Date/Time: Fri, 18 Sep 2026 09:29:05 +0000
Unable to Connect
View Count: 871
[2020-06-01 11:48:54]
gmorgan111 - Posts: 121
I am unable to connect to my Sierra Chart platform this morning and need help as to why
I have attached my log
Please let me know as soon as you can
ThanksReading Internal Order ID file. | 2020-06-01 06:03:34.596
Reading Trade Orders file. | 2020-06-01 06:03:34.656
Reading Trade Positions file. | 2020-06-01 06:03:34.656
Reading Account Balance file. | 2020-06-01 06:03:34.656
UDPListener (1396). Port 22904 | Listening on UDP port 22904. | 2020-06-01 06:03:34.667
Software version: 2086 64-bit | 2020-06-01 06:03:34.667
Primary Thread ID: 2952 | 2020-06-01 06:03:34.667
Usage end date: 2020-07-08 | 2020-06-01 06:03:34.667
Enabled for: Advanced Features 2. | 2020-06-01 06:03:34.667
Enabled for: Sierra Chart Historical Data Service. | 2020-06-01 06:03:34.667
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-01 06:03:34.667
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-01 06:03:34.667
Current selected Data/Trading service: Rithmic Trading | 2020-06-01 06:03:34.667
Custom symbol settings values: disabled | 2020-06-01 06:03:34.667
Chart Update Interval: 500 | 2020-06-01 06:03:34.667
Intraday Data Storage Time Unit: 0 | 2020-06-01 06:03:34.667
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-06-01 06:03:34.667
2020-06-01 06:03:34 Local computer time | 2020-06-01 06:03:34.667
2020-06-01 11:03:34 Local computer time in UTC | 2020-06-01 06:03:34.667
2020-06-01 06:03:34 Local computer time in SC Time Zone | 2020-06-01 06:03:34.667
2020-06-01 11:03:34 Server time in UTC | 2020-06-01 06:03:34.667
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-06-01 06:03:34.667
Program path: C:\SierraChart\ | 2020-06-01 06:03:34.667
Data Files path: C:\SierraChart\Data\ | 2020-06-01 06:03:34.667
OS Version Number: 10.0 | 2020-06-01 06:03:34.667
Locale Setting: C | 2020-06-01 06:03:34.667
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-06-01 06:03:34.668
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-06-01 06:03:34.668
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:03:34.706
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-01 06:03:34.843
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-01 06:03:34.843
Received 5 login tokens. | 2020-06-01 06:03:35.116
Symbol settings MD5 received. Request ID: 1. | 2020-06-01 06:03:35.393
Symbol settings are up-to-date for rithmic.trading. | 2020-06-01 06:03:35.393
Rithmic Trading | Port for executable: 51434 | 2020-06-01 06:03:40.352
Listening socket (1416). Port 51434 | Closed. | 2020-06-01 06:03:40.352
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:03:40.355
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51434. Current folder: C:\SierraChart\Rim | 2020-06-01 06:03:40.376
Rithmic Trading | Bridge process is running. | 2020-06-01 06:03:42.380
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51434 | 2020-06-01 06:03:42.380
DTC Client socket (1) | Creating socket. | 2020-06-01 06:03:42.380
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:03:42.380
Rithmic Trading | Connected to server. | 2020-06-01 06:03:42.383
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:03:42.383
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:03:42.383
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:03:42.385
Rithmic Trading | Sending logon request message. | 2020-06-01 06:03:42.385
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:03:42.387
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:03:42.390
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:03:42.390
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:03:42.786
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:03:42.970
Rithmic Trading | Received logon response. | 2020-06-01 06:03:42.970
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:03:42.970
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:03:42.971
Rithmic Trading | Logon error received from server | 2020-06-01 06:03:42.971
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:03:42.971
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:42.971
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:03:42.996
Rithmic Trading | Disconnected. | 2020-06-01 06:03:42.996
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:42.996
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:03:42.996
Rithmic Trading | Port for executable: 51450 | 2020-06-01 06:03:44.993
Listening socket (1068). Port 51450 | Closed. | 2020-06-01 06:03:44.993
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:03:44.995
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51450. Current folder: C:\SierraChart\Rim | 2020-06-01 06:03:45.016
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:03:45.421
DTC Client socket (1) | Closed. | 2020-06-01 06:03:45.421
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:03:47.022
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51450 | 2020-06-01 06:03:47.022
DTC Client socket (1) | Creating socket. | 2020-06-01 06:03:47.022
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:03:47.022
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:03:49.054 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:03:49.055
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:03:49.055
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:49.055
DTC Client socket (1) | Closed. | 2020-06-01 06:03:49.055
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:03:49.069
Rithmic Trading | Disconnected. | 2020-06-01 06:03:49.069
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:49.069
Rithmic Trading | Port for executable: 51454 | 2020-06-01 06:03:51.083
Listening socket (992). Port 51454 | Closed. | 2020-06-01 06:03:51.083
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:03:51.086
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51454. Current folder: C:\SierraChart\Rim | 2020-06-01 06:03:51.107
Rithmic Trading | Bridge process is running. | 2020-06-01 06:03:53.092
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51454 | 2020-06-01 06:03:53.092
DTC Client socket (1) | Creating socket. | 2020-06-01 06:03:53.092
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:03:53.093
Rithmic Trading | Connected to server. | 2020-06-01 06:03:53.095
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:03:53.095
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:03:53.096
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:03:53.097
Rithmic Trading | Sending logon request message. | 2020-06-01 06:03:53.097
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:03:53.100
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:03:53.102
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:03:53.102
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:03:53.469
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:03:53.641
Rithmic Trading | Received logon response. | 2020-06-01 06:03:53.641
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:03:53.641
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:03:53.642
Rithmic Trading | Logon error received from server | 2020-06-01 06:03:53.642
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:03:53.642
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:53.642
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:03:53.660
Rithmic Trading | Disconnected. | 2020-06-01 06:03:53.660
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:53.660
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:03:53.660
Rithmic Trading | Port for executable: 51468 | 2020-06-01 06:03:55.678
Listening socket (1428). Port 51468 | Closed. | 2020-06-01 06:03:55.678
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:03:55.680
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51468. Current folder: C:\SierraChart\Rim | 2020-06-01 06:03:55.695
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:03:56.161
DTC Client socket (1) | Closed. | 2020-06-01 06:03:56.161
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:03:57.691
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51468 | 2020-06-01 06:03:57.691
DTC Client socket (1) | Creating socket. | 2020-06-01 06:03:57.691
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:03:57.691
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:03:59.723 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:03:59.723
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:03:59.723
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:59.723
DTC Client socket (1) | Closed. | 2020-06-01 06:03:59.723
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:03:59.738
Rithmic Trading | Disconnected. | 2020-06-01 06:03:59.738
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:03:59.738
Rithmic Trading | Port for executable: 51470 | 2020-06-01 06:04:01.740
Listening socket (992). Port 51470 | Closed. | 2020-06-01 06:04:01.740
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:01.741
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51470. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:01.756
Rithmic Trading | Bridge process is running. | 2020-06-01 06:04:03.755
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51470 | 2020-06-01 06:04:03.755
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:03.755
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:03.755
Rithmic Trading | Connected to server. | 2020-06-01 06:04:03.759
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:04:03.759
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:04:03.759
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:04:03.760
Rithmic Trading | Sending logon request message. | 2020-06-01 06:04:03.760
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:04:03.761
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:04:03.762
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:04:03.762
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:04:04.115
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:04:04.283
Rithmic Trading | Received logon response. | 2020-06-01 06:04:04.283
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:04:04.283
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:04:04.283
Rithmic Trading | Logon error received from server | 2020-06-01 06:04:04.283
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:04.283
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:04.283
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:04.286
Rithmic Trading | Disconnected. | 2020-06-01 06:04:04.286
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:04.286
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:04:04.286
Rithmic Trading | Port for executable: 51484 | 2020-06-01 06:04:06.292
Listening socket (1464). Port 51484 | Closed. | 2020-06-01 06:04:06.292
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:06.294
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51484. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:06.316
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:04:06.790
DTC Client socket (1) | Closed. | 2020-06-01 06:04:06.790
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:04:08.319
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51484 | 2020-06-01 06:04:08.319
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:08.319
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:08.319
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:04:10.366 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:10.366
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:10.367
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:10.367
DTC Client socket (1) | Closed. | 2020-06-01 06:04:10.367
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:04:10.382
Rithmic Trading | Disconnected. | 2020-06-01 06:04:10.382
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:10.382
Rithmic Trading | Port for executable: 51486 | 2020-06-01 06:04:12.402
Listening socket (992). Port 51486 | Closed. | 2020-06-01 06:04:12.402
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:12.405
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51486. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:12.421
