Date/Time: Fri, 07 Feb 2025 11:17:11 +0000
TT fix data feed
View Count: 765
[2020-06-01 17:37:10]
User198159 - Posts: 6
i just opened an account with the broker ironbeam and their FCM stage 5 trading. I would like to use sierra chart TT fix but they don't support it. They only support CQG. Is there no other way to connect TT fix with this broker? And if not, which broker would you recommend signing up with to use TT fix?
[2020-06-01 18:28:21]
We assume that you are referring to the Sierra Chart Order Routing Service With Data when you reference TT FIX. As such, refer to the section #2 of the Setup Instructions which gives a list of brokers that work with this solution:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Stage 5 does support the Sierra Chart Order Routing Service. You will be set up through the clearing firm Advantage with them.
Date Time Of Last Edit: 2020-06-01 18:29:07
