Date/Time: Fri, 07 Feb 2025 10:39:24 +0000
HKFE depth on SC data feed
View Count: 792
[2020-06-02 00:25:26] |
joshtrader - Posts: 500 |
With CQG I only get 10 levels of depth with HSI futures on the HKFE. Can someone confirm how many levels of depth the SC data feed has, for HSI futures?
[2020-06-02 05:21:34] |
It is 10 levels. It would have to be the same since Barchart, the vendor in this case, gets the data from CQG.