Rithmic Trading | Bridge process is running. | 2020-06-01 06:04:14.414
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51486 | 2020-06-01 06:04:14.414
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:14.414
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:14.414
Rithmic Trading | Connected to server. | 2020-06-01 06:04:14.417
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:04:14.417
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:04:14.417
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:04:14.419
Rithmic Trading | Sending logon request message. | 2020-06-01 06:04:14.419
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:04:14.421
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:04:14.424
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:04:14.424
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:04:14.774
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:04:14.958
Rithmic Trading | Received logon response. | 2020-06-01 06:04:14.958
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:04:14.958
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:04:14.958
Rithmic Trading | Logon error received from server | 2020-06-01 06:04:14.958
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:14.958
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:14.958
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:14.961
Rithmic Trading | Disconnected. | 2020-06-01 06:04:14.961
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:04:14.961
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:14.961
Rithmic Trading | Port for executable: 51512 | 2020-06-01 06:04:16.981
Listening socket (1272). Port 51512 | Closed. | 2020-06-01 06:04:16.981
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:16.982
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51512. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:16.997
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:04:17.480
DTC Client socket (1) | Closed. | 2020-06-01 06:04:17.480
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:04:19.009
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51512 | 2020-06-01 06:04:19.009
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:19.009
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:19.009
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:04:21.057 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:21.057
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:21.057
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:21.057
DTC Client socket (1) | Closed. | 2020-06-01 06:04:21.057
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:04:21.072
Rithmic Trading | Disconnected. | 2020-06-01 06:04:21.072
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:21.072
Rithmic Trading | Port for executable: 51519 | 2020-06-01 06:04:23.077
Listening socket (1484). Port 51519 | Closed. | 2020-06-01 06:04:23.077
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:23.080
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51519. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:23.101
Rithmic Trading | Bridge process is running. | 2020-06-01 06:04:25.089
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51519 | 2020-06-01 06:04:25.089
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:25.089
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:25.089
Rithmic Trading | Connected to server. | 2020-06-01 06:04:25.092
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:04:25.092
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:04:25.092
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:04:25.094
Rithmic Trading | Sending logon request message. | 2020-06-01 06:04:25.094
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:04:25.096
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:04:25.099
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:04:25.099
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:04:25.470
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:04:25.663
Rithmic Trading | Received logon response. | 2020-06-01 06:04:25.663
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:04:25.663
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:04:25.663
Rithmic Trading | Logon error received from server | 2020-06-01 06:04:25.663
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:25.663
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:25.663
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:25.667
Rithmic Trading | Disconnected. | 2020-06-01 06:04:25.667
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:25.667
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:04:25.667
Rithmic Trading | Port for executable: 51539 | 2020-06-01 06:04:27.696
Listening socket (1440). Port 51539 | Closed. | 2020-06-01 06:04:27.696
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:27.699
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51539. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:27.719
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:04:28.148
DTC Client socket (1) | Closed. | 2020-06-01 06:04:28.148
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:04:29.707
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51539 | 2020-06-01 06:04:29.707
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:29.707
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:29.707
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:04:31.755 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:31.755
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:31.755
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:31.755
DTC Client socket (1) | Closed. | 2020-06-01 06:04:31.755
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:04:31.770
Rithmic Trading | Disconnected. | 2020-06-01 06:04:31.770
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:31.770
Rithmic Trading | Port for executable: 51541 | 2020-06-01 06:04:33.773
Listening socket (1448). Port 51541 | Closed. | 2020-06-01 06:04:33.773
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:33.775
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51541. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:33.796
Rithmic Trading | Bridge process is running. | 2020-06-01 06:04:35.786
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51541 | 2020-06-01 06:04:35.787
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:35.787
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:35.787
Rithmic Trading | Connected to server. | 2020-06-01 06:04:35.790
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:04:35.790
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:04:35.790
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:04:35.792
Rithmic Trading | Sending logon request message. | 2020-06-01 06:04:35.792
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:04:35.794
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:04:35.797
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:04:35.797
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:04:36.176
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:04:36.354
Rithmic Trading | Received logon response. | 2020-06-01 06:04:36.354
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:04:36.354
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:04:36.354
Rithmic Trading | Logon error received from server | 2020-06-01 06:04:36.354
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:36.354
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:36.354
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:36.365
Rithmic Trading | Disconnected. | 2020-06-01 06:04:36.365
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:36.365
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:04:36.365
Rithmic Trading | Port for executable: 51556 | 2020-06-01 06:04:38.386
Listening socket (1068). Port 51556 | Closed. | 2020-06-01 06:04:38.386
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:38.389
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51556. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:38.406
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:04:38.838
DTC Client socket (1) | Closed. | 2020-06-01 06:04:38.838
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:04:40.413
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51556 | 2020-06-01 06:04:40.413
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:40.413
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:40.413
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:04:42.445 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:42.445
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:42.445
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:42.445
DTC Client socket (1) | Closed. | 2020-06-01 06:04:42.445
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:04:42.460
Rithmic Trading | Disconnected. | 2020-06-01 06:04:42.460
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:42.460
Rithmic Trading | Port for executable: 51558 | 2020-06-01 06:04:44.481
Listening socket (904). Port 51558 | Closed. | 2020-06-01 06:04:44.481
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:44.483
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51558. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:44.505
Rithmic Trading | Bridge process is running. | 2020-06-01 06:04:46.494
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51558 | 2020-06-01 06:04:46.494
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:46.495
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:46.495
Rithmic Trading | Connected to server. | 2020-06-01 06:04:46.498
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:04:46.498
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:04:46.498
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:04:46.500
Rithmic Trading | Sending logon request message. | 2020-06-01 06:04:46.500
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:04:46.502
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:04:46.505
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:04:46.505
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:04:46.853
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:04:47.027
Rithmic Trading | Received logon response. | 2020-06-01 06:04:47.028
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:04:47.028
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:04:47.028
Rithmic Trading | Logon error received from server | 2020-06-01 06:04:47.028
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:47.028
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:47.028
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:47.042
Rithmic Trading | Disconnected. | 2020-06-01 06:04:47.042
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:47.042
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:04:47.042
Rithmic Trading | Port for executable: 51574 | 2020-06-01 06:04:49.046
Listening socket (1488). Port 51574 | Closed. | 2020-06-01 06:04:49.046
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:49.049
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51574. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:49.090
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:04:49.562
DTC Client socket (1) | Closed. | 2020-06-01 06:04:49.562
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:04:51.104
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51574 | 2020-06-01 06:04:51.104
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:51.105
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:51.105
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:04:53.152 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:53.152
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:53.153
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:53.153
DTC Client socket (1) | Closed. | 2020-06-01 06:04:53.153
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:04:53.168
Rithmic Trading | Disconnected. | 2020-06-01 06:04:53.168
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:53.168
