:49.473
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:46:49.473
Rithmic Trading | Logon error received from server | 2020-06-02 09:46:49.473
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:49.473
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:49.473
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:49.489
Rithmic Trading | Disconnected. | 2020-06-02 09:46:49.489
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:49.489
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:46:49.489
Rithmic Trading | Port for executable: 56891 | 2020-06-02 09:46:51.511
Listening socket (1676). Port 56891 | Closed. | 2020-06-02 09:46:51.511
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:51.514
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56891. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:51.522
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:46:52.174
DTC Client socket (1) | Closed. | 2020-06-02 09:46:52.174
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:46:53.523
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56891 | 2020-06-02 09:46:53.523
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:53.523
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:53.523
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:46:55.555 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:46:55.555
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:46:55.555
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:55.555
DTC Client socket (1) | Closed. | 2020-06-02 09:46:55.555
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:46:55.570
Rithmic Trading | Disconnected. | 2020-06-02 09:46:55.570
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:46:55.570
Rithmic Trading | Port for executable: 56893 | 2020-06-02 09:46:57.591
Listening socket (1692). Port 56893 | Closed. | 2020-06-02 09:46:57.591
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:46:57.594
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56893. Current folder: C:\SierraChart\Rim | 2020-06-02 09:46:57.603
Rithmic Trading | Bridge process is running. | 2020-06-02 09:46:59.602
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56893 | 2020-06-02 09:46:59.602
DTC Client socket (1) | Creating socket. | 2020-06-02 09:46:59.602
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:46:59.602
Rithmic Trading | Connected to server. | 2020-06-02 09:46:59.605
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:46:59.605
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:46:59.607
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:46:59.608
Rithmic Trading | Sending logon request message. | 2020-06-02 09:46:59.608
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:46:59.611
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:46:59.615
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:46:59.615
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:46:59.920
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:47:00.059
Rithmic Trading | Received logon response. | 2020-06-02 09:47:00.059
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:47:00.059
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:47:00.059
Rithmic Trading | Logon error received from server | 2020-06-02 09:47:00.059
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:00.059
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:00.059
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:00.064
Rithmic Trading | Disconnected. | 2020-06-02 09:47:00.064
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:00.064
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:47:00.064
Rithmic Trading | Port for executable: 56907 | 2020-06-02 09:47:02.061
Listening socket (1436). Port 56907 | Closed. | 2020-06-02 09:47:02.061
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:02.063
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56907. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:02.072
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:47:02.694
DTC Client socket (1) | Closed. | 2020-06-02 09:47:02.694
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:47:04.079
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56907 | 2020-06-02 09:47:04.079
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:04.079
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:04.079
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:47:06.103 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:06.103
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:06.103
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:06.103
DTC Client socket (1) | Closed. | 2020-06-02 09:47:06.103
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:47:06.118
Rithmic Trading | Disconnected. | 2020-06-02 09:47:06.118
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:06.118
Rithmic Trading | Port for executable: 56909 | 2020-06-02 09:47:08.124
Listening socket (1232). Port 56909 | Closed. | 2020-06-02 09:47:08.124
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:08.127
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56909. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:08.135
Rithmic Trading | Bridge process is running. | 2020-06-02 09:47:10.149
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56909 | 2020-06-02 09:47:10.149
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:10.149
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:10.149
Rithmic Trading | Connected to server. | 2020-06-02 09:47:10.151
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:47:10.151
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:47:10.151
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:47:10.152
Rithmic Trading | Sending logon request message. | 2020-06-02 09:47:10.152
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:47:10.153
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:47:10.154
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:47:10.154
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:47:10.440
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:47:10.572
Rithmic Trading | Received logon response. | 2020-06-02 09:47:10.572
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:47:10.572
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:47:10.572
Rithmic Trading | Logon error received from server | 2020-06-02 09:47:10.572
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:10.572
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:10.572
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:10.586
Rithmic Trading | Disconnected. | 2020-06-02 09:47:10.586
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:10.586
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:47:10.586
Rithmic Trading | Port for executable: 56924 | 2020-06-02 09:47:12.589
Listening socket (1672). Port 56924 | Closed. | 2020-06-02 09:47:12.589
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:12.590
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56924. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:12.598
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:47:13.220
DTC Client socket (1) | Closed. | 2020-06-02 09:47:13.220
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:47:14.612
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56924 | 2020-06-02 09:47:14.612
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:14.612
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:14.612
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:47:16.635 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:16.635
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:16.635
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:16.635
DTC Client socket (1) | Closed. | 2020-06-02 09:47:16.635
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:47:16.650
Rithmic Trading | Disconnected. | 2020-06-02 09:47:16.650
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:16.650
Rithmic Trading | Port for executable: 56928 | 2020-06-02 09:47:18.650
Listening socket (1672). Port 56928 | Closed. | 2020-06-02 09:47:18.650
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:18.651
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56928. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:18.659
Rithmic Trading | Bridge process is running. | 2020-06-02 09:47:20.658
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56928 | 2020-06-02 09:47:20.658
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:20.658
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:20.658
Rithmic Trading | Connected to server. | 2020-06-02 09:47:20.661
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:47:20.661
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:47:20.663
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:47:20.665
Rithmic Trading | Sending logon request message. | 2020-06-02 09:47:20.665
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:47:20.670
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:47:20.670
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:47:20.670
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:47:20.967
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:47:21.099
Rithmic Trading | Received logon response. | 2020-06-02 09:47:21.099
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:47:21.099
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:47:21.099
Rithmic Trading | Logon error received from server | 2020-06-02 09:47:21.099
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:21.099
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:21.099
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:21.103
Rithmic Trading | Disconnected. | 2020-06-02 09:47:21.104
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:47:21.104
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:21.104
Rithmic Trading | Port for executable: 56944 | 2020-06-02 09:47:23.127
Listening socket (1672). Port 56944 | Closed. | 2020-06-02 09:47:23.127
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:23.128
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56944. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:23.142
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:47:23.749
DTC Client socket (1) | Closed. | 2020-06-02 09:47:23.749
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:47:25.158
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56944 | 2020-06-02 09:47:25.158
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:25.158
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:25.159
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:47:27.189 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:27.189
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:27.189
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:27.189
DTC Client socket (1) | Closed. | 2020-06-02 09:47:27.189
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:47:27.204
Rithmic Trading | Disconnected. | 2020-06-02 09:47:27.204
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:27.204
Rithmic Trading | Port for executable: 56947 | 2020-06-02 09:47:29.200
Listening socket (1712). Port 56947 | Closed. | 2020-06-02 09:47:29.200
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:29.201
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56947. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:29.209
Rithmic Trading | Bridge process is running. | 2020-06-02 09:47:31.232
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56947 | 2020-06-02 09:47:31.232
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:31.233
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:31.233
Rithmic Trading | Connected to server. | 2020-06-02 09:47:31.234
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:47:31.234
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:47:31.234
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:47:31.235
Rithmic Trading | Sending logon request message. | 2020-06-02 09:47:31.235
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:47:31.236
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:47:31.237
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:47:31.237
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:47:31.580
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:47:31.698
Rithmic Trading | Received logon response. | 2020-06-02 09:47:31.699
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:47:31.699
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:47:31.699
Rithmic Trading | Logon error received from server | 2020-06-02 09:47:31.699
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:31.699
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:31.699
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:31.702
Rithmic Trading | Disconnected. | 2020-06-02 09:47:31.702
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:47:31.702
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:31.702
Rithmic Trading | Port for executable: 56961 | 2020-06-02 09:47:33.697
Listening socket (1708). Port 56961 | Closed. | 2020-06-02 09:47:33.697
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:33.699
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56961. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:33.713
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:47:34.288
DTC Client socket (1) | Closed. | 2020-06-02 09:47:34.288
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:47:35.735
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56961 | 2020-06-02 09:47:35.735
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:35.735
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:35.736
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:47:37.784 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:37.784
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:37.784
DTC Client socket (1) | Closed. | 2020-06-02 09:47:37.785
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:37.785
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:47:37.800
Rithmic Trading | Disconnected. | 2020-06-02 09:47:37.800
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:37.800
Rithmic Trading | Port for executable: 56964 | 2020-06-02 09:47:39.807
Listening socket (1708). Port 56964 | Closed. | 2020-06-02 09:47:39.807
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:39.808
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56964. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:39.816
Rithmic Trading | Bridge process is running. | 2020-06-02 09:47:41.802
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56964 | 2020-06-02 09:47:41.802
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:41.802
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:41.802
Rithmic Trading | Connected to server. | 2020-06-02 09:47:41.804
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:47:41.804
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:47:41.814
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:47:41.816
Rithmic Trading | Sending logon request message. | 2020-06-02 09:47:41.816
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:47:41.819
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:47:41.824
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:47:41.824
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:47:42.103
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:47:42.237
Rithmic Trading | Received logon response. | 2020-06-02 09:47:42.237
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:47:42.237
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:47:42.237
Rithmic Trading | Logon error received from server | 2020-06-02 09:47:42.237
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:47:42.237
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:42.237
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:42.266
Rithmic Trading | Disconnected. | 2020-06-02 09:47:42.266
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:47:42.266
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:47:42.266
Rithmic Trading | Port for executable: 56977 | 2020-06-02 09:47:44.278
Listening socket (1720). Port 56977 | Closed. | 2020-06-02 09:47:44.278
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:47:44.279
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56977. Current folder: C:\SierraChart\Rim | 2020-06-02 09:47:44.287
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:47:44.894
DTC Client socket (1) | Closed. | 2020-06-02 09:47:44.894
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:47:46.305
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56977 | 2020-06-02 09:47:46.305
DTC Client socket (1) | Creating socket. | 2020-06-02 09:47:46.305
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:47:46.305
File >> Disconnect selected. | 2020-06-02 09:47:47.210
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:47:47.210
DTC Client socket (1) | Closed. | 2020-06-02 09:47:47.210
Rithmic Trading | Disconnected. | 2020-06-02 09:47:47.210
Rithmic Trading | Port for executable: 57038 | 2020-06-02 09:50:17.411
Listening socket (1652). Port 57038 | Closed. | 2020-06-02 09:50:17.411
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:17.412
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57038. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:17.428
Rithmic Trading | Bridge process is running. | 2020-06-02 09:50:19.409
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57038 | 2020-06-02 09:50:19.409
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:19.409
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:19.409
Rithmic Trading | Connected to server. | 2020-06-02 09:50:19.410
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:50:19.410
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:50:19.411
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:50:19.412
Rithmic Trading | Sending logon request message. | 2020-06-02 09:50:19.412
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:50:19.412
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:50:19.414
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:50:19.414
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:50:19.693
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:50:19.839
Rithmic Trading | Received logon response. | 2020-06-02 09:50:19.839
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:50:19.839
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:50:19.839
Rithmic Trading | Logon error received from server | 2020-06-02 09:50:19.839
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:19.839
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:19.839
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:19.862
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:50:19.862
Rithmic Trading | Disconnected. | 2020-06-02 09:50:19.862
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:19.862
Rithmic Trading | Port for executable: 57055 | 2020-06-02 09:50:21.861
Listening socket (1232). Port 57055 | Closed. | 2020-06-02 09:50:21.862
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:21.862
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57055. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:21.872
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:50:22.515
DTC Client socket (1) | Closed. | 2020-06-02 09:50:22.515
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:50:23.865
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57055 | 2020-06-02 09:50:23.865
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:23.865
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:23.865
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:50:25.919 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:25.919
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:25.919
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:25.919
DTC Client socket (1) | Closed. | 2020-06-02 09:50:25.919
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:50:25.934
Rithmic Trading | Disconnected. | 2020-06-02 09:50:25.934
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:25.934
Rithmic Trading | Port for executable: 57058 | 2020-06-02 09:50:27.961
Listening socket (1232). Port 57058 | Closed. | 2020-06-02 09:50:27.961
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:27.963
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57058. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:27.974
Rithmic Trading | Bridge process is running. | 2020-06-02 09:50:29.959
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57058 | 2020-06-02 09:50:29.959
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:29.959
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:29.959
Rithmic Trading | Connected to server. | 2020-06-02 09:50:29.961
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:50:29.961
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:50:29.962
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:50:29.963
Rithmic Trading | Sending logon request message. | 2020-06-02 09:50:29.963
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:50:29.964
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:50:29.968
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:50:29.968
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:50:30.230
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:50:30.379
Rithmic Trading | Received logon response. | 2020-06-02 09:50:30.379
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:50:30.379
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:50:30.379
Rithmic Trading | Logon error received from server | 2020-06-02 09:50:30.379
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:30.379
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:30.379
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:30.400
Rithmic Trading | Disconnected. | 2020-06-02 09:50:30.400
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:30.400
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:50:30.400
Rithmic Trading | Port for executable: 57073 | 2020-06-02 09:50:32.403
Listening socket (1232). Port 57073 | Closed. | 2020-06-02 09:50:32.403
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:32.404
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57073. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:32.412
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:50:33.043
DTC Client socket (1) | Closed. | 2020-06-02 09:50:33.043
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:50:34.413
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57073 | 2020-06-02 09:50:34.413
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:34.413
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:34.413
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:50:36.467 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:36.467
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:36.467
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:36.467
DTC Client socket (1) | Closed. | 2020-06-02 09:50:36.467
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:50:36.482
Rithmic Trading | Disconnected. | 2020-06-02 09:50:36.482
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:36.482
Rithmic Trading | Port for executable: 57077 | 2020-06-02 09:50:38.500
Listening socket (1232). Port 57077 | Closed. | 2020-06-02 09:50:38.500
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:38.501
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57077. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:38.509
Rithmic Trading | Bridge process is running. | 2020-06-02 09:50:40.505
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57077 | 2020-06-02 09:50:40.505
