Date/Time: Fri, 07 Feb 2025 16:57:39 +0000
AMP Futures - Sierra Package 5
View Count: 1550
[2020-06-02 14:15:18] |
User338902 - Posts: 4 |
Hi! I currently have Package 5 activated, paid directly to you - and will continue with the sierra chart service package 5 paid directly via AMP Futures. Do I need to do change anything on my account, or will this be all automatic? I have set the package type to disabled for now on the Sierra Account Control Panel. thx, Sascha |
[2020-06-02 18:02:14] |
There is nothing more you need to do.
[2020-06-08 07:27:52] |
ok thanks, but how is my Sierrachart account linked to the AMP account then? Is this performed via the CQG Data Feed? |
[2020-06-08 13:25:38] |
John - SC Support - Posts: 37826 |
You will need to log into the Sierra Chart account you were provided by AMP. Refer to: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