Rithmic Trading | Port for executable: 51576 | 2020-06-01 06:04:55.173
Listening socket (904). Port 51576 | Closed. | 2020-06-01 06:04:55.173
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:55.176
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51576. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:55.198
Rithmic Trading | Bridge process is running. | 2020-06-01 06:04:57.184
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51576 | 2020-06-01 06:04:57.184
DTC Client socket (1) | Creating socket. | 2020-06-01 06:04:57.184
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:04:57.185
Rithmic Trading | Connected to server. | 2020-06-01 06:04:57.187
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:04:57.187
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:04:57.187
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:04:57.190
Rithmic Trading | Sending logon request message. | 2020-06-01 06:04:57.190
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:04:57.192
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:04:57.194
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:04:57.195
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:04:57.559
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:04:57.742
Rithmic Trading | Received logon response. | 2020-06-01 06:04:57.743
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:04:57.743
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:04:57.743
Rithmic Trading | Logon error received from server | 2020-06-01 06:04:57.743
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:04:57.743
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:57.743
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:04:57.747
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:04:57.747
Rithmic Trading | Disconnected. | 2020-06-01 06:04:57.747
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:04:57.747
Rithmic Trading | Port for executable: 51592 | 2020-06-01 06:04:59.752
Listening socket (1008). Port 51592 | Closed. | 2020-06-01 06:04:59.752
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:04:59.754
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51592. Current folder: C:\SierraChart\Rim | 2020-06-01 06:04:59.770
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:05:00.240
DTC Client socket (1) | Closed. | 2020-06-01 06:05:00.240
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:05:01.779
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51592 | 2020-06-01 06:05:01.779
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:01.779
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:01.779
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:05:03.826 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:03.826
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:03.826
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:03.826
DTC Client socket (1) | Closed. | 2020-06-01 06:05:03.826
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:05:03.842
Rithmic Trading | Disconnected. | 2020-06-01 06:05:03.842
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:03.842
Rithmic Trading | Port for executable: 51594 | 2020-06-01 06:05:05.860
Listening socket (1468). Port 51594 | Closed. | 2020-06-01 06:05:05.860
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:05.862
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51594. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:05.884
Rithmic Trading | Bridge process is running. | 2020-06-01 06:05:07.874
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51594 | 2020-06-01 06:05:07.874
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:07.874
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:07.874
Rithmic Trading | Connected to server. | 2020-06-01 06:05:07.877
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:05:07.877
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:05:07.877
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:05:07.879
Rithmic Trading | Sending logon request message. | 2020-06-01 06:05:07.879
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:05:07.881
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:05:07.884
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:05:07.884
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:05:08.251
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:05:08.423
Rithmic Trading | Received logon response. | 2020-06-01 06:05:08.423
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:05:08.423
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:05:08.423
Rithmic Trading | Logon error received from server | 2020-06-01 06:05:08.423
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:08.423
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:08.423
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:08.437
Rithmic Trading | Disconnected. | 2020-06-01 06:05:08.437
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:08.437
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:05:08.437
Rithmic Trading | Port for executable: 51609 | 2020-06-01 06:05:10.441
Listening socket (1500). Port 51609 | Closed. | 2020-06-01 06:05:10.441
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:10.444
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51609. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:10.466
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:05:10.915
DTC Client socket (1) | Closed. | 2020-06-01 06:05:10.915
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:05:12.443
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51609 | 2020-06-01 06:05:12.443
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:12.444
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:12.444
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:05:14.486 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:14.486
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:14.486
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:14.486
DTC Client socket (1) | Closed. | 2020-06-01 06:05:14.486
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:05:14.502
Rithmic Trading | Disconnected. | 2020-06-01 06:05:14.502
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:14.502
Rithmic Trading | Port for executable: 51625 | 2020-06-01 06:05:16.523
Listening socket (1448). Port 51625 | Closed. | 2020-06-01 06:05:16.523
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:16.525
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51625. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:16.541
Rithmic Trading | Bridge process is running. | 2020-06-01 06:05:18.549
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51625 | 2020-06-01 06:05:18.549
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:18.550
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:18.550
Rithmic Trading | Connected to server. | 2020-06-01 06:05:18.552
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:05:18.552
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:05:18.553
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:05:18.555
Rithmic Trading | Sending logon request message. | 2020-06-01 06:05:18.555
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:05:18.558
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:05:18.560
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:05:18.560
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:05:18.930
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:05:19.101
Rithmic Trading | Received logon response. | 2020-06-01 06:05:19.101
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:05:19.101
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:05:19.101
Rithmic Trading | Logon error received from server | 2020-06-01 06:05:19.101
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:19.101
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:19.101
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:19.112
Rithmic Trading | Disconnected. | 2020-06-01 06:05:19.112
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:19.112
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:05:19.112
Rithmic Trading | Port for executable: 51640 | 2020-06-01 06:05:21.130
Listening socket (1504). Port 51640 | Closed. | 2020-06-01 06:05:21.130
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:21.132
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51640. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:21.147
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:05:21.599
DTC Client socket (1) | Closed. | 2020-06-01 06:05:21.599
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:05:23.148
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51640 | 2020-06-01 06:05:23.148
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:23.148
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:23.148
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:05:25.165 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:25.165
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:25.165
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:25.165
DTC Client socket (1) | Closed. | 2020-06-01 06:05:25.165
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:05:25.180
Rithmic Trading | Disconnected. | 2020-06-01 06:05:25.180
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:25.180
Rithmic Trading | Port for executable: 51647 | 2020-06-01 06:05:27.197
Listening socket (1008). Port 51647 | Closed. | 2020-06-01 06:05:27.197
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:27.198
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51647. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:27.213
Rithmic Trading | Bridge process is running. | 2020-06-01 06:05:29.228
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51647 | 2020-06-01 06:05:29.228
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:29.228
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:29.228
Rithmic Trading | Connected to server. | 2020-06-01 06:05:29.231
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:05:29.231
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:05:29.231
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:05:29.233
Rithmic Trading | Sending logon request message. | 2020-06-01 06:05:29.233
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:05:29.235
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:05:29.238
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:05:29.238
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:05:29.641
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:05:29.822
Rithmic Trading | Received logon response. | 2020-06-01 06:05:29.822
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:05:29.822
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:05:29.822
Rithmic Trading | Logon error received from server | 2020-06-01 06:05:29.822
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:29.822
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:29.822
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:29.837
Rithmic Trading | Disconnected. | 2020-06-01 06:05:29.837
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:29.837
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:05:29.837
Rithmic Trading | Port for executable: 51664 | 2020-06-01 06:05:31.858
Listening socket (1508). Port 51664 | Closed. | 2020-06-01 06:05:31.858
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:31.861
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51664. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:31.877
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:05:32.268 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:05:32.268
DTC Client socket (1) | Closed. | 2020-06-01 06:05:32.268
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:05:33.892
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51664 | 2020-06-01 06:05:33.892
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:33.892
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:33.892
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:05:35.939 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:35.939