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:40.505
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:40.505
Rithmic Trading | Connected to server. | 2020-06-02 09:50:40.507
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:50:40.507
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:50:40.508
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:50:40.509
Rithmic Trading | Sending logon request message. | 2020-06-02 09:50:40.509
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:50:40.511
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:50:40.515
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:50:40.515
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:50:40.863
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:50:41.028
Rithmic Trading | Received logon response. | 2020-06-02 09:50:41.029
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:50:41.029
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:50:41.029
Rithmic Trading | Logon error received from server | 2020-06-02 09:50:41.029
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:41.029
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:41.029
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:41.036
Rithmic Trading | Disconnected. | 2020-06-02 09:50:41.036
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:41.036
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:50:41.036
Rithmic Trading | Port for executable: 57092 | 2020-06-02 09:50:43.047
Listening socket (1592). Port 57092 | Closed. | 2020-06-02 09:50:43.047
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:43.049
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57092. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:43.058
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:50:43.595
DTC Client socket (1) | Closed. | 2020-06-02 09:50:43.595
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:50:45.059
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57092 | 2020-06-02 09:50:45.059
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:45.059
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:45.059
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:50:47.091 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:47.091
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:47.091
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:47.091
DTC Client socket (1) | Closed. | 2020-06-02 09:50:47.091
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:50:47.106
Rithmic Trading | Disconnected. | 2020-06-02 09:50:47.107
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:47.107
Rithmic Trading | Port for executable: 57095 | 2020-06-02 09:50:49.106
Listening socket (1592). Port 57095 | Closed. | 2020-06-02 09:50:49.106
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:49.109
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57095. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:49.120
Rithmic Trading | Bridge process is running. | 2020-06-02 09:50:51.123
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57095 | 2020-06-02 09:50:51.123
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:51.123
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:51.124
Rithmic Trading | Connected to server. | 2020-06-02 09:50:51.126
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:50:51.126
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:50:51.129
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:50:51.131
Rithmic Trading | Sending logon request message. | 2020-06-02 09:50:51.131
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:50:51.133
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:50:51.138
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:50:51.138
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:50:51.432
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:50:51.559
Rithmic Trading | Received logon response. | 2020-06-02 09:50:51.559
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:50:51.559
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:50:51.559
Rithmic Trading | Logon error received from server | 2020-06-02 09:50:51.559
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:51.559
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:51.559
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:51.562
Rithmic Trading | Disconnected. | 2020-06-02 09:50:51.562
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:50:51.562
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:51.562
Rithmic Trading | Port for executable: 57109 | 2020-06-02 09:50:53.571
Listening socket (1592). Port 57109 | Closed. | 2020-06-02 09:50:53.571
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:53.572
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57109. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:53.580
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:50:54.196
DTC Client socket (1) | Closed. | 2020-06-02 09:50:54.196
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:50:55.572
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57109 | 2020-06-02 09:50:55.572
DTC Client socket (1) | Creating socket. | 2020-06-02 09:50:55.573
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:50:55.573
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:50:57.635 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:50:57.635
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:50:57.635
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:57.635
DTC Client socket (1) | Closed. | 2020-06-02 09:50:57.635
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:50:57.650
Rithmic Trading | Disconnected. | 2020-06-02 09:50:57.650
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:50:57.650
Rithmic Trading | Port for executable: 57111 | 2020-06-02 09:50:59.662
Listening socket (1592). Port 57111 | Closed. | 2020-06-02 09:50:59.662
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:50:59.666
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57111. Current folder: C:\SierraChart\Rim | 2020-06-02 09:50:59.675
Rithmic Trading | Bridge process is running. | 2020-06-02 09:51:01.682
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57111 | 2020-06-02 09:51:01.682
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:01.682
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:01.682
Rithmic Trading | Connected to server. | 2020-06-02 09:51:01.685
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:51:01.685
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:51:01.688
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:51:01.689
Rithmic Trading | Sending logon request message. | 2020-06-02 09:51:01.689
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:51:01.692
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:51:01.696
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:51:01.696
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:51:02.061
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:51:02.211
Rithmic Trading | Received logon response. | 2020-06-02 09:51:02.211
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:51:02.211
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:51:02.211
Rithmic Trading | Logon error received from server | 2020-06-02 09:51:02.211
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:02.211
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:02.211
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:02.214
Rithmic Trading | Disconnected. | 2020-06-02 09:51:02.214
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:02.214
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:51:02.214
Rithmic Trading | Port for executable: 57125 | 2020-06-02 09:51:04.226
Listening socket (1592). Port 57125 | Closed. | 2020-06-02 09:51:04.226
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:04.230
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57125. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:04.238
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:51:04.757
DTC Client socket (1) | Closed. | 2020-06-02 09:51:04.757
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:51:06.262
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57125 | 2020-06-02 09:51:06.262
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:06.263
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:06.263
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:51:08.309 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:08.310
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:08.310
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:08.310
DTC Client socket (1) | Closed. | 2020-06-02 09:51:08.310
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:51:08.324
Rithmic Trading | Disconnected. | 2020-06-02 09:51:08.324
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:08.324
Rithmic Trading | Port for executable: 57127 | 2020-06-02 09:51:10.328
Listening socket (1592). Port 57127 | Closed. | 2020-06-02 09:51:10.328
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:10.331
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57127. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:10.339
Rithmic Trading | Bridge process is running. | 2020-06-02 09:51:12.337
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57127 | 2020-06-02 09:51:12.337
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:12.337
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:12.337
Rithmic Trading | Connected to server. | 2020-06-02 09:51:12.340
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:51:12.340
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:51:12.343
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:51:12.344
Rithmic Trading | Sending logon request message. | 2020-06-02 09:51:12.344
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:51:12.347
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:51:12.351
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:51:12.351
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:51:12.624
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:51:12.791
Rithmic Trading | Received logon response. | 2020-06-02 09:51:12.791
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:51:12.791
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:51:12.791
Rithmic Trading | Logon error received from server | 2020-06-02 09:51:12.791
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:12.791
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:12.791
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:12.807
Rithmic Trading | Disconnected. | 2020-06-02 09:51:12.807
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:12.807
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:51:12.807
Rithmic Trading | Port for executable: 57142 | 2020-06-02 09:51:14.834
Listening socket (1724). Port 57142 | Closed. | 2020-06-02 09:51:14.834
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:14.837
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57142. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:14.848
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:51:15.434
DTC Client socket (1) | Closed. | 2020-06-02 09:51:15.434
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:51:16.854
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57142 | 2020-06-02 09:51:16.854
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:16.854
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:16.854
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:51:18.909 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:18.909
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:18.909
DTC Client socket (1) | Closed. | 2020-06-02 09:51:18.909
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:18.909
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:51:18.924
Rithmic Trading | Disconnected. | 2020-06-02 09:51:18.924
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:18.924
Rithmic Trading | Port for executable: 57144 | 2020-06-02 09:51:20.939
Listening socket (1724). Port 57144 | Closed. | 2020-06-02 09:51:20.939
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:20.941
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57144. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:20.948
Rithmic Trading | Bridge process is running. | 2020-06-02 09:51:22.941
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57144 | 2020-06-02 09:51:22.941
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:22.941
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:22.941
Rithmic Trading | Connected to server. | 2020-06-02 09:51:22.942
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:51:22.942
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:51:22.943
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:51:22.944
Rithmic Trading | Sending logon request message. | 2020-06-02 09:51:22.944
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:51:22.945
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:51:22.946
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:51:22.946
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:51:23.231
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:51:23.380
Rithmic Trading | Received logon response. | 2020-06-02 09:51:23.380
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:51:23.380
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:51:23.380
Rithmic Trading | Logon error received from server | 2020-06-02 09:51:23.380
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:23.380
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:23.380
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:23.395
Rithmic Trading | Disconnected. | 2020-06-02 09:51:23.395
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:23.395
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:51:23.395
Rithmic Trading | Port for executable: 57158 | 2020-06-02 09:51:25.406
Listening socket (1592). Port 57158 | Closed. | 2020-06-02 09:51:25.406
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:25.409
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57158. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:25.424
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 09:51:26.019 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:51:26.019
DTC Client socket (1) | Closed. | 2020-06-02 09:51:26.019
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:51:27.430
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57158 | 2020-06-02 09:51:27.430
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:27.430
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:27.430
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:51:29.457 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:29.457
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:29.457
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:29.457
DTC Client socket (1) | Closed. | 2020-06-02 09:51:29.457
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:51:29.472
Rithmic Trading | Disconnected. | 2020-06-02 09:51:29.472
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:29.473
Rithmic Trading | Port for executable: 57160 | 2020-06-02 09:51:31.501
Listening socket (1592). Port 57160 | Closed. | 2020-06-02 09:51:31.501
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:31.504
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57160. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:31.517
Rithmic Trading | Bridge process is running. | 2020-06-02 09:51:33.525
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57160 | 2020-06-02 09:51:33.526
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:33.526
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:33.526
Rithmic Trading | Connected to server. | 2020-06-02 09:51:33.529
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:51:33.529
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:51:33.532
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:51:33.533
Rithmic Trading | Sending logon request message. | 2020-06-02 09:51:33.533
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:51:33.536
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:51:33.540
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:51:33.540
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:51:33.846
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:51:34.015
Rithmic Trading | Received logon response. | 2020-06-02 09:51:34.015
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:51:34.015
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:51:34.015
Rithmic Trading | Logon error received from server | 2020-06-02 09:51:34.015
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:34.015
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:34.015
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:34.026
Rithmic Trading | Disconnected. | 2020-06-02 09:51:34.026
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:34.026
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:51:34.026
Rithmic Trading | Port for executable: 57175 | 2020-06-02 09:51:36.035
Listening socket (1728). Port 57175 | Closed. | 2020-06-02 09:51:36.035
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:36.036
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57175. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:36.044
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:51:36.600
DTC Client socket (1) | Closed. | 2020-06-02 09:51:36.600
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:51:38.026
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57175 | 2020-06-02 09:51:38.026
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:38.026
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:38.026
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:51:40.047 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:40.047
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:40.047
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:40.047
DTC Client socket (1) | Closed. | 2020-06-02 09:51:40.047
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:51:40.063
Rithmic Trading | Disconnected. | 2020-06-02 09:51:40.063
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:40.063
Rithmic Trading | Port for executable: 57177 | 2020-06-02 09:51:42.056
Listening socket (1592). Port 57177 | Closed. | 2020-06-02 09:51:42.056
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:42.057
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57177. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:42.065
Rithmic Trading | Bridge process is running. | 2020-06-02 09:51:44.059
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57177 | 2020-06-02 09:51:44.059
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:44.059
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:44.059
Rithmic Trading | Connected to server. | 2020-06-02 09:51:44.061
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:51:44.061
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:51:44.062
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:51:44.064
Rithmic Trading | Sending logon request message. | 2020-06-02 09:51:44.064
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:51:44.065
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:51:44.066
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:51:44.066
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:51:44.466
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:51:44.626
Rithmic Trading | Received logon response. | 2020-06-02 09:51:44.626
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:51:44.626
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:51:44.626
Rithmic Trading | Logon error received from server | 2020-06-02 09:51:44.626
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:44.626
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:44.626
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:44.639
Rithmic Trading | Disconnected. | 2020-06-02 09:51:44.639
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:44.639
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:51:44.639
Rithmic Trading | Port for executable: 57192 | 2020-06-02 09:51:46.659
Listening socket (1592). Port 57192 | Closed. | 2020-06-02 09:51:46.659
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:46.661
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57192. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:46.677
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:51:47.139
DTC Client socket (1) | Closed. | 2020-06-02 09:51:47.139
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:51:48.665
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57192 | 2020-06-02 09:51:48.665
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:48.665
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:48.665
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:51:50.679 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:50.680
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:50.680
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:50.680
DTC Client socket (1) | Closed. | 2020-06-02 09:51:50.680
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:51:50.695
Rithmic Trading | Disconnected. | 2020-06-02 09:51:50.695
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:50.695
Rithmic Trading | Port for executable: 57194 | 2020-06-02 09:51:52.699
Listening socket (1592). Port 57194 | Closed. | 2020-06-02 09:51:52.699
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:52.701
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57194. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:52.716
Rithmic Trading | Bridge process is running. | 2020-06-02 09:51:54.733
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57194 | 2020-06-02 09:51:54.733
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:54.733
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:54.734
Rithmic Trading | Connected to server. | 2020-06-02 09:51:54.736
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:51:54.736
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:51:54.739
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:51:54.741
Rithmic Trading | Sending logon request message. | 2020-06-02 09:51:54.741
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:51:54.744
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:51:54.748
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:51:54.748
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:51:55.068
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:51:55.225
Rithmic Trading | Received logon response. | 2020-06-02 09:51:55.225
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:51:55.225
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:51:55.225
Rithmic Trading | Logon error received from server | 2020-06-02 09:51:55.225
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:51:55.225
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:55.225
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:51:55.231
Rithmic Trading | Disconnected. | 2020-06-02 09:51:55.231
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:51:55.231
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:51:55.231
Rithmic Trading | Port for executable: 57207 | 2020-06-02 09:51:57.242
Listening socket (1592). Port 57207 | Closed. | 2020-06-02 09:51:57.243
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:51:57.244
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57207. Current folder: C:\SierraChart\Rim | 2020-06-02 09:51:57.259
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:51:57.797
DTC Client socket (1) | Closed. | 2020-06-02 09:51:57.798
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:51:59.278
