Date/Time: Fri, 07 Feb 2025 12:40:41 +0000
[User Discussion] - convert volume into a negative number based on conditions
View Count: 659
[2020-06-01 18:45:13] |
User970210 - Posts: 99 |
Hi, I would like to convert volume into a negative number based on conditions (color bar background includes v>v[-1]) How? thx |
[2020-06-02 05:58:23] |
We need more information on exactly what you want to accomplish, as we do not understand "convert volume into a negative number". But, take a look at the Arithmetic Studies and see if it gives you what you want: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-02 07:00:20] |
Ackin - Posts: 1865 |
contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