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:35.940
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:35.940
DTC Client socket (1) | Closed. | 2020-06-01 06:05:35.940
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:05:35.955
Rithmic Trading | Disconnected. | 2020-06-01 06:05:35.955
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:35.956
Rithmic Trading | Port for executable: 51681 | 2020-06-01 06:05:37.961
Listening socket (1496). Port 51681 | Closed. | 2020-06-01 06:05:37.961
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:37.963
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51681. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:37.980
Rithmic Trading | Bridge process is running. | 2020-06-01 06:05:39.986
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51681 | 2020-06-01 06:05:39.986
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:39.987
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:39.987
Rithmic Trading | Connected to server. | 2020-06-01 06:05:39.989
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:05:39.989
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:05:39.990
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:05:39.992
Rithmic Trading | Sending logon request message. | 2020-06-01 06:05:39.992
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:05:39.994
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:05:39.997
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:05:39.997
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:05:40.363
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:05:40.553
Rithmic Trading | Received logon response. | 2020-06-01 06:05:40.553
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:05:40.553
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:05:40.553
Rithmic Trading | Logon error received from server | 2020-06-01 06:05:40.553
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:40.553
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:40.553
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:40.565
Rithmic Trading | Disconnected. | 2020-06-01 06:05:40.565
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:40.565
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:05:40.565
Rithmic Trading | Port for executable: 51696 | 2020-06-01 06:05:42.570
Listening socket (1500). Port 51696 | Closed. | 2020-06-01 06:05:42.570
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:42.573
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51696. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:42.589
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:05:43.039
DTC Client socket (1) | Closed. | 2020-06-01 06:05:43.039
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:05:44.581
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51696 | 2020-06-01 06:05:44.581
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:44.582
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:44.582
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:05:46.613 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:46.614
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:46.614
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:46.614
DTC Client socket (1) | Closed. | 2020-06-01 06:05:46.614
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:05:46.629
Rithmic Trading | Disconnected. | 2020-06-01 06:05:46.629
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:46.629
Rithmic Trading | Port for executable: 51698 | 2020-06-01 06:05:48.647
Listening socket (1480). Port 51698 | Closed. | 2020-06-01 06:05:48.647
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:48.648
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51698. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:48.663
Rithmic Trading | Bridge process is running. | 2020-06-01 06:05:50.676
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51698 | 2020-06-01 06:05:50.676
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:50.677
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:50.677
Rithmic Trading | Connected to server. | 2020-06-01 06:05:50.680
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:05:50.680
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:05:50.680
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:05:50.681
Rithmic Trading | Sending logon request message. | 2020-06-01 06:05:50.681
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:05:50.684
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:05:50.687
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:05:50.687
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:05:51.053
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:05:51.229
Rithmic Trading | Received logon response. | 2020-06-01 06:05:51.229
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:05:51.229
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:05:51.229
Rithmic Trading | Logon error received from server | 2020-06-01 06:05:51.229
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:51.229
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:51.229
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:51.239
Rithmic Trading | Disconnected. | 2020-06-01 06:05:51.239
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:51.239
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:05:51.240
Rithmic Trading | Port for executable: 51714 | 2020-06-01 06:05:53.243
Listening socket (1468). Port 51714 | Closed. | 2020-06-01 06:05:53.243
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:53.244
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51714. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:53.261
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:05:53.725 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:05:53.725
DTC Client socket (1) | Closed. | 2020-06-01 06:05:53.725
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:05:55.271
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51714 | 2020-06-01 06:05:55.272
DTC Client socket (1) | Creating socket. | 2020-06-01 06:05:55.272
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:05:55.272
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:05:57.282 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:05:57.283
DTC Client socket (1) | Closed. | 2020-06-01 06:05:57.283
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:05:57.283
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:57.283
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:05:57.294
Rithmic Trading | Disconnected. | 2020-06-01 06:05:57.294
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:05:57.294
Rithmic Trading | Port for executable: 51754 | 2020-06-01 06:05:59.301
Listening socket (1512). Port 51754 | Closed. | 2020-06-01 06:05:59.301
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:05:59.301
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51754. Current folder: C:\SierraChart\Rim | 2020-06-01 06:05:59.318
Rithmic Trading | Bridge process is running. | 2020-06-01 06:06:01.318
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51754 | 2020-06-01 06:06:01.318
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:01.318
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:01.318
Rithmic Trading | Connected to server. | 2020-06-01 06:06:01.319
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:06:01.319
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:06:01.319
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:06:01.320
Rithmic Trading | Sending logon request message. | 2020-06-01 06:06:01.320
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:06:01.320
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:06:01.321
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:06:01.321
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:06:01.678
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:06:01.855
Rithmic Trading | Received logon response. | 2020-06-01 06:06:01.855
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:06:01.855
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:06:01.855
Rithmic Trading | Logon error received from server | 2020-06-01 06:06:01.855
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:01.855
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:01.855
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:01.864
Rithmic Trading | Disconnected. | 2020-06-01 06:06:01.864
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:01.865
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:06:01.865
Rithmic Trading | Port for executable: 51782 | 2020-06-01 06:06:03.869
Listening socket (1376). Port 51782 | Closed. | 2020-06-01 06:06:03.869
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:03.871
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51782. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:03.886
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:06:04.355 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:06:04.355
DTC Client socket (1) | Closed. | 2020-06-01 06:06:04.355
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:06:05.890
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51782 | 2020-06-01 06:06:05.890
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:05.890
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:05.890
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:06:07.893 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:07.894
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:07.894
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:07.894
DTC Client socket (1) | Closed. | 2020-06-01 06:06:07.894
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:06:07.903
Rithmic Trading | Disconnected. | 2020-06-01 06:06:07.903
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:07.904
Rithmic Trading | Port for executable: 51819 | 2020-06-01 06:06:09.906
Listening socket (904). Port 51819 | Closed. | 2020-06-01 06:06:09.906
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:09.906
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51819. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:09.922
Rithmic Trading | Bridge process is running. | 2020-06-01 06:06:11.912
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51819 | 2020-06-01 06:06:11.912
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:11.912
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:11.912
Rithmic Trading | Connected to server. | 2020-06-01 06:06:11.913
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:06:11.913
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:06:11.913
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:06:11.914
Rithmic Trading | Sending logon request message. | 2020-06-01 06:06:11.914
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:06:11.914
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:06:11.915
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:06:11.915
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:06:12.280
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:06:12.449
Rithmic Trading | Received logon response. | 2020-06-01 06:06:12.449
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:06:12.449
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:06:12.449
Rithmic Trading | Logon error received from server | 2020-06-01 06:06:12.449
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:12.449
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:12.449
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:12.464
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:06:12.464
Rithmic Trading | Disconnected. | 2020-06-01 06:06:12.464
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:12.464
Rithmic Trading | Port for executable: 51840 | 2020-06-01 06:06:14.468
Listening socket (904). Port 51840 | Closed. | 2020-06-01 06:06:14.468
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:14.470
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51840. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:14.486
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:06:14.977
DTC Client socket (1) | Closed. | 2020-06-01 06:06:14.977