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57207 | 2020-06-02 09:51:59.278
DTC Client socket (1) | Creating socket. | 2020-06-02 09:51:59.278
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:51:59.278
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:52:01.320 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:01.320
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:01.320
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:01.320
DTC Client socket (1) | Closed. | 2020-06-02 09:52:01.321
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:52:01.336
Rithmic Trading | Disconnected. | 2020-06-02 09:52:01.336
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:01.336
Rithmic Trading | Port for executable: 57209 | 2020-06-02 09:52:03.339
Listening socket (1592). Port 57209 | Closed. | 2020-06-02 09:52:03.339
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:03.341
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57209. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:03.357
Rithmic Trading | Bridge process is running. | 2020-06-02 09:52:05.363
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57209 | 2020-06-02 09:52:05.364
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:05.364
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:05.364
Rithmic Trading | Connected to server. | 2020-06-02 09:52:05.367
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:52:05.367
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:52:05.369
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:52:05.370
Rithmic Trading | Sending logon request message. | 2020-06-02 09:52:05.370
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:52:05.371
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:52:05.372
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:52:05.372
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:52:05.702
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:52:05.848
Rithmic Trading | Received logon response. | 2020-06-02 09:52:05.848
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:52:05.848
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:52:05.848
Rithmic Trading | Logon error received from server | 2020-06-02 09:52:05.848
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:05.848
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:05.848
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:05.851
Rithmic Trading | Disconnected. | 2020-06-02 09:52:05.851
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:05.851
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:52:05.851
Rithmic Trading | Port for executable: 57225 | 2020-06-02 09:52:07.867
Listening socket (1592). Port 57225 | Closed. | 2020-06-02 09:52:07.867
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:07.869
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57225. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:07.876
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:52:08.415
DTC Client socket (1) | Closed. | 2020-06-02 09:52:08.415
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:52:09.870
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57225 | 2020-06-02 09:52:09.870
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:09.870
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:09.870
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:52:11.898 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:11.898
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:11.898
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:11.898
DTC Client socket (1) | Closed. | 2020-06-02 09:52:11.898
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:52:11.914
Rithmic Trading | Disconnected. | 2020-06-02 09:52:11.914
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:11.914
Rithmic Trading | Port for executable: 57227 | 2020-06-02 09:52:13.940
Listening socket (1592). Port 57227 | Closed. | 2020-06-02 09:52:13.940
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:13.941
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57227. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:13.948
Rithmic Trading | Bridge process is running. | 2020-06-02 09:52:15.929
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57227 | 2020-06-02 09:52:15.929
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:15.929
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:15.929
Rithmic Trading | Connected to server. | 2020-06-02 09:52:15.932
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:52:15.932
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:52:15.935
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:52:15.936
Rithmic Trading | Sending logon request message. | 2020-06-02 09:52:15.937
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:52:15.939
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:52:15.943
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:52:15.943
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:52:16.278
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:52:16.407
Rithmic Trading | Received logon response. | 2020-06-02 09:52:16.407
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:52:16.407
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:52:16.407
Rithmic Trading | Logon error received from server | 2020-06-02 09:52:16.407
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:16.407
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:16.407
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:16.413
Rithmic Trading | Disconnected. | 2020-06-02 09:52:16.413
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:52:16.413
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:16.413
Rithmic Trading | Port for executable: 57241 | 2020-06-02 09:52:18.439
Listening socket (1732). Port 57241 | Closed. | 2020-06-02 09:52:18.439
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:18.440
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57241. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:18.449
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:52:19.034
DTC Client socket (1) | Closed. | 2020-06-02 09:52:19.034
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:52:20.445
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57241 | 2020-06-02 09:52:20.445
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:20.445
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:20.446
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:52:22.492 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:22.492
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:22.492
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:22.492
DTC Client socket (1) | Closed. | 2020-06-02 09:52:22.492
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:52:22.507
Rithmic Trading | Disconnected. | 2020-06-02 09:52:22.507
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:22.508
Rithmic Trading | Port for executable: 57243 | 2020-06-02 09:52:24.526
Listening socket (1732). Port 57243 | Closed. | 2020-06-02 09:52:24.526
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:24.527
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57243. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:24.535
Rithmic Trading | Bridge process is running. | 2020-06-02 09:52:26.562
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57243 | 2020-06-02 09:52:26.562
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:26.562
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:26.562
Rithmic Trading | Connected to server. | 2020-06-02 09:52:26.563
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:52:26.563
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:52:26.565
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:52:26.565
Rithmic Trading | Sending logon request message. | 2020-06-02 09:52:26.565
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:52:26.566
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:52:26.568
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:52:26.568
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:52:26.900
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:52:27.081
Rithmic Trading | Received logon response. | 2020-06-02 09:52:27.081
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:52:27.081
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:52:27.081
Rithmic Trading | Logon error received from server | 2020-06-02 09:52:27.081
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:27.081
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:27.081
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:27.093
Rithmic Trading | Disconnected. | 2020-06-02 09:52:27.093
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:27.093
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:52:27.093
Rithmic Trading | Port for executable: 57256 | 2020-06-02 09:52:29.105
Listening socket (1592). Port 57256 | Closed. | 2020-06-02 09:52:29.106
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:29.108
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57256. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:29.119
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:52:29.621
DTC Client socket (1) | Closed. | 2020-06-02 09:52:29.621
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:52:31.117
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57256 | 2020-06-02 09:52:31.117
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:31.117
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:31.117
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:52:33.179 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:33.179
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:33.179
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:33.179
DTC Client socket (1) | Closed. | 2020-06-02 09:52:33.179
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:52:33.194
Rithmic Trading | Disconnected. | 2020-06-02 09:52:33.195
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:33.195
Rithmic Trading | Port for executable: 57258 | 2020-06-02 09:52:35.196
Listening socket (1592). Port 57258 | Closed. | 2020-06-02 09:52:35.196
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:35.199
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57258. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:35.208
Rithmic Trading | Bridge process is running. | 2020-06-02 09:52:37.227
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57258 | 2020-06-02 09:52:37.227
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:37.227
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:37.228
Rithmic Trading | Connected to server. | 2020-06-02 09:52:37.230
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:52:37.230
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:52:37.233
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:52:37.235
Rithmic Trading | Sending logon request message. | 2020-06-02 09:52:37.235
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:52:37.237
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:52:37.241
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:52:37.241
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:52:37.735
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:52:37.998
Rithmic Trading | Received logon response. | 2020-06-02 09:52:37.998
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:52:37.998
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:52:37.998
Rithmic Trading | Logon error received from server | 2020-06-02 09:52:37.998
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:37.998
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:37.998
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:38.009
Rithmic Trading | Disconnected. | 2020-06-02 09:52:38.009
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:38.009
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:52:38.009
Rithmic Trading | Port for executable: 57272 | 2020-06-02 09:52:40.013
Listening socket (1708). Port 57272 | Closed. | 2020-06-02 09:52:40.013
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:40.016
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57272. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:40.027
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:52:40.280
DTC Client socket (1) | Closed. | 2020-06-02 09:52:40.280
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:52:42.048
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57272 | 2020-06-02 09:52:42.048
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:42.048
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:42.048
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:52:44.095 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:44.095
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:44.095
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:44.095
DTC Client socket (1) | Closed. | 2020-06-02 09:52:44.095
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:52:44.110
Rithmic Trading | Disconnected. | 2020-06-02 09:52:44.110
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:44.110
Rithmic Trading | Port for executable: 57274 | 2020-06-02 09:52:46.114
Listening socket (1708). Port 57274 | Closed. | 2020-06-02 09:52:46.114
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:46.118
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57274. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:46.126
Rithmic Trading | Bridge process is running. | 2020-06-02 09:52:48.118
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57274 | 2020-06-02 09:52:48.118
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:48.119
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:48.119
Rithmic Trading | Connected to server. | 2020-06-02 09:52:48.122
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:52:48.122
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:52:48.123
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:52:48.125
Rithmic Trading | Sending logon request message. | 2020-06-02 09:52:48.125
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:52:48.128
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:52:48.132
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:52:48.132
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:52:48.531
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:52:48.683
Rithmic Trading | Received logon response. | 2020-06-02 09:52:48.684
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:52:48.684
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:52:48.684
Rithmic Trading | Logon error received from server | 2020-06-02 09:52:48.684
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:48.684
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:48.684
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:48.699
Rithmic Trading | Disconnected. | 2020-06-02 09:52:48.699
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:48.699
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:52:48.699
Rithmic Trading | Port for executable: 57290 | 2020-06-02 09:52:50.699
Listening socket (1708). Port 57290 | Closed. | 2020-06-02 09:52:50.699
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:50.700
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57290. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:50.716
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:52:51.206
DTC Client socket (1) | Closed. | 2020-06-02 09:52:51.206
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:52:52.732
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57290 | 2020-06-02 09:52:52.732
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:52.732
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:52.732
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:52:54.778 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:54.779
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:54.779
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:54.779
DTC Client socket (1) | Closed. | 2020-06-02 09:52:54.779
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:52:54.794
Rithmic Trading | Disconnected. | 2020-06-02 09:52:54.794
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:54.794
Rithmic Trading | Port for executable: 57292 | 2020-06-02 09:52:56.788
Listening socket (1708). Port 57292 | Closed. | 2020-06-02 09:52:56.788
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:52:56.790
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57292. Current folder: C:\SierraChart\Rim | 2020-06-02 09:52:56.804
Rithmic Trading | Bridge process is running. | 2020-06-02 09:52:58.815
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57292 | 2020-06-02 09:52:58.815
DTC Client socket (1) | Creating socket. | 2020-06-02 09:52:58.815
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:52:58.816
Rithmic Trading | Connected to server. | 2020-06-02 09:52:58.817
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:52:58.817
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:52:58.817
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:52:58.818
Rithmic Trading | Sending logon request message. | 2020-06-02 09:52:58.818
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:52:58.819
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:52:58.820
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:52:58.820
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:52:59.218
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:52:59.377
Rithmic Trading | Received logon response. | 2020-06-02 09:52:59.377
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:52:59.377
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:52:59.377
Rithmic Trading | Logon error received from server | 2020-06-02 09:52:59.377
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:52:59.377
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:59.377
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:52:59.387
Rithmic Trading | Disconnected. | 2020-06-02 09:52:59.387
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:52:59.387
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:52:59.387
Rithmic Trading | Port for executable: 57307 | 2020-06-02 09:53:01.395
Listening socket (1444). Port 57307 | Closed. | 2020-06-02 09:53:01.395
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:01.396
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57307. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:01.404
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:53:01.876
DTC Client socket (1) | Closed. | 2020-06-02 09:53:01.876
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:53:03.397
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57307 | 2020-06-02 09:53:03.397
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:03.397
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:03.397
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:53:05.425 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:05.425
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:05.425
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:05.425
DTC Client socket (1) | Closed. | 2020-06-02 09:53:05.425
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:53:05.440
Rithmic Trading | Disconnected. | 2020-06-02 09:53:05.440
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:05.441
Rithmic Trading | Port for executable: 57309 | 2020-06-02 09:53:07.445
Listening socket (1444). Port 57309 | Closed. | 2020-06-02 09:53:07.445
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:07.446
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57309. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:07.453
Rithmic Trading | Bridge process is running. | 2020-06-02 09:53:09.449
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57309 | 2020-06-02 09:53:09.449
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:09.449
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:09.449
Rithmic Trading | Connected to server. | 2020-06-02 09:53:09.452
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:53:09.452
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:53:09.453
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:53:09.455
Rithmic Trading | Sending logon request message. | 2020-06-02 09:53:09.455
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:53:09.457
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:53:09.461
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:53:09.461
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:53:09.749
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:53:09.914
Rithmic Trading | Received logon response. | 2020-06-02 09:53:09.915
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:53:09.915
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:53:09.915
Rithmic Trading | Logon error received from server | 2020-06-02 09:53:09.915
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:09.915
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:09.915
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:09.918
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:53:09.918
Rithmic Trading | Disconnected. | 2020-06-02 09:53:09.918
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:09.918
Rithmic Trading | Port for executable: 57323 | 2020-06-02 09:53:11.943
Listening socket (1444). Port 57323 | Closed. | 2020-06-02 09:53:11.943
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:11.945
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57323. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:11.960
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:53:12.536
DTC Client socket (1) | Closed. | 2020-06-02 09:53:12.536
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:53:13.956
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57323 | 2020-06-02 09:53:13.956
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:13.956
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:13.956
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:53:15.987 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:15.987
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:15.987
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:15.987
DTC Client socket (1) | Closed. | 2020-06-02 09:53:15.987
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:53:16.002
Rithmic Trading | Disconnected. | 2020-06-02 09:53:16.002
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:16.003
Rithmic Trading | Port for executable: 57325 | 2020-06-02 09:53:17.992
Listening socket (1444). Port 57325 | Closed. | 2020-06-02 09:53:17.992
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:17.993
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57325. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:18.001
Rithmic Trading | Bridge process is running. | 2020-06-02 09:53:19.997
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57325 | 2020-06-02 09:53:19.997
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:19.997
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:19.998
Rithmic Trading | Connected to server. | 2020-06-02 09:53:20.000
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:53:20.000
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:53:20.002
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:53:20.003
Rithmic Trading | Sending logon request message. | 2020-06-02 09:53:20.003
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:53:20.006
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:53:20.010
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:53:20.010
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:53:20.310
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:53:20.483
