Date/Time: Fri, 28 Feb 2025 09:35:47 +0000
Overlay multiple symbols on percentage-change chart
View Count: 2801
[2014-01-24 08:53:42] |
mmarczewski - Posts: 4 |
I am having great difficulty figuring out how to overlay multiple symbols on the same chart showing their percentage change. I've searched the board but didn't find the solution. Has anyone tried this? http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#OverlayingMultipleSymbols |
[2014-01-25 02:17:12] |
This is accomplished by opening a separate chart for each of the symbols and then adding the Percent Change Since Open study to each of those charts. You then overlay onto one of those charts, all of those instances of the Percent Change Since Open studies using this study: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Study Reference: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s325 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-12 14:52:51] |
GravisHTG - Posts: 306 |
why can we just do all of this in one chart ? With Add symbol study, you add all you need, then you add a Percentage Change since open on each of them, then you put all in the first region. that works right? |
[2021-08-12 15:13:00] |
John - SC Support - Posts: 38259 |
You can do it all in one chart, you will just have to figure out how you want to lay everything out with the different scales.