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:06:16.477
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51840 | 2020-06-01 06:06:16.477
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:16.477
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:16.477
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:06:18.514 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:18.514
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:18.514
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:18.514
DTC Client socket (1) | Closed. | 2020-06-01 06:06:18.514
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:06:18.529
Rithmic Trading | Disconnected. | 2020-06-01 06:06:18.529
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:18.529
Rithmic Trading | Port for executable: 51847 | 2020-06-01 06:06:20.532
Listening socket (904). Port 51847 | Closed. | 2020-06-01 06:06:20.532
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:20.534
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51847. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:20.555
Rithmic Trading | Bridge process is running. | 2020-06-01 06:06:22.538
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51847 | 2020-06-01 06:06:22.538
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:22.539
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:22.539
Rithmic Trading | Connected to server. | 2020-06-01 06:06:22.539
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:06:22.539
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:06:22.539
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:06:22.540
Rithmic Trading | Sending logon request message. | 2020-06-01 06:06:22.540
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:06:22.540
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:06:22.541
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:06:22.541
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:06:22.900
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:06:23.072
Rithmic Trading | Received logon response. | 2020-06-01 06:06:23.072
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:06:23.072
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:06:23.072
Rithmic Trading | Logon error received from server | 2020-06-01 06:06:23.072
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:23.072
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:23.072
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:23.081
Rithmic Trading | Disconnected. | 2020-06-01 06:06:23.081
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:23.081
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:06:23.081
Rithmic Trading | Port for executable: 51861 | 2020-06-01 06:06:25.085
Listening socket (1524). Port 51861 | Closed. | 2020-06-01 06:06:25.085
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:25.085
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51861. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:25.101
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:06:25.619
DTC Client socket (1) | Closed. | 2020-06-01 06:06:25.619
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:06:27.093
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51861 | 2020-06-01 06:06:27.093
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:27.093
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:27.093
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:06:29.140 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:29.141
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:29.141
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:29.141
DTC Client socket (1) | Closed. | 2020-06-01 06:06:29.141
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:06:29.156
Rithmic Trading | Disconnected. | 2020-06-01 06:06:29.156
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:29.156
Rithmic Trading | Port for executable: 51867 | 2020-06-01 06:06:31.149
Listening socket (1488). Port 51867 | Closed. | 2020-06-01 06:06:31.149
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:31.150
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51867. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:31.166
Rithmic Trading | Bridge process is running. | 2020-06-01 06:06:33.169
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51867 | 2020-06-01 06:06:33.169
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:33.169
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:33.170
Rithmic Trading | Connected to server. | 2020-06-01 06:06:33.173
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:06:33.173
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:06:33.173
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:06:33.174
Rithmic Trading | Sending logon request message. | 2020-06-01 06:06:33.174
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:06:33.176
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:06:33.180
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:06:33.180
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:06:33.543
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:06:33.725
Rithmic Trading | Received logon response. | 2020-06-01 06:06:33.725
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:06:33.725
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:06:33.725
Rithmic Trading | Logon error received from server | 2020-06-01 06:06:33.725
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:33.725
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:33.725
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:33.732
Rithmic Trading | Disconnected. | 2020-06-01 06:06:33.732
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:33.732
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:06:33.732
Rithmic Trading | Port for executable: 51884 | 2020-06-01 06:06:35.737
Listening socket (1484). Port 51884 | Closed. | 2020-06-01 06:06:35.737
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:35.740
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51884. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:35.755
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:06:36.221
DTC Client socket (1) | Closed. | 2020-06-01 06:06:36.221
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:06:37.748
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51884 | 2020-06-01 06:06:37.748
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:37.748
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:37.749
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:06:39.796 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:39.796
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:39.796
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:39.796
DTC Client socket (1) | Closed. | 2020-06-01 06:06:39.796
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:06:39.811
Rithmic Trading | Disconnected. | 2020-06-01 06:06:39.812
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:39.812
Rithmic Trading | Port for executable: 51886 | 2020-06-01 06:06:41.816
Listening socket (1512). Port 51886 | Closed. | 2020-06-01 06:06:41.817
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:41.818
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51886. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:41.835
Rithmic Trading | Bridge process is running. | 2020-06-01 06:06:43.828
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51886 | 2020-06-01 06:06:43.828
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:43.828
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:43.828
Rithmic Trading | Connected to server. | 2020-06-01 06:06:43.831
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:06:43.831
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:06:43.831
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:06:43.833
Rithmic Trading | Sending logon request message. | 2020-06-01 06:06:43.833
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:06:43.835
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:06:43.838
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:06:43.838
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:06:44.220
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:06:44.386
Rithmic Trading | Received logon response. | 2020-06-01 06:06:44.386
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:06:44.387
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:06:44.387
Rithmic Trading | Logon error received from server | 2020-06-01 06:06:44.387
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:44.387
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:44.387
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:44.390
Rithmic Trading | Disconnected. | 2020-06-01 06:06:44.390
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:44.391
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:06:44.391
Rithmic Trading | Port for executable: 51902 | 2020-06-01 06:06:46.396
Listening socket (1536). Port 51902 | Closed. | 2020-06-01 06:06:46.396
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:46.399
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51902. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:46.419
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:06:46.892
DTC Client socket (1) | Closed. | 2020-06-01 06:06:46.892
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:06:48.407
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51902 | 2020-06-01 06:06:48.407
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:48.407
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:48.407
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:06:50.454 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:50.455
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:50.455
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:50.455
DTC Client socket (1) | Closed. | 2020-06-01 06:06:50.455
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:06:50.470
Rithmic Trading | Disconnected. | 2020-06-01 06:06:50.470
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:50.470
Rithmic Trading | Port for executable: 51904 | 2020-06-01 06:06:52.475
Listening socket (1512). Port 51904 | Closed. | 2020-06-01 06:06:52.475
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:52.478
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51904. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:52.499
Rithmic Trading | Bridge process is running. | 2020-06-01 06:06:54.486
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51904 | 2020-06-01 06:06:54.486
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:54.487
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:54.487
Rithmic Trading | Connected to server. | 2020-06-01 06:06:54.490
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:06:54.490
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:06:54.490
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:06:54.492
Rithmic Trading | Sending logon request message. | 2020-06-01 06:06:54.492
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:06:54.494
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:06:54.496
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:06:54.496
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:06:54.860
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:06:55.034
Rithmic Trading | Received logon response. | 2020-06-01 06:06:55.034
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:06:55.034
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:06:55.034
Rithmic Trading | Logon error received from server | 2020-06-01 06:06:55.034
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:06:55.034
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:55.034
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:06:55.049
Rithmic Trading | Disconnected. | 2020-06-01 06:06:55.049
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:06:55.049
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:06:55.049
Rithmic Trading | Port for executable: 51918 | 2020-06-01 06:06:57.054
Listening socket (1468). Port 51918 | Closed. | 2020-06-01 06:06:57.054
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:06:57.057