Rithmic Trading | Received logon response. | 2020-06-02 09:53:20.483
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:53:20.483
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:53:20.483
Rithmic Trading | Logon error received from server | 2020-06-02 09:53:20.483
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:20.483
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:20.483
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:20.487
Rithmic Trading | Disconnected. | 2020-06-02 09:53:20.488
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:20.488
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:53:20.488
Rithmic Trading | Port for executable: 57340 | 2020-06-02 09:53:22.491
Listening socket (1444). Port 57340 | Closed. | 2020-06-02 09:53:22.491
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:22.493
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57340. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:22.508
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:53:23.061
DTC Client socket (1) | Closed. | 2020-06-02 09:53:23.061
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:53:24.528
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57340 | 2020-06-02 09:53:24.528
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:24.528
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:24.528
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:53:26.566 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:26.566
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:26.566
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:26.566
DTC Client socket (1) | Closed. | 2020-06-02 09:53:26.566
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:53:26.581
Rithmic Trading | Disconnected. | 2020-06-02 09:53:26.581
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:26.581
Rithmic Trading | Port for executable: 57342 | 2020-06-02 09:53:28.605
Listening socket (1444). Port 57342 | Closed. | 2020-06-02 09:53:28.605
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:28.606
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57342. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:28.614
Rithmic Trading | Bridge process is running. | 2020-06-02 09:53:30.607
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57342 | 2020-06-02 09:53:30.607
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:30.607
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:30.607
Rithmic Trading | Connected to server. | 2020-06-02 09:53:30.609
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:53:30.609
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:53:30.609
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:53:30.610
Rithmic Trading | Sending logon request message. | 2020-06-02 09:53:30.610
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:53:30.611
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:53:30.613
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:53:30.613
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:53:30.938
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:53:31.081
Rithmic Trading | Received logon response. | 2020-06-02 09:53:31.081
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:53:31.081
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:53:31.081
Rithmic Trading | Logon error received from server | 2020-06-02 09:53:31.081
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:31.081
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:31.081
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:31.092
Rithmic Trading | Disconnected. | 2020-06-02 09:53:31.092
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:31.092
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:53:31.092
Rithmic Trading | Port for executable: 57356 | 2020-06-02 09:53:33.113
Listening socket (1752). Port 57356 | Closed. | 2020-06-02 09:53:33.113
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:33.116
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57356. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:33.130
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:53:33.689
DTC Client socket (1) | Closed. | 2020-06-02 09:53:33.689
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:53:35.138
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57356 | 2020-06-02 09:53:35.138
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:35.138
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:35.138
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:53:37.160 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:37.161
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:37.161
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:37.161
DTC Client socket (1) | Closed. | 2020-06-02 09:53:37.161
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:53:37.176
Rithmic Trading | Disconnected. | 2020-06-02 09:53:37.176
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:37.176
Rithmic Trading | Port for executable: 57358 | 2020-06-02 09:53:39.203
Listening socket (1752). Port 57358 | Closed. | 2020-06-02 09:53:39.203
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:39.205
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57358. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:39.219
Rithmic Trading | Bridge process is running. | 2020-06-02 09:53:41.236
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57358 | 2020-06-02 09:53:41.236
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:41.236
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:41.236
Rithmic Trading | Connected to server. | 2020-06-02 09:53:41.239
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:53:41.239
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:53:41.241
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:53:41.242
Rithmic Trading | Sending logon request message. | 2020-06-02 09:53:41.242
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:53:41.245
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:53:41.249
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:53:41.249
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:53:41.615
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:53:41.739
Rithmic Trading | Received logon response. | 2020-06-02 09:53:41.739
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:53:41.739
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:53:41.739
Rithmic Trading | Logon error received from server | 2020-06-02 09:53:41.739
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:41.739
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:41.739
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:41.752
Rithmic Trading | Disconnected. | 2020-06-02 09:53:41.752
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:41.752
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:53:41.752
Rithmic Trading | Port for executable: 57371 | 2020-06-02 09:53:43.771
Listening socket (1752). Port 57371 | Closed. | 2020-06-02 09:53:43.771
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:43.773
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57371. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:43.789
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:53:44.299
DTC Client socket (1) | Closed. | 2020-06-02 09:53:44.299
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:53:45.772
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57371 | 2020-06-02 09:53:45.772
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:45.773
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:45.773
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:53:47.820 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:47.821
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:47.821
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:47.821
DTC Client socket (1) | Closed. | 2020-06-02 09:53:47.821
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:53:47.836
Rithmic Trading | Disconnected. | 2020-06-02 09:53:47.836
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:47.836
Rithmic Trading | Port for executable: 57374 | 2020-06-02 09:53:49.846
Listening socket (1444). Port 57374 | Closed. | 2020-06-02 09:53:49.846
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:49.848
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57374. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:49.862
Rithmic Trading | Bridge process is running. | 2020-06-02 09:53:51.862
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57374 | 2020-06-02 09:53:51.862
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:51.862
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:51.862
Rithmic Trading | Connected to server. | 2020-06-02 09:53:51.865
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:53:51.865
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:53:51.866
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:53:51.868
Rithmic Trading | Sending logon request message. | 2020-06-02 09:53:51.868
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:53:51.871
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:53:51.875
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:53:51.875
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:53:52.329
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:53:52.465
Rithmic Trading | Received logon response. | 2020-06-02 09:53:52.465
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:53:52.465
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:53:52.465
Rithmic Trading | Logon error received from server | 2020-06-02 09:53:52.465
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:52.465
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:52.465
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:52.479
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:53:52.480
Rithmic Trading | Disconnected. | 2020-06-02 09:53:52.480
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:52.480
Rithmic Trading | Port for executable: 57388 | 2020-06-02 09:53:54.488
Listening socket (1764). Port 57388 | Closed. | 2020-06-02 09:53:54.488
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:53:54.489
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57388. Current folder: C:\SierraChart\Rim | 2020-06-02 09:53:54.504
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 09:53:54.931 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:53:54.931
DTC Client socket (1) | Closed. | 2020-06-02 09:53:54.931
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:53:56.525
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57388 | 2020-06-02 09:53:56.525
DTC Client socket (1) | Creating socket. | 2020-06-02 09:53:56.525
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:53:56.526
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:53:58.546 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:53:58.546
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:53:58.546
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:58.546
DTC Client socket (1) | Closed. | 2020-06-02 09:53:58.546
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:53:58.562
Rithmic Trading | Disconnected. | 2020-06-02 09:53:58.562
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:53:58.562
Rithmic Trading | Port for executable: 57390 | 2020-06-02 09:54:00.573
Listening socket (1764). Port 57390 | Closed. | 2020-06-02 09:54:00.573
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:00.574
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57390. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:00.588
Rithmic Trading | Bridge process is running. | 2020-06-02 09:54:02.601
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57390 | 2020-06-02 09:54:02.601
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:02.601
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:02.601
Rithmic Trading | Connected to server. | 2020-06-02 09:54:02.602
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:54:02.602
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:54:02.603
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:54:02.604
Rithmic Trading | Sending logon request message. | 2020-06-02 09:54:02.604
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:54:02.605
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:54:02.608
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:54:02.608
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:54:02.943
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:54:03.093
Rithmic Trading | Received logon response. | 2020-06-02 09:54:03.093
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:54:03.093
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:54:03.093
Rithmic Trading | Logon error received from server | 2020-06-02 09:54:03.093
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:03.093
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:03.093
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:03.094
Rithmic Trading | Disconnected. | 2020-06-02 09:54:03.094
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:03.095
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:54:03.095
Rithmic Trading | Port for executable: 57407 | 2020-06-02 09:54:05.115
Listening socket (1764). Port 57407 | Closed. | 2020-06-02 09:54:05.115
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:05.117
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57407. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:05.126
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:54:05.665
DTC Client socket (1) | Closed. | 2020-06-02 09:54:05.665
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:54:07.133
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57407 | 2020-06-02 09:54:07.133
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:07.133
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:07.133
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:54:09.169 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:09.169
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:09.169
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:09.169
DTC Client socket (1) | Closed. | 2020-06-02 09:54:09.169
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:54:09.184
Rithmic Trading | Disconnected. | 2020-06-02 09:54:09.184
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:09.185
Rithmic Trading | Port for executable: 57409 | 2020-06-02 09:54:11.191
Listening socket (1764). Port 57409 | Closed. | 2020-06-02 09:54:11.191
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:11.193
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57409. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:11.201
Rithmic Trading | Bridge process is running. | 2020-06-02 09:54:13.197
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57409 | 2020-06-02 09:54:13.197
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:13.197
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:13.197
Rithmic Trading | Connected to server. | 2020-06-02 09:54:13.199
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:54:13.199
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:54:13.201
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:54:13.202
Rithmic Trading | Sending logon request message. | 2020-06-02 09:54:13.202
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:54:13.204
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:54:13.208
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:54:13.208
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:54:13.595
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:54:13.746
Rithmic Trading | Received logon response. | 2020-06-02 09:54:13.746
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:54:13.746
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:54:13.746
Rithmic Trading | Logon error received from server | 2020-06-02 09:54:13.746
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:13.746
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:13.746
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:13.750
Rithmic Trading | Disconnected. | 2020-06-02 09:54:13.750
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:13.750
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:54:13.750
Rithmic Trading | Port for executable: 57424 | 2020-06-02 09:54:15.750
Listening socket (1772). Port 57424 | Closed. | 2020-06-02 09:54:15.750
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:15.751
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57424. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:15.759
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:54:16.287
DTC Client socket (1) | Closed. | 2020-06-02 09:54:16.287
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:54:17.738
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57424 | 2020-06-02 09:54:17.738
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:17.738
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:17.739
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:54:19.776 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:19.776
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:19.776
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:19.776
DTC Client socket (1) | Closed. | 2020-06-02 09:54:19.777
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:54:19.792
Rithmic Trading | Disconnected. | 2020-06-02 09:54:19.792
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:19.792
Rithmic Trading | Port for executable: 57426 | 2020-06-02 09:54:21.801
Listening socket (1784). Port 57426 | Closed. | 2020-06-02 09:54:21.801
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:21.802
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57426. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:21.810
Rithmic Trading | Bridge process is running. | 2020-06-02 09:54:23.798
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57426 | 2020-06-02 09:54:23.798
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:23.798
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:23.799
Rithmic Trading | Connected to server. | 2020-06-02 09:54:23.800
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:54:23.800
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:54:23.801
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:54:23.802
Rithmic Trading | Sending logon request message. | 2020-06-02 09:54:23.802
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:54:23.803
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:54:23.806
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:54:23.806
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:54:24.146
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:54:24.343
Rithmic Trading | Received logon response. | 2020-06-02 09:54:24.343
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:54:24.343
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:54:24.343
Rithmic Trading | Logon error received from server | 2020-06-02 09:54:24.344
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:24.344
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:24.344
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:24.346
Rithmic Trading | Disconnected. | 2020-06-02 09:54:24.346
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:54:24.347
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:24.347
Rithmic Trading | Port for executable: 57441 | 2020-06-02 09:54:26.349
Listening socket (1772). Port 57441 | Closed. | 2020-06-02 09:54:26.349
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:26.352
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57441. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:26.359
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 09:54:26.891 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:54:26.891
DTC Client socket (1) | Closed. | 2020-06-02 09:54:26.891
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:54:28.374
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57441 | 2020-06-02 09:54:28.374
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:28.374
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:28.374
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:54:30.428 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:30.428
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:30.428
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:30.428
DTC Client socket (1) | Closed. | 2020-06-02 09:54:30.428
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:54:30.443
Rithmic Trading | Disconnected. | 2020-06-02 09:54:30.444
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:30.444
Rithmic Trading | Port for executable: 57444 | 2020-06-02 09:54:32.457
Listening socket (1772). Port 57444 | Closed. | 2020-06-02 09:54:32.457
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:32.460
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57444. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:32.475
Rithmic Trading | Bridge process is running. | 2020-06-02 09:54:34.491
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57444 | 2020-06-02 09:54:34.491
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:34.491
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:34.491
Rithmic Trading | Connected to server. | 2020-06-02 09:54:34.494
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:54:34.494
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:54:34.496
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:54:34.497
Rithmic Trading | Sending logon request message. | 2020-06-02 09:54:34.497
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:54:34.500
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:54:34.504
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:54:34.504
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:54:34.933
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:54:35.069
Rithmic Trading | Received logon response. | 2020-06-02 09:54:35.069
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:54:35.069
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:54:35.069
Rithmic Trading | Logon error received from server | 2020-06-02 09:54:35.069
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:35.069
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:35.069
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:35.085
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:54:35.085
Rithmic Trading | Disconnected. | 2020-06-02 09:54:35.085
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:35.085
Rithmic Trading | Port for executable: 57458 | 2020-06-02 09:54:37.097
Listening socket (1772). Port 57458 | Closed. | 2020-06-02 09:54:37.097
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:54:37.100
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57458. Current folder: C:\SierraChart\Rim | 2020-06-02 09:54:37.109
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 09:54:37.536 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:54:37.536
DTC Client socket (1) | Closed. | 2020-06-02 09:54:37.536
Rithmic Trading | Bridge process is not running! | 2020-06-02 09:54:39.125
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57458 | 2020-06-02 09:54:39.126
DTC Client socket (1) | Creating socket. | 2020-06-02 09:54:39.126
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:54:39.126
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 09:54:41.162 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:54:41.162
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:54:41.162
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:41.162
DTC Client socket (1) | Closed. | 2020-06-02 09:54:41.162
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:54:41.177
Rithmic Trading | Disconnected. | 2020-06-02 09:54:41.177
