Date/Time: Fri, 07 Feb 2025 13:18:34 +0000
CQG data with Interactive Brokers configuration.
View Count: 767
[2020-06-02 12:19:13] |
User691398 - Posts: 27 |
I am fairly new to SC, I need help configuring SC. I need to configure sierra chart to connect to CQG (using for data feed) to access Interactive brokers IB. I know how to configure SC using IB data feed. (at Data/Trade Service Settings, choose Interactive Brokers) it works fine even without IB data feed as long as I use sierra chart data feeds, with (Allow Support for Sierra Chart Data Feeds box is checked) but I need to use CQG data feed. Similar I choose at Data/Trade Service Settings CQGWebAPI, don't know how to connect IB connection. I know you would like me to use Denali data feed, but I need to use CQG. I am not asking you to support CQG nor IB all I am asking how to configure communication between CQG and IB. |
[2020-06-02 12:40:22] |
This was already answered in another thread that you posted.