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51918. Current folder: C:\SierraChart\Rim | 2020-06-01 06:06:57.078
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:06:57.554
DTC Client socket (1) | Closed. | 2020-06-01 06:06:57.555
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:06:59.065
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51918 | 2020-06-01 06:06:59.065
DTC Client socket (1) | Creating socket. | 2020-06-01 06:06:59.065
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:06:59.066
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:07:01.097 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:01.097
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:01.097
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:01.097
DTC Client socket (1) | Closed. | 2020-06-01 06:07:01.097
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:07:01.112
Rithmic Trading | Disconnected. | 2020-06-01 06:07:01.112
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:01.112
Rithmic Trading | Port for executable: 51920 | 2020-06-01 06:07:03.115
Listening socket (1524). Port 51920 | Closed. | 2020-06-01 06:07:03.115
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:03.116
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51920. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:03.132
Rithmic Trading | Bridge process is running. | 2020-06-01 06:07:05.129
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51920 | 2020-06-01 06:07:05.129
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:05.129
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:05.129
Rithmic Trading | Connected to server. | 2020-06-01 06:07:05.130
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:07:05.130
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:07:05.130
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:07:05.131
Rithmic Trading | Sending logon request message. | 2020-06-01 06:07:05.131
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:07:05.132
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:07:05.133
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:07:05.133
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:07:05.511
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:07:05.677
Rithmic Trading | Received logon response. | 2020-06-01 06:07:05.677
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:07:05.677
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:07:05.677
Rithmic Trading | Logon error received from server | 2020-06-01 06:07:05.677
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:05.677
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:05.677
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:05.692
Rithmic Trading | Disconnected. | 2020-06-01 06:07:05.692
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:05.692
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:07:05.692
Rithmic Trading | Port for executable: 51934 | 2020-06-01 06:07:07.697
Listening socket (1532). Port 51934 | Closed. | 2020-06-01 06:07:07.697
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:07.700
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51934. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:07.721
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:07:08.180 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:07:08.180
DTC Client socket (1) | Closed. | 2020-06-01 06:07:08.180
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:07:09.693
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51934 | 2020-06-01 06:07:09.693
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:09.693
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:09.693
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:07:11.724 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:11.725
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:11.725
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:11.725
DTC Client socket (1) | Closed. | 2020-06-01 06:07:11.725
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:07:11.740
Rithmic Trading | Disconnected. | 2020-06-01 06:07:11.740
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:11.740
Rithmic Trading | Port for executable: 51946 | 2020-06-01 06:07:13.742
Listening socket (1016). Port 51946 | Closed. | 2020-06-01 06:07:13.742
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:13.742
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51946. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:13.758
Rithmic Trading | Bridge process is running. | 2020-06-01 06:07:15.765
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51946 | 2020-06-01 06:07:15.765
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:15.765
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:15.765
Rithmic Trading | Connected to server. | 2020-06-01 06:07:15.766
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:07:15.766
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:07:15.766
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:07:15.766
Rithmic Trading | Sending logon request message. | 2020-06-01 06:07:15.766
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:07:15.767
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:07:15.769
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:07:15.769
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:07:16.143
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:07:16.320
Rithmic Trading | Received logon response. | 2020-06-01 06:07:16.320
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:07:16.320
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:07:16.320
Rithmic Trading | Logon error received from server | 2020-06-01 06:07:16.320
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:16.320
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:16.320
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:16.328
Rithmic Trading | Disconnected. | 2020-06-01 06:07:16.328
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:16.328
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:07:16.328
Rithmic Trading | Port for executable: 51966 | 2020-06-01 06:07:18.332
Listening socket (1544). Port 51966 | Closed. | 2020-06-01 06:07:18.332
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:18.334
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51966. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:18.350
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:07:18.814
DTC Client socket (1) | Closed. | 2020-06-01 06:07:18.814
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:07:20.344
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51966 | 2020-06-01 06:07:20.344
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:20.344
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:20.344
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:07:22.376 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:22.377
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:22.377
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:22.377
DTC Client socket (1) | Closed. | 2020-06-01 06:07:22.377
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:07:22.392
Rithmic Trading | Disconnected. | 2020-06-01 06:07:22.392
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:22.392
Rithmic Trading | Port for executable: 51973 | 2020-06-01 06:07:24.397
Listening socket (1524). Port 51973 | Closed. | 2020-06-01 06:07:24.398
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:24.400
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51973. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:24.421
Rithmic Trading | Bridge process is running. | 2020-06-01 06:07:26.409
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51973 | 2020-06-01 06:07:26.409
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:26.409
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:26.409
Rithmic Trading | Connected to server. | 2020-06-01 06:07:26.412
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:07:26.412
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:07:26.412
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:07:26.414
Rithmic Trading | Sending logon request message. | 2020-06-01 06:07:26.414
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:07:26.417
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:07:26.419
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:07:26.419
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:07:26.819
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:07:26.999
Rithmic Trading | Received logon response. | 2020-06-01 06:07:27.000
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:07:27.000
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:07:27.000
Rithmic Trading | Logon error received from server | 2020-06-01 06:07:27.000
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:27.000
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:27.000
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:27.003
Rithmic Trading | Disconnected. | 2020-06-01 06:07:27.003
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:27.003
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:07:27.003
Rithmic Trading | Port for executable: 51988 | 2020-06-01 06:07:29.006
Listening socket (1520). Port 51988 | Closed. | 2020-06-01 06:07:29.006
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:29.006
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51988. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:29.021
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:07:29.461 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:07:29.461
DTC Client socket (1) | Closed. | 2020-06-01 06:07:29.461
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:07:31.019
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51988 | 2020-06-01 06:07:31.019
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:31.019
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:31.019
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:07:33.051 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:33.051
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:33.051
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:33.051
DTC Client socket (1) | Closed. | 2020-06-01 06:07:33.051
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:07:33.066
Rithmic Trading | Disconnected. | 2020-06-01 06:07:33.066
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:33.067
Rithmic Trading | Port for executable: 51991 | 2020-06-01 06:07:35.071
Listening socket (1512). Port 51991 | Closed. | 2020-06-01 06:07:35.071
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:35.074
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51991. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:35.093
Rithmic Trading | Bridge process is running. | 2020-06-01 06:07:37.082
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51991 | 2020-06-01 06:07:37.082
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:37.082
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:37.082
Rithmic Trading | Connected to server. | 2020-06-01 06:07:37.083
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:07:37.083
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:07:37.083
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:07:37.084
Rithmic Trading | Sending logon request message. | 2020-06-01 06:07:37.084
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:07:37.084
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:07:37.086
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:07:37.086
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:07:37.445
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:07:37.623
Rithmic Trading | Received logon response. | 2020-06-01 06:07:37.623
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:07:37.623
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:07:37.623
Rithmic Trading | Logon error received from server | 2020-06-01 06:07:37.623
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:37.623
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:37.623