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:54:41.177
Rithmic Trading | Port for executable: 57470 | 2020-06-02 09:56:41.203
Listening socket (1772). Port 57470 | Closed. | 2020-06-02 09:56:41.203
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 09:56:41.207
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57470. Current folder: C:\SierraChart\Rim | 2020-06-02 09:56:41.215
Rithmic Trading | Bridge process is running. | 2020-06-02 09:56:43.224
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57470 | 2020-06-02 09:56:43.224
DTC Client socket (1) | Creating socket. | 2020-06-02 09:56:43.224
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 09:56:43.224
Rithmic Trading | Connected to server. | 2020-06-02 09:56:43.227
Rithmic Trading | Starting socket receive thread. | 2020-06-02 09:56:43.227
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 09:56:43.229
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 09:56:43.230
Rithmic Trading | Sending logon request message. | 2020-06-02 09:56:43.230
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 09:56:43.233
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 09:56:43.237
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 09:56:43.237
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 09:56:43.522
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 09:56:43.684
Rithmic Trading | Received logon response. | 2020-06-02 09:56:43.684
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 09:56:43.684
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 09:56:43.684
Rithmic Trading | Logon error received from server | 2020-06-02 09:56:43.684
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 09:56:43.684
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:56:43.684
DTC Client socket (1) | CloseSocket call. | 2020-06-02 09:56:43.698
Rithmic Trading | Disconnected. | 2020-06-02 09:56:43.698
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 09:56:43.698
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 09:56:43.699
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 09:56:46.296
DTC Client socket (1) | Closed. | 2020-06-02 09:56:46.296
File >> Disconnect selected. | 2020-06-02 09:56:46.689
DTC Client socket (0) | CloseSocket call. | 2020-06-02 09:56:46.689
Rithmic Trading | Disconnected. | 2020-06-02 09:56:46.689
Rithmic Trading | Port for executable: 57532 | 2020-06-02 10:02:13.009
Listening socket (1620). Port 57532 | Closed. | 2020-06-02 10:02:13.009
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:13.011
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57532. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:13.021
Rithmic Trading | Bridge process is running. | 2020-06-02 10:02:15.030
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57532 | 2020-06-02 10:02:15.030
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:15.031
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:15.031
Rithmic Trading | Connected to server. | 2020-06-02 10:02:15.032
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:02:15.032
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:02:15.035
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:02:15.036
Rithmic Trading | Sending logon request message. | 2020-06-02 10:02:15.036
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:02:15.037
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:02:15.039
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:02:15.039
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:02:15.350
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:02:15.492
Rithmic Trading | Received logon response. | 2020-06-02 10:02:15.492
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:02:15.493
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:02:15.493
Rithmic Trading | Logon error received from server | 2020-06-02 10:02:15.493
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:15.493
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:15.493
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:15.521
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:02:15.521
Rithmic Trading | Disconnected. | 2020-06-02 10:02:15.521
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:15.521
Rithmic Trading | Port for executable: 57547 | 2020-06-02 10:02:17.529
Listening socket (1620). Port 57547 | Closed. | 2020-06-02 10:02:17.529
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:17.530
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57547. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:17.538
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:02:18.110
DTC Client socket (1) | Closed. | 2020-06-02 10:02:18.110
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:02:19.527
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57547 | 2020-06-02 10:02:19.527
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:19.527
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:19.527
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:02:21.567 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:21.567
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:21.567
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:21.567
DTC Client socket (1) | Closed. | 2020-06-02 10:02:21.567
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:02:21.582
Rithmic Trading | Disconnected. | 2020-06-02 10:02:21.582
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:21.582
Rithmic Trading | Port for executable: 57549 | 2020-06-02 10:02:23.614
Listening socket (1620). Port 57549 | Closed. | 2020-06-02 10:02:23.614
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:23.616
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57549. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:23.630
Rithmic Trading | Bridge process is running. | 2020-06-02 10:02:25.626
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57549 | 2020-06-02 10:02:25.626
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:25.626
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:25.627
Rithmic Trading | Connected to server. | 2020-06-02 10:02:25.629
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:02:25.629
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:02:25.631
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:02:25.633
Rithmic Trading | Sending logon request message. | 2020-06-02 10:02:25.633
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:02:25.635
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:02:25.639
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:02:25.639
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:02:26.049
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:02:26.191
Rithmic Trading | Received logon response. | 2020-06-02 10:02:26.191
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:02:26.191
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:02:26.191
Rithmic Trading | Logon error received from server | 2020-06-02 10:02:26.191
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:26.191
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:26.192
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:26.205
Rithmic Trading | Disconnected. | 2020-06-02 10:02:26.205
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:26.205
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:02:26.205
Rithmic Trading | Port for executable: 57563 | 2020-06-02 10:02:28.202
Listening socket (1620). Port 57563 | Closed. | 2020-06-02 10:02:28.202
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:28.204
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57563. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:28.212
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:02:28.707
DTC Client socket (1) | Closed. | 2020-06-02 10:02:28.707
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:02:30.202
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57563 | 2020-06-02 10:02:30.202
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:30.202
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:30.202
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:02:32.258 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:32.258
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:32.258
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:32.258
DTC Client socket (1) | Closed. | 2020-06-02 10:02:32.258
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:02:32.273
Rithmic Trading | Disconnected. | 2020-06-02 10:02:32.273
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:32.273
Rithmic Trading | Port for executable: 57565 | 2020-06-02 10:02:34.301
Listening socket (1620). Port 57565 | Closed. | 2020-06-02 10:02:34.301
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:34.302
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57565. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:34.310
Rithmic Trading | Bridge process is running. | 2020-06-02 10:02:36.295
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57565 | 2020-06-02 10:02:36.295
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:36.295
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:36.295
Rithmic Trading | Connected to server. | 2020-06-02 10:02:36.296
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:02:36.296
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:02:36.297
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:02:36.298
Rithmic Trading | Sending logon request message. | 2020-06-02 10:02:36.298
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:02:36.298
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:02:36.300
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:02:36.300
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:02:36.687
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:02:36.874
Rithmic Trading | Received logon response. | 2020-06-02 10:02:36.874
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:02:36.874
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:02:36.875
Rithmic Trading | Logon error received from server | 2020-06-02 10:02:36.875
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:36.875
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:36.875
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:36.889
Rithmic Trading | Disconnected. | 2020-06-02 10:02:36.889
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:36.889
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:02:36.889
Rithmic Trading | Port for executable: 57580 | 2020-06-02 10:02:38.898
Listening socket (1620). Port 57580 | Closed. | 2020-06-02 10:02:38.898
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:38.900
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57580. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:38.907
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:02:39.388
DTC Client socket (1) | Closed. | 2020-06-02 10:02:39.388
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:02:40.907
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57580 | 2020-06-02 10:02:40.907
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:40.907
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:40.907
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:02:42.940 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:42.940
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:42.940
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:42.940
DTC Client socket (1) | Closed. | 2020-06-02 10:02:42.940
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:02:42.956
Rithmic Trading | Disconnected. | 2020-06-02 10:02:42.956
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:42.956
Rithmic Trading | Port for executable: 57582 | 2020-06-02 10:02:44.959
Listening socket (1808). Port 57582 | Closed. | 2020-06-02 10:02:44.959
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:44.960
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57582. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:44.969
Rithmic Trading | Bridge process is running. | 2020-06-02 10:02:46.967
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57582 | 2020-06-02 10:02:46.967
DTC Client socket (2) | Creating socket. | 2020-06-02 10:02:46.967
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:46.967
Rithmic Trading | Connected to server. | 2020-06-02 10:02:46.968
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:02:46.968
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:02:46.976
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:02:46.976
Rithmic Trading | Sending logon request message. | 2020-06-02 10:02:46.976
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:02:46.977
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:02:46.979
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:02:46.979
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:02:47.436
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:02:47.642
Rithmic Trading | Received logon response. | 2020-06-02 10:02:47.642
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:02:47.642
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:02:47.642
Rithmic Trading | Logon error received from server | 2020-06-02 10:02:47.642
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:47.642
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:47.642
DTC Client socket (2) | CloseSocket call. | 2020-06-02 10:02:47.651
Rithmic Trading | Disconnected. | 2020-06-02 10:02:47.651
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:47.651
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:02:47.652
Rithmic Trading | Port for executable: 57600 | 2020-06-02 10:02:49.646
Listening socket (1808). Port 57600 | Closed. | 2020-06-02 10:02:49.646
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:49.647
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57600. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:49.660
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-06-02 10:02:50.056
DTC Client socket (2) | Closed. | 2020-06-02 10:02:50.056
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:02:51.683
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57600 | 2020-06-02 10:02:51.683
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:51.683
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:51.683
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:02:53.723 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:53.723
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:53.723
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:53.723
DTC Client socket (1) | Closed. | 2020-06-02 10:02:53.723
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:02:53.738
Rithmic Trading | Disconnected. | 2020-06-02 10:02:53.739
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:53.739
Rithmic Trading | Port for executable: 57602 | 2020-06-02 10:02:55.744
Listening socket (1808). Port 57602 | Closed. | 2020-06-02 10:02:55.744
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:02:55.745
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57602. Current folder: C:\SierraChart\Rim | 2020-06-02 10:02:55.757
Rithmic Trading | Bridge process is running. | 2020-06-02 10:02:57.750
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57602 | 2020-06-02 10:02:57.750
DTC Client socket (1) | Creating socket. | 2020-06-02 10:02:57.751
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:02:57.751
Rithmic Trading | Connected to server. | 2020-06-02 10:02:57.753
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:02:57.753
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:02:57.755
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:02:57.757
Rithmic Trading | Sending logon request message. | 2020-06-02 10:02:57.757
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:02:57.759
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:02:57.763
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:02:57.763
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:02:58.164
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:02:58.342
Rithmic Trading | Received logon response. | 2020-06-02 10:02:58.342
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:02:58.342
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:02:58.342
Rithmic Trading | Logon error received from server | 2020-06-02 10:02:58.342
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:02:58.342
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:58.342
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:02:58.353
Rithmic Trading | Disconnected. | 2020-06-02 10:02:58.353
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:02:58.353
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:02:58.353
Rithmic Trading | Port for executable: 57616 | 2020-06-02 10:03:00.378
Listening socket (1808). Port 57616 | Closed. | 2020-06-02 10:03:00.378
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:00.379
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57616. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:00.388
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:03:00.833
DTC Client socket (1) | Closed. | 2020-06-02 10:03:00.834
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:03:02.395
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57616 | 2020-06-02 10:03:02.395
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:02.395
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:02.395
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:03:04.442 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:04.442
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:04.442
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:04.442
DTC Client socket (1) | Closed. | 2020-06-02 10:03:04.442
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:03:04.457
Rithmic Trading | Disconnected. | 2020-06-02 10:03:04.457
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:04.458
Rithmic Trading | Port for executable: 57618 | 2020-06-02 10:03:06.471
Listening socket (1808). Port 57618 | Closed. | 2020-06-02 10:03:06.471
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:06.472
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57618. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:06.480
Rithmic Trading | Bridge process is running. | 2020-06-02 10:03:08.475
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57618 | 2020-06-02 10:03:08.475
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:08.475
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:08.476
Rithmic Trading | Connected to server. | 2020-06-02 10:03:08.478
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:03:08.478
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:03:08.482
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:03:08.483
Rithmic Trading | Sending logon request message. | 2020-06-02 10:03:08.483
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:03:08.485
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:03:08.490
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:03:08.490
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:03:08.835
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:03:08.977
Rithmic Trading | Received logon response. | 2020-06-02 10:03:08.977
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:03:08.977
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:03:08.977
Rithmic Trading | Logon error received from server | 2020-06-02 10:03:08.977
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:08.977
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:08.977
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:08.991
Rithmic Trading | Disconnected. | 2020-06-02 10:03:08.991
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:08.991
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:03:08.991
Rithmic Trading | Port for executable: 57636 | 2020-06-02 10:03:10.999
Listening socket (1820). Port 57636 | Closed. | 2020-06-02 10:03:10.999
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:10.999
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57636. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:11.011
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:03:11.561
DTC Client socket (1) | Closed. | 2020-06-02 10:03:11.561
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:03:13.024
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57636 | 2020-06-02 10:03:13.024
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:13.024
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:13.024
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:03:15.036 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:15.037
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:15.037
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:15.037
DTC Client socket (1) | Closed. | 2020-06-02 10:03:15.037
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:03:15.052
Rithmic Trading | Disconnected. | 2020-06-02 10:03:15.052
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:15.052
Rithmic Trading | Port for executable: 57640 | 2020-06-02 10:03:17.065
Listening socket (1820). Port 57640 | Closed. | 2020-06-02 10:03:17.065
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:17.066
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57640. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:17.074
Rithmic Trading | Bridge process is running. | 2020-06-02 10:03:19.059
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57640 | 2020-06-02 10:03:19.059
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:19.059
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:19.059
Rithmic Trading | Connected to server. | 2020-06-02 10:03:19.062
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:03:19.062
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:03:19.065
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:03:19.066
Rithmic Trading | Sending logon request message. | 2020-06-02 10:03:19.066
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:03:19.066
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:03:19.068
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:03:19.068
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:03:19.445
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:03:19.593
Rithmic Trading | Received logon response. | 2020-06-02 10:03:19.593
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:03:19.593
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:03:19.593
Rithmic Trading | Logon error received from server | 2020-06-02 10:03:19.593
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:19.593
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:19.593
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:19.605
Rithmic Trading | Disconnected. | 2020-06-02 10:03:19.606
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:19.606
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:03:19.606
Rithmic Trading | Port for executable: 57653 | 2020-06-02 10:03:21.621
Listening socket (1832). Port 57653 | Closed. | 2020-06-02 10:03:21.621
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:21.622
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57653. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:21.630
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:03:22.145
DTC Client socket (1) | Closed. | 2020-06-02 10:03:22.145
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:03:23.643
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57653 | 2020-06-02 10:03:23.643
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:23.643
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:23.643
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:03:25.674 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:25.674
