Date/Time: Fri, 07 Feb 2025 13:20:07 +0000
Change from Rithmic
View Count: 551
[2020-06-01 13:18:54]
gmorgan111 - Posts: 121
I am in the process of changing my data from Rithmic to either Denali Exchange Data feed or the Sierra Chart Real Time Exchange Data feed. I assume both use the Sierra Chart Order Routing thru TT
I am unsure of which I should use and my broker is AGN.
Can you give me any help in which data service to use. I trade the ES, NQ, YM, 6E, Gc, Cl, and NG emini futures only
[2020-06-02 05:45:00]
Since you are only trading symbols from the CME Group, you would need the Denali Exchange Data Feed.
To get started with the Order Routing Service with Data, refer to the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
