Date/Time: Fri, 07 Feb 2025 12:46:35 +0000
Adjust Horizontal Lines in increments that match price
View Count: 587
[2020-06-01 15:06:46] |
User772499 - Posts: 48 |
Is there a setting to allow me to do this? For example, move a horz line on an ES chart in increments of 0.25 Thanks! |
[2020-06-01 16:04:13] |
Yes. Refer to this Chart Setting: Chart Settings: Adjust Tool Values to Tick Size (Chart >> Chart Settings >> Chart Drawing menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-01 17:06:21] |
In my Chart Settings, I have the following: Price Display Format: 0.01 Tick Size: 0.25 Adjust Tool Values to Tick size is checked on But my lines are moving in increments of 0.01 |
[2020-06-02 05:49:16] |
Update to the latest version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