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:25.674
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:25.674
DTC Client socket (1) | Closed. | 2020-06-02 10:03:25.674
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:03:25.689
Rithmic Trading | Disconnected. | 2020-06-02 10:03:25.689
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:25.689
Rithmic Trading | Port for executable: 57655 | 2020-06-02 10:03:27.703
Listening socket (1832). Port 57655 | Closed. | 2020-06-02 10:03:27.703
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:27.706
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57655. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:27.719
Rithmic Trading | Bridge process is running. | 2020-06-02 10:03:29.723
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57655 | 2020-06-02 10:03:29.723
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:29.723
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:29.723
Rithmic Trading | Connected to server. | 2020-06-02 10:03:29.724
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:03:29.724
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:03:29.725
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:03:29.725
Rithmic Trading | Sending logon request message. | 2020-06-02 10:03:29.725
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:03:29.726
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:03:29.727
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:03:29.727
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:03:30.014
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:03:30.148
Rithmic Trading | Received logon response. | 2020-06-02 10:03:30.148
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:03:30.148
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:03:30.148
Rithmic Trading | Logon error received from server | 2020-06-02 10:03:30.148
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:30.148
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:30.148
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:30.152
Rithmic Trading | Disconnected. | 2020-06-02 10:03:30.152
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:30.152
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:03:30.152
The message log has been sent to support. | 2020-06-02 10:03:31.911 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2020-06-02 10:03:31.911
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2020-06-02 10:03:31.911
Rithmic Trading | Port for executable: 57669 | 2020-06-02 10:03:32.146
Listening socket (1808). Port 57669 | Closed. | 2020-06-02 10:03:32.146
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:32.148
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57669. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:32.156
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:03:32.812
DTC Client socket (1) | Closed. | 2020-06-02 10:03:32.813
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2020-06-02 10:03:33.406
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2020-06-02 10:03:33.650
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:03:33.650
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2020-06-02 10:03:33.803
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2020-06-02 10:03:33.803
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:03:34.147
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57669 | 2020-06-02 10:03:34.147
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:34.147
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:34.147
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:03:36.148 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:36.148
DTC Client socket (1) | Closed. | 2020-06-02 10:03:36.148
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:36.149
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:36.149
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:03:36.159
Rithmic Trading | Disconnected. | 2020-06-02 10:03:36.159
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:36.159
Rithmic Trading | Port for executable: 57695 | 2020-06-02 10:03:38.172
Listening socket (1812). Port 57695 | Closed. | 2020-06-02 10:03:38.172
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:38.173
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57695. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:38.182
Rithmic Trading | Bridge process is running. | 2020-06-02 10:03:40.195
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57695 | 2020-06-02 10:03:40.195
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:40.195
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:40.195
Rithmic Trading | Connected to server. | 2020-06-02 10:03:40.197
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:03:40.197
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:03:40.198
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:03:40.198
Rithmic Trading | Sending logon request message. | 2020-06-02 10:03:40.198
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:03:40.199
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:03:40.201
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:03:40.201
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:03:40.585
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:03:40.750
Rithmic Trading | Received logon response. | 2020-06-02 10:03:40.750
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:03:40.750
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:03:40.750
Rithmic Trading | Logon error received from server | 2020-06-02 10:03:40.750
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:40.750
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:40.750
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:40.770
Rithmic Trading | Disconnected. | 2020-06-02 10:03:40.770
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:40.770
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:03:40.770
Rithmic Trading | Port for executable: 57710 | 2020-06-02 10:03:42.783
Listening socket (1812). Port 57710 | Closed. | 2020-06-02 10:03:42.783
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:42.787
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57710. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:42.810
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:03:43.258
DTC Client socket (1) | Closed. | 2020-06-02 10:03:43.258
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:03:44.829
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57710 | 2020-06-02 10:03:44.829
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:44.829
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:44.829
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:03:46.858 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:46.858
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:46.858
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:46.858
DTC Client socket (1) | Closed. | 2020-06-02 10:03:46.858
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:03:46.873
Rithmic Trading | Disconnected. | 2020-06-02 10:03:46.873
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:46.874
Rithmic Trading | Port for executable: 57717 | 2020-06-02 10:03:48.878
Listening socket (1812). Port 57717 | Closed. | 2020-06-02 10:03:48.878
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:48.879
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57717. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:48.887
Rithmic Trading | Bridge process is running. | 2020-06-02 10:03:50.888
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57717 | 2020-06-02 10:03:50.888
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:50.888
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:50.888
Rithmic Trading | Connected to server. | 2020-06-02 10:03:50.889
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:03:50.889
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:03:50.890
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:03:50.891
Rithmic Trading | Sending logon request message. | 2020-06-02 10:03:50.891
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:03:50.892
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:03:50.893
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:03:50.893
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:03:51.228
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:03:51.417
Rithmic Trading | Received logon response. | 2020-06-02 10:03:51.417
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:03:51.417
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:03:51.417
Rithmic Trading | Logon error received from server | 2020-06-02 10:03:51.417
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:51.417
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:51.417
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:51.427
Rithmic Trading | Disconnected. | 2020-06-02 10:03:51.427
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:03:51.427
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:51.428
Rithmic Trading | Port for executable: 57734 | 2020-06-02 10:03:53.430
Listening socket (2096). Port 57734 | Closed. | 2020-06-02 10:03:53.430
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:53.431
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57734. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:53.441
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 10:03:53.954 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:03:53.954
DTC Client socket (1) | Closed. | 2020-06-02 10:03:53.954
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:03:55.450
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57734 | 2020-06-02 10:03:55.450
DTC Client socket (1) | Creating socket. | 2020-06-02 10:03:55.450
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:03:55.450
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:03:57.478 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:03:57.478
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:03:57.479
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:57.479
DTC Client socket (1) | Closed. | 2020-06-02 10:03:57.479
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:03:57.494
Rithmic Trading | Disconnected. | 2020-06-02 10:03:57.494
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:03:57.494
Rithmic Trading | Port for executable: 57736 | 2020-06-02 10:03:59.510
Listening socket (2096). Port 57736 | Closed. | 2020-06-02 10:03:59.510
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:03:59.511
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57736. Current folder: C:\SierraChart\Rim | 2020-06-02 10:03:59.519
Rithmic Trading | Bridge process is running. | 2020-06-02 10:04:01.519
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57736 | 2020-06-02 10:04:01.519
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:01.519
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:01.519
Rithmic Trading | Connected to server. | 2020-06-02 10:04:01.520
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:04:01.520
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:04:01.522
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:04:01.523
Rithmic Trading | Sending logon request message. | 2020-06-02 10:04:01.523
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:04:01.524
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:04:01.526
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:04:01.526
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:04:01.890
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:04:02.064
Rithmic Trading | Received logon response. | 2020-06-02 10:04:02.064
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:04:02.064
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:04:02.064
Rithmic Trading | Logon error received from server | 2020-06-02 10:04:02.064
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:02.064
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:02.064
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:02.068
Rithmic Trading | Disconnected. | 2020-06-02 10:04:02.068
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:02.068
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:04:02.068
Rithmic Trading | Port for executable: 57751 | 2020-06-02 10:04:04.076
Listening socket (2096). Port 57751 | Closed. | 2020-06-02 10:04:04.076
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:04.078
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57751. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:04.086
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:04:04.602
DTC Client socket (1) | Closed. | 2020-06-02 10:04:04.602
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:04:06.072
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57751 | 2020-06-02 10:04:06.072
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:06.072
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:06.072
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:04:08.095 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:08.095
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:08.095
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:08.095
DTC Client socket (1) | Closed. | 2020-06-02 10:04:08.095
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:04:08.110
Rithmic Trading | Disconnected. | 2020-06-02 10:04:08.110
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:08.111
Rithmic Trading | Port for executable: 57753 | 2020-06-02 10:04:10.121
Listening socket (2096). Port 57753 | Closed. | 2020-06-02 10:04:10.122
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:10.124
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57753. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:10.135
Rithmic Trading | Bridge process is running. | 2020-06-02 10:04:12.158
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57753 | 2020-06-02 10:04:12.158
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:12.158
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:12.158
Rithmic Trading | Connected to server. | 2020-06-02 10:04:12.159
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:04:12.159
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:04:12.160
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:04:12.160
Rithmic Trading | Sending logon request message. | 2020-06-02 10:04:12.160
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:04:12.161
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:04:12.162
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:04:12.162
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:04:12.542
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:04:12.690
Rithmic Trading | Received logon response. | 2020-06-02 10:04:12.690
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:04:12.690
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:04:12.690
Rithmic Trading | Logon error received from server | 2020-06-02 10:04:12.690
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:12.690
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:12.690
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:12.692
Rithmic Trading | Disconnected. | 2020-06-02 10:04:12.693
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:12.693
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:04:12.693
Rithmic Trading | Port for executable: 57768 | 2020-06-02 10:04:14.700
Listening socket (2000). Port 57768 | Closed. | 2020-06-02 10:04:14.700
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:14.700
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57768. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:14.708
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:04:15.211
DTC Client socket (1) | Closed. | 2020-06-02 10:04:15.211
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:04:16.732
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57768 | 2020-06-02 10:04:16.732
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:16.733
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:16.733
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:04:18.771 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:18.771
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:18.771
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:18.771
DTC Client socket (1) | Closed. | 2020-06-02 10:04:18.771
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:04:18.786
Rithmic Trading | Disconnected. | 2020-06-02 10:04:18.786
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:18.786
Rithmic Trading | Port for executable: 57770 | 2020-06-02 10:04:20.786
Listening socket (2000). Port 57770 | Closed. | 2020-06-02 10:04:20.786
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:20.787
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57770. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:20.795
Rithmic Trading | Bridge process is running. | 2020-06-02 10:04:22.806
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57770 | 2020-06-02 10:04:22.806
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:22.806
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:22.806
Rithmic Trading | Connected to server. | 2020-06-02 10:04:22.809
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:04:22.809
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:04:22.811
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:04:22.812
Rithmic Trading | Sending logon request message. | 2020-06-02 10:04:22.812
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:04:22.815
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:04:22.819
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:04:22.819
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:04:23.402
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:04:23.643
Rithmic Trading | Received logon response. | 2020-06-02 10:04:23.643
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:04:23.643
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:04:23.643
Rithmic Trading | Logon error received from server | 2020-06-02 10:04:23.643
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:23.643
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:23.643
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:23.647
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:04:23.647
Rithmic Trading | Disconnected. | 2020-06-02 10:04:23.648
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:23.648
Rithmic Trading | Port for executable: 57785 | 2020-06-02 10:04:25.648
Listening socket (2000). Port 57785 | Closed. | 2020-06-02 10:04:25.648
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:25.649
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57785. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:25.660
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:04:25.879
DTC Client socket (1) | Closed. | 2020-06-02 10:04:25.880
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:04:27.675
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57785 | 2020-06-02 10:04:27.675
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:27.675
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:27.675
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:04:29.722 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:29.722
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:29.722
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:29.722
DTC Client socket (1) | Closed. | 2020-06-02 10:04:29.722
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:04:29.737
Rithmic Trading | Disconnected. | 2020-06-02 10:04:29.737
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:29.737
Rithmic Trading | Port for executable: 57787 | 2020-06-02 10:04:31.745
Listening socket (2000). Port 57787 | Closed. | 2020-06-02 10:04:31.745
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:31.746
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57787. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:31.753
Rithmic Trading | Bridge process is running. | 2020-06-02 10:04:33.748
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57787 | 2020-06-02 10:04:33.748
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:33.748
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:33.748
Rithmic Trading | Connected to server. | 2020-06-02 10:04:33.749
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:04:33.749
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:04:33.750
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:04:33.751
Rithmic Trading | Sending logon request message. | 2020-06-02 10:04:33.751
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:04:33.751
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:04:33.753
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:04:33.753
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:04:34.057
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:04:34.240
Rithmic Trading | Received logon response. | 2020-06-02 10:04:34.240
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:04:34.240
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:04:34.240
Rithmic Trading | Logon error received from server | 2020-06-02 10:04:34.240
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:34.240
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:34.240
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:34.253
Rithmic Trading | Disconnected. | 2020-06-02 10:04:34.254
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:34.254
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:04:34.254
Rithmic Trading | Port for executable: 57827 | 2020-06-02 10:04:36.256
Listening socket (1988). Port 57827 | Closed. | 2020-06-02 10:04:36.256
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:36.257
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57827. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:36.265
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 10:04:36.837 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:04:36.837
DTC Client socket (1) | Closed. | 2020-06-02 10:04:36.837
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:04:38.278
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57827 | 2020-06-02 10:04:38.278
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:38.278
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:38.278
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:04:40.310 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:40.310
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:40.310
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:40.310
DTC Client socket (1) | Closed. | 2020-06-02 10:04:40.310
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:04:40.325
Rithmic Trading | Disconnected. | 2020-06-02 10:04:40.325
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:40.325
Rithmic Trading | Port for executable: 57857 | 2020-06-02 10:04:42.333
Listening socket (1988). Port 57857 | Closed. | 2020-06-02 10:04:42.333
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:42.334
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57857. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:42.342
Rithmic Trading | Bridge process is running. | 2020-06-02 10:04:44.349
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57857 | 2020-06-02 10:04:44.349
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:44.350
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:44.350
Rithmic Trading | Connected to server. | 2020-06-02 10:04:44.352
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:04:44.352
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:04:44.353
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:04:44.354
Rithmic Trading | Sending logon request message. | 2020-06-02 10:04:44.354
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:04:44.356
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:04:44.358
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:04:44.358
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:04:44.730
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:04:44.979
Rithmic Trading | Received logon response. | 2020-06-02 10:04:44.979
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:04:44.979
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:04:44.979
Rithmic Trading | Logon error received from server | 2020-06-02 10:04:44.979
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:44.979
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:44.979
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:44.995
Rithmic Trading | Disconnected. | 2020-06-02 10:04:44.995
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:44.995
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:04:44.995
Rithmic Trading | Port for executable: 57883 | 2020-06-02 10:04:46.990
Listening socket (1944). Port 57883 | Closed. | 2020-06-02 10:04:46.990
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:46.991
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57883. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:46.999
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:04:47.404
DTC Client socket (1) | Closed. | 2020-06-02 10:04:47.404
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:04:48.998
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57883 | 2020-06-02 10:04:48.998
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:48.999
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:48.999
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:04:51.020 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:51.020
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:51.020
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:51.020
DTC Client socket (1) | Closed. | 2020-06-02 10:04:51.020
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:04:51.036
Rithmic Trading | Disconnected. | 2020-06-02 10:04:51.036
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:51.036
Rithmic Trading | Port for executable: 57885 | 2020-06-02 10:04:53.049
Listening socket (2244). Port 57885 | Closed. | 2020-06-02 10:04:53.049
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:53.050
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57885. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:53.058
Rithmic Trading | Bridge process is running. | 2020-06-02 10:04:55.064
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57885 | 2020-06-02 10:04:55.064
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:55.064
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:55.064
Rithmic Trading | Connected to server. | 2020-06-02 10:04:55.065
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:04:55.065
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:04:55.065
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:04:55.066
Rithmic Trading | Sending logon request message. | 2020-06-02 10:04:55.066
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:04:55.067
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:04:55.068
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:04:55.068
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:04:55.353
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:04:55.489
Rithmic Trading | Received logon response. | 2020-06-02 10:04:55.489
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:04:55.489
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:04:55.489
Rithmic Trading | Logon error received from server | 2020-06-02 10:04:55.489
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:04:55.489
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:55.489
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:04:55.501
Rithmic Trading | Disconnected. | 2020-06-02 10:04:55.501
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:04:55.501
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:04:55.502
Rithmic Trading | Port for executable: 57899 | 2020-06-02 10:04:57.503
Listening socket (2000). Port 57899 | Closed. | 2020-06-02 10:04:57.503
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:04:57.504
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57899. Current folder: C:\SierraChart\Rim | 2020-06-02 10:04:57.513
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:04:58.126
DTC Client socket (1) | Closed. | 2020-06-02 10:04:58.126
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:04:59.526
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57899 | 2020-06-02 10:04:59.526
DTC Client socket (1) | Creating socket. | 2020-06-02 10:04:59.526
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:04:59.526
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:05:01.549 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:01.549
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:01.549
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:01.549
DTC Client socket (1) | Closed. | 2020-06-02 10:05:01.549
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:05:01.564
Rithmic Trading | Disconnected. | 2020-06-02 10:05:01.564
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:01.564
Rithmic Trading | Port for executable: 57948 | 2020-06-02 10:05:03.568
Listening socket (2244). Port 57948 | Closed. | 2020-06-02 10:05:03.568
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:03.569
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57948. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:03.578
Rithmic Trading | Bridge process is running. | 2020-06-02 10:05:05.572
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57948 | 2020-06-02 10:05:05.572
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:05.572
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:05.572
Rithmic Trading | Connected to server. | 2020-06-02 10:05:05.574
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:05:05.574
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:05:05.576
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:05:05.577
Rithmic Trading | Sending logon request message. | 2020-06-02 10:05:05.577
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:05:05.579
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:05:05.582
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:05:05.583
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:05:05.954
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:05:06.094
Rithmic Trading | Received logon response. | 2020-06-02 10:05:06.094
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:05:06.094
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:05:06.094
Rithmic Trading | Logon error received from server | 2020-06-02 10:05:06.094
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:06.094
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:06.094
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:06.106
Rithmic Trading | Disconnected. | 2020-06-02 10:05:06.106
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:06.106
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:05:06.106
Rithmic Trading | Port for executable: 57976 | 2020-06-02 10:05:08.125
Listening socket (1988). Port 57976 | Closed. | 2020-06-02 10:05:08.125
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:08.126
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57976. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:08.134
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 10:05:08.655 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:05:08.655
DTC Client socket (1) | Closed. | 2020-06-02 10:05:08.655
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:05:10.136
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57976 | 2020-06-02 10:05:10.136
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:10.136
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:10.136
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:05:12.178 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:12.178
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:12.178
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:12.178
DTC Client socket (1) | Closed. | 2020-06-02 10:05:12.178
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:05:12.193
Rithmic Trading | Disconnected. | 2020-06-02 10:05:12.193
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:12.193
Rithmic Trading | Port for executable: 57980 | 2020-06-02 10:05:14.222
Listening socket (2268). Port 57980 | Closed. | 2020-06-02 10:05:14.222
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:14.224
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57980. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:14.232
Rithmic Trading | Bridge process is running. | 2020-06-02 10:05:16.236
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57980 | 2020-06-02 10:05:16.236
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:16.236
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:16.236
Rithmic Trading | Connected to server. | 2020-06-02 10:05:16.239
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:05:16.239
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:05:16.242
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:05:16.243
Rithmic Trading | Sending logon request message. | 2020-06-02 10:05:16.243
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:05:16.246
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:05:16.253
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:05:16.253
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:05:16.535
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:05:16.705
Rithmic Trading | Received logon response. | 2020-06-02 10:05:16.705
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:05:16.705
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:05:16.705
Rithmic Trading | Logon error received from server | 2020-06-02 10:05:16.705
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:16.705
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:16.705
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:16.721
Rithmic Trading | Disconnected. | 2020-06-02 10:05:16.721
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:16.721
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:05:16.721
Rithmic Trading | Port for executable: 57996 | 2020-06-02 10:05:18.720
Listening socket (1988). Port 57996 | Closed. | 2020-06-02 10:05:18.720
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:18.722
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57996. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:18.731
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:05:19.310
DTC Client socket (1) | Closed. | 2020-06-02 10:05:19.310
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:05:20.740
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57996 | 2020-06-02 10:05:20.740
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:20.740
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:20.740
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:05:22.757 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:22.758
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:22.758
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:22.758
DTC Client socket (1) | Closed. | 2020-06-02 10:05:22.758
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:05:22.773
Rithmic Trading | Disconnected. | 2020-06-02 10:05:22.773
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:22.773
Rithmic Trading | Port for executable: 57998 | 2020-06-02 10:05:24.772
Listening socket (2244). Port 57998 | Closed. | 2020-06-02 10:05:24.772
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:24.773
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:57998. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:24.781
Rithmic Trading | Bridge process is running. | 2020-06-02 10:05:26.772
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57998 | 2020-06-02 10:05:26.772
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:26.772
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:26.772
Rithmic Trading | Connected to server. | 2020-06-02 10:05:26.773
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:05:26.773
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:05:26.774
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:05:26.775
Rithmic Trading | Sending logon request message. | 2020-06-02 10:05:26.775
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:05:26.776
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:05:26.778
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:05:26.778
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:05:27.060
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:05:27.197
Rithmic Trading | Received logon response. | 2020-06-02 10:05:27.197
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:05:27.197
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:05:27.197
Rithmic Trading | Logon error received from server | 2020-06-02 10:05:27.197
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:27.197
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:27.197
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:27.210
Rithmic Trading | Disconnected. | 2020-06-02 10:05:27.210
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:27.210
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:05:27.210
Rithmic Trading | Port for executable: 58012 | 2020-06-02 10:05:29.223
Listening socket (2264). Port 58012 | Closed. | 2020-06-02 10:05:29.223
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:29.224
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58012. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:29.238
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-02 10:05:29.866 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:05:29.866
DTC Client socket (1) | Closed. | 2020-06-02 10:05:29.866
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:05:31.238
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58012 | 2020-06-02 10:05:31.238
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:31.238
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:31.238
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:05:33.277 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:33.277
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:33.277
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:33.277
DTC Client socket (1) | Closed. | 2020-06-02 10:05:33.277
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:05:33.292
Rithmic Trading | Disconnected. | 2020-06-02 10:05:33.293
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:33.293
Rithmic Trading | Port for executable: 58014 | 2020-06-02 10:05:35.289
Listening socket (2264). Port 58014 | Closed. | 2020-06-02 10:05:35.289
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:35.290
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58014. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:35.298
Rithmic Trading | Bridge process is running. | 2020-06-02 10:05:37.285
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58014 | 2020-06-02 10:05:37.285
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:37.285
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:37.285
Rithmic Trading | Connected to server. | 2020-06-02 10:05:37.286
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:05:37.286
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:05:37.287
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:05:37.287
Rithmic Trading | Sending logon request message. | 2020-06-02 10:05:37.287
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:05:37.288
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:05:37.290
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:05:37.290
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:05:37.623
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:05:37.770
Rithmic Trading | Received logon response. | 2020-06-02 10:05:37.771
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:05:37.771
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:05:37.771
Rithmic Trading | Logon error received from server | 2020-06-02 10:05:37.771
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:37.771
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:37.771
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:37.785
Rithmic Trading | Disconnected. | 2020-06-02 10:05:37.785
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:37.785
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:05:37.785
Rithmic Trading | Port for executable: 58028 | 2020-06-02 10:05:39.793
Listening socket (2264). Port 58028 | Closed. | 2020-06-02 10:05:39.793
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:39.795
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58028. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:39.804
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:05:40.379
DTC Client socket (1) | Closed. | 2020-06-02 10:05:40.379
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:05:41.789
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58028 | 2020-06-02 10:05:41.789
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:41.789
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:41.789
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:05:43.825 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:43.825
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:43.825
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:43.825
DTC Client socket (1) | Closed. | 2020-06-02 10:05:43.825
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:05:43.840
Rithmic Trading | Disconnected. | 2020-06-02 10:05:43.841
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:43.841
Rithmic Trading | Port for executable: 58031 | 2020-06-02 10:05:45.850
Listening socket (2264). Port 58031 | Closed. | 2020-06-02 10:05:45.850
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:45.852
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58031. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:45.873
Rithmic Trading | Bridge process is running. | 2020-06-02 10:05:47.868
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58031 | 2020-06-02 10:05:47.868
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:47.868
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:47.868
Rithmic Trading | Connected to server. | 2020-06-02 10:05:47.871
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:05:47.871
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:05:47.873
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:05:47.875
Rithmic Trading | Sending logon request message. | 2020-06-02 10:05:47.875
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:05:47.877
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:05:47.882
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:05:47.882
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:05:48.227
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:05:48.353
Rithmic Trading | Received logon response. | 2020-06-02 10:05:48.355
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:05:48.355
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:05:48.355
Rithmic Trading | Logon error received from server | 2020-06-02 10:05:48.355
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:48.355
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:48.355
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:48.368
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:05:48.368
Rithmic Trading | Disconnected. | 2020-06-02 10:05:48.368
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:48.368
Rithmic Trading | Port for executable: 58046 | 2020-06-02 10:05:50.366
Listening socket (2264). Port 58046 | Closed. | 2020-06-02 10:05:50.366
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:50.366
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58046. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:50.376
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:05:50.957
DTC Client socket (1) | Closed. | 2020-06-02 10:05:50.957
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:05:52.370
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58046 | 2020-06-02 10:05:52.371
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:52.371
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:52.371
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:05:54.401 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:54.401
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:54.401
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:54.401
DTC Client socket (1) | Closed. | 2020-06-02 10:05:54.401
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:05:54.416
Rithmic Trading | Disconnected. | 2020-06-02 10:05:54.416
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:54.416
Rithmic Trading | Port for executable: 58049 | 2020-06-02 10:05:56.430
Listening socket (1752). Port 58049 | Closed. | 2020-06-02 10:05:56.430
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:05:56.431
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58049. Current folder: C:\SierraChart\Rim | 2020-06-02 10:05:56.439
Rithmic Trading | Bridge process is running. | 2020-06-02 10:05:58.450
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58049 | 2020-06-02 10:05:58.450
DTC Client socket (1) | Creating socket. | 2020-06-02 10:05:58.450
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:05:58.450
Rithmic Trading | Connected to server. | 2020-06-02 10:05:58.451
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:05:58.451
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:05:58.452
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:05:58.453
Rithmic Trading | Sending logon request message. | 2020-06-02 10:05:58.453
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:05:58.454
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:05:58.455
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:05:58.455
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:05:58.743
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:05:58.877
Rithmic Trading | Received logon response. | 2020-06-02 10:05:58.877
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:05:58.877
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:05:58.877
Rithmic Trading | Logon error received from server | 2020-06-02 10:05:58.877
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:05:58.877
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:58.877
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:05:58.890
Rithmic Trading | Disconnected. | 2020-06-02 10:05:58.890
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:05:58.890
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:05:58.890
Rithmic Trading | Port for executable: 58062 | 2020-06-02 10:06:00.884
Listening socket (2000). Port 58062 | Closed. | 2020-06-02 10:06:00.884
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:00.885
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58062. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:00.894
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:06:01.536
DTC Client socket (1) | Closed. | 2020-06-02 10:06:01.536
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:06:02.902
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58062 | 2020-06-02 10:06:02.902
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:02.902
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:02.902
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:06:04.930 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:04.930
DTC Client socket (1) | Closed. | 2020-06-02 10:06:04.930
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:04.931
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:04.931
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:06:04.947
Rithmic Trading | Disconnected. | 2020-06-02 10:06:04.947
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:04.947
Rithmic Trading | Port for executable: 58064 | 2020-06-02 10:06:06.965
Listening socket (2000). Port 58064 | Closed. | 2020-06-02 10:06:06.965
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:06.967
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58064. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:06.982
Rithmic Trading | Bridge process is running. | 2020-06-02 10:06:08.989
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58064 | 2020-06-02 10:06:08.989
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:08.989
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:08.989
Rithmic Trading | Connected to server. | 2020-06-02 10:06:08.990
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:06:08.990
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:06:08.990
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:06:08.991
Rithmic Trading | Sending logon request message. | 2020-06-02 10:06:08.991
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:06:08.992
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:06:08.993
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:06:08.993
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:06:09.304
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:06:09.434
Rithmic Trading | Received logon response. | 2020-06-02 10:06:09.434
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:06:09.434
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:06:09.434
Rithmic Trading | Logon error received from server | 2020-06-02 10:06:09.434
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:09.434
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:09.434
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:09.442
Rithmic Trading | Disconnected. | 2020-06-02 10:06:09.442
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:09.442
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:06:09.443
Rithmic Trading | Port for executable: 58080 | 2020-06-02 10:06:11.450
Listening socket (2084). Port 58080 | Closed. | 2020-06-02 10:06:11.450
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:11.451
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58080. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:11.459
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:06:12.055
DTC Client socket (1) | Closed. | 2020-06-02 10:06:12.055
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:06:13.472
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58080 | 2020-06-02 10:06:13.472
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:13.472
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:13.472
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:06:15.497 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:15.497
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:15.497
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:15.497
DTC Client socket (1) | Closed. | 2020-06-02 10:06:15.497
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:06:15.512
Rithmic Trading | Disconnected. | 2020-06-02 10:06:15.512
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:15.512
Rithmic Trading | Port for executable: 58082 | 2020-06-02 10:06:17.526
Listening socket (2084). Port 58082 | Closed. | 2020-06-02 10:06:17.526
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:17.527
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58082. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:17.534
Rithmic Trading | Bridge process is running. | 2020-06-02 10:06:19.533
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58082 | 2020-06-02 10:06:19.533
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:19.533
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:19.533
Rithmic Trading | Connected to server. | 2020-06-02 10:06:19.534
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:06:19.534
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:06:19.535
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:06:19.539
Rithmic Trading | Sending logon request message. | 2020-06-02 10:06:19.539
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:06:19.540
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:06:19.543
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:06:19.543
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:06:19.853
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:06:19.991
Rithmic Trading | Received logon response. | 2020-06-02 10:06:19.991
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:06:19.991
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:06:19.991
Rithmic Trading | Logon error received from server | 2020-06-02 10:06:19.991
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:19.991
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:19.991
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:20.002
Rithmic Trading | Disconnected. | 2020-06-02 10:06:20.002
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:20.002
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:06:20.002
Rithmic Trading | Port for executable: 58096 | 2020-06-02 10:06:21.995
Listening socket (2084). Port 58096 | Closed. | 2020-06-02 10:06:21.995
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:21.997
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58096. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:22.010
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:06:22.620
DTC Client socket (1) | Closed. | 2020-06-02 10:06:22.620
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:06:24.007
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58096 | 2020-06-02 10:06:24.007
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:24.007
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:24.007
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:06:26.037 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:26.037
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:26.037
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:26.037
DTC Client socket (1) | Closed. | 2020-06-02 10:06:26.037
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:06:26.053
Rithmic Trading | Disconnected. | 2020-06-02 10:06:26.053
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:26.053
Rithmic Trading | Port for executable: 58098 | 2020-06-02 10:06:28.125
Listening socket (2084). Port 58098 | Closed. | 2020-06-02 10:06:28.125
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:28.127
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58098. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:28.136
Rithmic Trading | Bridge process is running. | 2020-06-02 10:06:30.130
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58098 | 2020-06-02 10:06:30.130
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:30.131
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:30.131
Rithmic Trading | Connected to server. | 2020-06-02 10:06:30.133
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:06:30.133
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:06:30.135
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:06:30.137
Rithmic Trading | Sending logon request message. | 2020-06-02 10:06:30.137
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:06:30.140
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:06:30.144
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:06:30.144
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:06:30.461
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:06:30.581
Rithmic Trading | Received logon response. | 2020-06-02 10:06:30.581
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:06:30.581
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:06:30.581
Rithmic Trading | Logon error received from server | 2020-06-02 10:06:30.581
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:30.581
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:30.581
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:30.591
Rithmic Trading | Disconnected. | 2020-06-02 10:06:30.591
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:30.591
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:06:30.591
Rithmic Trading | Port for executable: 58111 | 2020-06-02 10:06:32.600
Listening socket (2268). Port 58111 | Closed. | 2020-06-02 10:06:32.600
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:06:32.601
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58111. Current folder: C:\SierraChart\Rim | 2020-06-02 10:06:32.613
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:06:33.225
DTC Client socket (1) | Closed. | 2020-06-02 10:06:33.225
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:06:34.612
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58111 | 2020-06-02 10:06:34.612
DTC Client socket (1) | Creating socket. | 2020-06-02 10:06:34.612
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:06:34.613
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:06:36.650 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:06:36.650
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:06:36.650
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:36.650
DTC Client socket (1) | Closed. | 2020-06-02 10:06:36.650
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:06:36.666
Rithmic Trading | Disconnected. | 2020-06-02 10:06:36.666
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:06:36.666
File >> Disconnect selected. | 2020-06-02 10:06:40.031
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:06:40.031
Rithmic Trading | Disconnected. | 2020-06-02 10:06:40.031
Rithmic Trading | Port for executable: 58115 | 2020-06-02 10:07:19.313
Listening socket (2084). Port 58115 | Closed. | 2020-06-02 10:07:19.314
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:19.315
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58115. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:19.323
Rithmic Trading | Bridge process is running. | 2020-06-02 10:07:21.319
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58115 | 2020-06-02 10:07:21.319
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:21.319
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:21.319
Rithmic Trading | Connected to server. | 2020-06-02 10:07:21.322
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:07:21.322
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:07:21.324
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:07:21.325
Rithmic Trading | Sending logon request message. | 2020-06-02 10:07:21.325
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:07:21.328
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:07:21.332
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:07:21.332
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:07:21.603
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:07:21.765
Rithmic Trading | Received logon response. | 2020-06-02 10:07:21.765
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:07:21.765
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:07:21.765
Rithmic Trading | Logon error received from server | 2020-06-02 10:07:21.765
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:21.765
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:21.765
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:21.778
Rithmic Trading | Disconnected. | 2020-06-02 10:07:21.778
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:21.778
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:07:21.778
Rithmic Trading | Port for executable: 58129 | 2020-06-02 10:07:23.780
Listening socket (2056). Port 58129 | Closed. | 2020-06-02 10:07:23.780
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:23.781
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58129. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:23.790
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:07:24.405
DTC Client socket (1) | Closed. | 2020-06-02 10:07:24.405
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:07:25.790
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58129 | 2020-06-02 10:07:25.790
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:25.790
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:25.790
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:07:27.844 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:27.844
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:27.845
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:27.845
DTC Client socket (1) | Closed. | 2020-06-02 10:07:27.845
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:07:27.866
Rithmic Trading | Disconnected. | 2020-06-02 10:07:27.866
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:27.866
Rithmic Trading | Port for executable: 58131 | 2020-06-02 10:07:29.886
Listening socket (2056). Port 58131 | Closed. | 2020-06-02 10:07:29.886
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:29.887
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58131. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:29.895
Rithmic Trading | Bridge process is running. | 2020-06-02 10:07:31.889
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58131 | 2020-06-02 10:07:31.889
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:31.889
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:31.889
Rithmic Trading | Connected to server. | 2020-06-02 10:07:31.892
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:07:31.892
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:07:31.894
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:07:31.895
Rithmic Trading | Sending logon request message. | 2020-06-02 10:07:31.895
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:07:31.898
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:07:31.902
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:07:31.902
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:07:32.206
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:07:32.346
Rithmic Trading | Received logon response. | 2020-06-02 10:07:32.346
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:07:32.346
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:07:32.346
Rithmic Trading | Logon error received from server | 2020-06-02 10:07:32.346
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:32.346
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:32.346
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:32.358
Rithmic Trading | Disconnected. | 2020-06-02 10:07:32.358
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:32.358
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:07:32.358
Rithmic Trading | Port for executable: 58144 | 2020-06-02 10:07:34.378
Listening socket (2060). Port 58144 | Closed. | 2020-06-02 10:07:34.378
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:34.381
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58144. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:34.395
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:07:34.976
DTC Client socket (1) | Closed. | 2020-06-02 10:07:34.976
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:07:36.394
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58144 | 2020-06-02 10:07:36.394
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:36.394
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:36.394
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:07:38.409 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:38.409
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:38.409
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:38.409
DTC Client socket (1) | Closed. | 2020-06-02 10:07:38.409
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:07:38.424
Rithmic Trading | Disconnected. | 2020-06-02 10:07:38.424
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:38.424
Rithmic Trading | Port for executable: 58146 | 2020-06-02 10:07:40.429
Listening socket (2060). Port 58146 | Closed. | 2020-06-02 10:07:40.429
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:40.431
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58146. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:40.440
Rithmic Trading | Bridge process is running. | 2020-06-02 10:07:42.446
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58146 | 2020-06-02 10:07:42.446
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:42.446
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:42.446
Rithmic Trading | Connected to server. | 2020-06-02 10:07:42.449
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:07:42.449
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:07:42.451
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:07:42.453
Rithmic Trading | Sending logon request message. | 2020-06-02 10:07:42.453
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:07:42.455
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:07:42.460
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:07:42.460
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:07:42.740
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:07:42.856
Rithmic Trading | Received logon response. | 2020-06-02 10:07:42.856
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:07:42.856
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:07:42.856
Rithmic Trading | Logon error received from server | 2020-06-02 10:07:42.856
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:42.856
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:42.856
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:42.869
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:07:42.870
Rithmic Trading | Disconnected. | 2020-06-02 10:07:42.870
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:42.870
Rithmic Trading | Port for executable: 58160 | 2020-06-02 10:07:44.872
Listening socket (2060). Port 58160 | Closed. | 2020-06-02 10:07:44.872
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:44.874
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58160. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:44.888
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:07:45.514
DTC Client socket (1) | Closed. | 2020-06-02 10:07:45.514
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:07:46.884
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58160 | 2020-06-02 10:07:46.884
DTC Client socket (2) | Creating socket. | 2020-06-02 10:07:46.884
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:46.884
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:07:48.938 *
DTC Client socket (2) | CloseSocket call. | 2020-06-02 10:07:48.938
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:48.938
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:48.938
DTC Client socket (2) | Closed. | 2020-06-02 10:07:48.938
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:07:48.953
Rithmic Trading | Disconnected. | 2020-06-02 10:07:48.954
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:48.954
Rithmic Trading | Port for executable: 58163 | 2020-06-02 10:07:50.964
Listening socket (1944). Port 58163 | Closed. | 2020-06-02 10:07:50.964
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:50.967
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58163. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:50.975
Rithmic Trading | Bridge process is running. | 2020-06-02 10:07:52.974
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58163 | 2020-06-02 10:07:52.974
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:52.974
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:52.974
Rithmic Trading | Connected to server. | 2020-06-02 10:07:52.977
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:07:52.977
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:07:52.979
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:07:52.988
Rithmic Trading | Sending logon request message. | 2020-06-02 10:07:52.988
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:07:52.989
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:07:52.991
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:07:52.991
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-02 10:07:53.322
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-02 10:07:53.466
Rithmic Trading | Received logon response. | 2020-06-02 10:07:53.466
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-02 10:07:53.466
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-02 10:07:53.466
Rithmic Trading | Logon error received from server | 2020-06-02 10:07:53.466
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:53.466
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:53.466
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:53.474
Rithmic Trading | Disconnected. | 2020-06-02 10:07:53.474
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:53.474
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-02 10:07:53.474
Rithmic Trading | Port for executable: 58177 | 2020-06-02 10:07:55.508
Listening socket (1944). Port 58177 | Closed. | 2020-06-02 10:07:55.508
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:07:55.511
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58177. Current folder: C:\SierraChart\Rim | 2020-06-02 10:07:55.519
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-02 10:07:56.056
DTC Client socket (1) | Closed. | 2020-06-02 10:07:56.057
Rithmic Trading | Bridge process is not running! | 2020-06-02 10:07:57.520
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58177 | 2020-06-02 10:07:57.520
DTC Client socket (1) | Creating socket. | 2020-06-02 10:07:57.520
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:07:57.520
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-02 10:07:59.545 *
DTC Client socket (1) | CloseSocket call. | 2020-06-02 10:07:59.545
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-02 10:07:59.545
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:59.545
DTC Client socket (1) | Closed. | 2020-06-02 10:07:59.546
DTC Client socket (0) | CloseSocket call. | 2020-06-02 10:07:59.561
Rithmic Trading | Disconnected. | 2020-06-02 10:07:59.561
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-02 10:07:59.561
Rithmic Trading | Port for executable: 58179 | 2020-06-02 10:08:01.576
Listening socket (1944). Port 58179 | Closed. | 2020-06-02 10:08:01.576
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-02 10:08:01.577
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:58179. Current folder: C:\SierraChart\Rim | 2020-06-02 10:08:01.591
Rithmic Trading | Bridge process is running. | 2020-06-02 10:08:03.599
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58179 | 2020-06-02 10:08:03.599
DTC Client socket (1) | Creating socket. | 2020-06-02 10:08:03.599
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-02 10:08:03.599
Rithmic Trading | Connected to server. | 2020-06-02 10:08:03.601
Rithmic Trading | Starting socket receive thread. | 2020-06-02 10:08:03.601
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-02 10:08:03.603
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-02 10:08:03.604
Rithmic Trading | Sending logon request message. | 2020-06-02 10:08:03.604
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-02 10:08:03.607
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-02 10:08:03.611
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-06-02 10:08:03.611
[2020-06-02 17:46:12]
Refer to:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward