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:37.630
Rithmic Trading | Disconnected. | 2020-06-01 06:07:37.630
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:37.630
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:07:37.630
Rithmic Trading | Port for executable: 52007 | 2020-06-01 06:07:39.620
Listening socket (1528). Port 52007 | Closed. | 2020-06-01 06:07:39.620
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:39.622
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52007. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:39.639
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:07:40.136
DTC Client socket (1) | Closed. | 2020-06-01 06:07:40.136
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:07:41.631
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52007 | 2020-06-01 06:07:41.631
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:41.631
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:41.631
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:07:43.662 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:43.663
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:43.663
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:43.663
DTC Client socket (1) | Closed. | 2020-06-01 06:07:43.663
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:07:43.678
Rithmic Trading | Disconnected. | 2020-06-01 06:07:43.678
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:43.678
Rithmic Trading | Port for executable: 52009 | 2020-06-01 06:07:45.683
Listening socket (1448). Port 52009 | Closed. | 2020-06-01 06:07:45.683
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:45.685
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52009. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:45.701
Rithmic Trading | Bridge process is running. | 2020-06-01 06:07:47.694
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52009 | 2020-06-01 06:07:47.694
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:47.694
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:47.695
Rithmic Trading | Connected to server. | 2020-06-01 06:07:47.697
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:07:47.697
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:07:47.698
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:07:47.699
Rithmic Trading | Sending logon request message. | 2020-06-01 06:07:47.699
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:07:47.702
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:07:47.704
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:07:47.704
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:07:48.044
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:07:48.231
Rithmic Trading | Received logon response. | 2020-06-01 06:07:48.231
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:07:48.231
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:07:48.231
Rithmic Trading | Logon error received from server | 2020-06-01 06:07:48.231
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:48.231
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:48.231
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:48.241
Rithmic Trading | Disconnected. | 2020-06-01 06:07:48.241
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:48.241
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:07:48.241
Rithmic Trading | Port for executable: 52024 | 2020-06-01 06:07:50.246
Listening socket (1524). Port 52024 | Closed. | 2020-06-01 06:07:50.246
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:50.249
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52024. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:50.265
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:07:50.759
DTC Client socket (1) | Closed. | 2020-06-01 06:07:50.759
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:07:52.257
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52024 | 2020-06-01 06:07:52.257
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:52.258
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:52.258
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:07:54.305 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:54.306
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:54.306
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:54.306
DTC Client socket (1) | Closed. | 2020-06-01 06:07:54.306
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:07:54.321
Rithmic Trading | Disconnected. | 2020-06-01 06:07:54.321
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:54.321
Rithmic Trading | Port for executable: 52026 | 2020-06-01 06:07:56.335
Listening socket (1528). Port 52026 | Closed. | 2020-06-01 06:07:56.335
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:07:56.338
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52026. Current folder: C:\SierraChart\Rim | 2020-06-01 06:07:56.354
Rithmic Trading | Bridge process is running. | 2020-06-01 06:07:58.347
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52026 | 2020-06-01 06:07:58.347
DTC Client socket (1) | Creating socket. | 2020-06-01 06:07:58.347
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:07:58.347
Rithmic Trading | Connected to server. | 2020-06-01 06:07:58.354
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:07:58.354
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:07:58.354
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:07:58.354
Rithmic Trading | Sending logon request message. | 2020-06-01 06:07:58.354
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:07:58.355
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:07:58.356
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:07:58.356
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:07:58.745
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:07:58.918
Rithmic Trading | Received logon response. | 2020-06-01 06:07:58.919
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:07:58.919
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:07:58.919
Rithmic Trading | Logon error received from server | 2020-06-01 06:07:58.919
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:07:58.919
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:58.919
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:07:58.925
Rithmic Trading | Disconnected. | 2020-06-01 06:07:58.925
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:07:58.925
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:07:58.925
Rithmic Trading | Port for executable: 52043 | 2020-06-01 06:08:00.929
Listening socket (1448). Port 52043 | Closed. | 2020-06-01 06:08:00.929
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:08:00.932
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52043. Current folder: C:\SierraChart\Rim | 2020-06-01 06:08:00.970
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:08:01.411
DTC Client socket (1) | Closed. | 2020-06-01 06:08:01.411
Rithmic Trading | Bridge process is not running! | 2020-06-01 06:08:02.943
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52043 | 2020-06-01 06:08:02.943
DTC Client socket (1) | Creating socket. | 2020-06-01 06:08:02.943
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:08:02.943
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-06-01 06:08:04.969 *
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:08:04.970
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:08:04.970
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:08:04.970
DTC Client socket (1) | Closed. | 2020-06-01 06:08:04.970
DTC Client socket (0) | CloseSocket call. | 2020-06-01 06:08:04.985
Rithmic Trading | Disconnected. | 2020-06-01 06:08:04.985
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:08:04.985
Rithmic Trading | Port for executable: 52136 | 2020-06-01 06:10:04.981
Listening socket (1576). Port 52136 | Closed. | 2020-06-01 06:10:04.981
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:10:04.983
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52136. Current folder: C:\SierraChart\Rim | 2020-06-01 06:10:05.004
Rithmic Trading | Bridge process is running. | 2020-06-01 06:10:06.994
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52136 | 2020-06-01 06:10:06.994
DTC Client socket (1) | Creating socket. | 2020-06-01 06:10:06.995
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:10:06.995
Rithmic Trading | Connected to server. | 2020-06-01 06:10:06.997
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:10:06.997
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:10:06.997
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:10:07.000
Rithmic Trading | Sending logon request message. | 2020-06-01 06:10:07.000
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:10:07.002
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:10:07.005
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:10:07.005
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:10:07.376
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:10:07.547
Rithmic Trading | Received logon response. | 2020-06-01 06:10:07.547
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:10:07.548
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:10:07.548
Rithmic Trading | Logon error received from server | 2020-06-01 06:10:07.548
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:10:07.548
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:10:07.548
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:10:07.578
Rithmic Trading | Disconnected. | 2020-06-01 06:10:07.578
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:10:07.578
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:10:07.578
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:10:10.063
DTC Client socket (1) | Closed. | 2020-06-01 06:10:10.063
Rithmic Trading | Port for executable: 52166 | 2020-06-01 06:12:07.572
Listening socket (1656). Port 52166 | Closed. | 2020-06-01 06:12:07.572
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:12:07.573
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52166. Current folder: C:\SierraChart\Rim | 2020-06-01 06:12:07.594
Rithmic Trading | Bridge process is running. | 2020-06-01 06:12:09.583
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52166 | 2020-06-01 06:12:09.583
DTC Client socket (1) | Creating socket. | 2020-06-01 06:12:09.583
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:12:09.583
Rithmic Trading | Connected to server. | 2020-06-01 06:12:09.586
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:12:09.586
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:12:09.586
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:12:09.588
Rithmic Trading | Sending logon request message. | 2020-06-01 06:12:09.588
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:12:09.591
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:12:09.593
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:12:09.593
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:12:09.971
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:12:10.146
Rithmic Trading | Received logon response. | 2020-06-01 06:12:10.147
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:12:10.147
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:12:10.147
Rithmic Trading | Logon error received from server | 2020-06-01 06:12:10.147
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:12:10.147
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:12:10.147
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:12:10.161
Rithmic Trading | Disconnected. | 2020-06-01 06:12:10.161
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:12:10.162
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:12:10.162
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:12:12.651 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:12:12.651
DTC Client socket (1) | Closed. | 2020-06-01 06:12:12.651
Rithmic Trading | Port for executable: 52230 | 2020-06-01 06:14:10.157
Listening socket (1652). Port 52230 | Closed. | 2020-06-01 06:14:10.157
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:14:10.158
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52230. Current folder: C:\SierraChart\Rim | 2020-06-01 06:14:10.175
Rithmic Trading | Bridge process is running. | 2020-06-01 06:14:12.171
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52230 | 2020-06-01 06:14:12.171
DTC Client socket (1) | Creating socket. | 2020-06-01 06:14:12.171
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:14:12.171
Rithmic Trading | Connected to server. | 2020-06-01 06:14:12.174
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:14:12.174
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:14:12.174
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:14:12.176
Rithmic Trading | Sending logon request message. | 2020-06-01 06:14:12.176
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:14:12.178
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:14:12.181
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:14:12.181
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:14:12.561
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:14:12.733
Rithmic Trading | Received logon response. | 2020-06-01 06:14:12.733
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:14:12.733
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:14:12.733
Rithmic Trading | Logon error received from server | 2020-06-01 06:14:12.733
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:14:12.733
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:14:12.733
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:14:12.736
Rithmic Trading | Disconnected. | 2020-06-01 06:14:12.736
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:14:12.736
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:14:12.736
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:14:15.240
DTC Client socket (1) | Closed. | 2020-06-01 06:14:15.240
Rithmic Trading | Port for executable: 52316 | 2020-06-01 06:16:12.738
Listening socket (1532). Port 52316 | Closed. | 2020-06-01 06:16:12.738
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:16:12.739
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52316. Current folder: C:\SierraChart\Rim | 2020-06-01 06:16:12.761
Rithmic Trading | Bridge process is running. | 2020-06-01 06:16:14.749
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52316 | 2020-06-01 06:16:14.749
DTC Client socket (1) | Creating socket. | 2020-06-01 06:16:14.749
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:16:14.750
Rithmic Trading | Connected to server. | 2020-06-01 06:16:14.753
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:16:14.753
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:16:14.753
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:16:14.754
Rithmic Trading | Sending logon request message. | 2020-06-01 06:16:14.754
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:16:14.757
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:16:14.759
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:16:14.759
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:16:15.126
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:16:15.315
Rithmic Trading | Received logon response. | 2020-06-01 06:16:15.315
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:16:15.315
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:16:15.315
Rithmic Trading | Logon error received from server | 2020-06-01 06:16:15.315
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:16:15.315
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:16:15.315
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:16:15.327
Rithmic Trading | Disconnected. | 2020-06-01 06:16:15.328
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:16:15.328
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:16:15.328
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:16:17.814
DTC Client socket (1) | Closed. | 2020-06-01 06:16:17.814
Rithmic Trading | Port for executable: 52343 | 2020-06-01 06:18:15.329
Listening socket (1552). Port 52343 | Closed. | 2020-06-01 06:18:15.329
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:18:15.331
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52343. Current folder: C:\SierraChart\Rim | 2020-06-01 06:18:15.347
Rithmic Trading | Bridge process is running. | 2020-06-01 06:18:17.340
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52343 | 2020-06-01 06:18:17.340
DTC Client socket (1) | Creating socket. | 2020-06-01 06:18:17.340
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:18:17.341
Rithmic Trading | Connected to server. | 2020-06-01 06:18:17.344
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:18:17.344
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:18:17.344
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:18:17.345
Rithmic Trading | Sending logon request message. | 2020-06-01 06:18:17.345
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:18:17.348
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:18:17.350
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:18:17.350
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:18:17.743
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:18:17.914
Rithmic Trading | Received logon response. | 2020-06-01 06:18:17.914
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:18:17.914
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:18:17.914
Rithmic Trading | Logon error received from server | 2020-06-01 06:18:17.914
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:18:17.914
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:18:17.914
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:18:17.919
Rithmic Trading | Disconnected. | 2020-06-01 06:18:17.919
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:18:17.919
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:18:17.919
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:18:20.409
DTC Client socket (1) | Closed. | 2020-06-01 06:18:20.409
Rithmic Trading | Port for executable: 52371 | 2020-06-01 06:20:17.919
Listening socket (1780). Port 52371 | Closed. | 2020-06-01 06:20:17.919
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:20:17.920
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52371. Current folder: C:\SierraChart\Rim | 2020-06-01 06:20:17.941
Rithmic Trading | Bridge process is running. | 2020-06-01 06:20:19.930
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52371 | 2020-06-01 06:20:19.930
DTC Client socket (1) | Creating socket. | 2020-06-01 06:20:19.931
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:20:19.931
Rithmic Trading | Connected to server. | 2020-06-01 06:20:19.934
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:20:19.934
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:20:19.934
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:20:19.935
Rithmic Trading | Sending logon request message. | 2020-06-01 06:20:19.935
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:20:19.938
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:20:19.940
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:20:19.940
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:20:20.283
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:20:20.453
Rithmic Trading | Received logon response. | 2020-06-01 06:20:20.453
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:20:20.453
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:20:20.453
Rithmic Trading | Logon error received from server | 2020-06-01 06:20:20.453
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:20:20.453
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:20:20.453
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:20:20.462
Rithmic Trading | Disconnected. | 2020-06-01 06:20:20.462
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:20:20.462
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:20:20.462
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:20:22.987
DTC Client socket (1) | Closed. | 2020-06-01 06:20:22.987
Rithmic Trading | Port for executable: 52398 | 2020-06-01 06:22:20.465
Listening socket (1376). Port 52398 | Closed. | 2020-06-01 06:22:20.465
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:22:20.466
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52398. Current folder: C:\SierraChart\Rim | 2020-06-01 06:22:20.487
Rithmic Trading | Bridge process is running. | 2020-06-01 06:22:22.476
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52398 | 2020-06-01 06:22:22.476
DTC Client socket (1) | Creating socket. | 2020-06-01 06:22:22.476
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:22:22.476
Rithmic Trading | Connected to server. | 2020-06-01 06:22:22.479
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:22:22.479
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:22:22.479
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:22:22.481
Rithmic Trading | Sending logon request message. | 2020-06-01 06:22:22.481
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:22:22.483
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:22:22.485
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:22:22.486
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:22:22.866
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:22:23.041
Rithmic Trading | Received logon response. | 2020-06-01 06:22:23.041
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:22:23.041
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:22:23.041
Rithmic Trading | Logon error received from server | 2020-06-01 06:22:23.041
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:22:23.041
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:22:23.041
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:22:23.054
Rithmic Trading | Disconnected. | 2020-06-01 06:22:23.054
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:22:23.054
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:22:23.054
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:22:25.541 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:22:25.541
DTC Client socket (1) | Closed. | 2020-06-01 06:22:25.541
Rithmic Trading | Port for executable: 52495 | 2020-06-01 06:24:23.057
Listening socket (1376). Port 52495 | Closed. | 2020-06-01 06:24:23.057
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:24:23.058
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52495. Current folder: C:\SierraChart\Rim | 2020-06-01 06:24:23.079
Rithmic Trading | Bridge process is running. | 2020-06-01 06:24:25.069
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52495 | 2020-06-01 06:24:25.069
DTC Client socket (1) | Creating socket. | 2020-06-01 06:24:25.069
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:24:25.069
Rithmic Trading | Connected to server. | 2020-06-01 06:24:25.072
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:24:25.072
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:24:25.072
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:24:25.074
Rithmic Trading | Sending logon request message. | 2020-06-01 06:24:25.074
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:24:25.076
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:24:25.079
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:24:25.079
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:24:25.507
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:24:25.680
Rithmic Trading | Received logon response. | 2020-06-01 06:24:25.680
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:24:25.680
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:24:25.680
Rithmic Trading | Logon error received from server | 2020-06-01 06:24:25.680
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:24:25.681
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:24:25.681
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:24:25.694
Rithmic Trading | Disconnected. | 2020-06-01 06:24:25.694
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:24:25.694
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:24:25.694
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:24:28.137
DTC Client socket (1) | Closed. | 2020-06-01 06:24:28.138
Rithmic Trading | Port for executable: 52527 | 2020-06-01 06:26:25.705
Listening socket (1648). Port 52527 | Closed. | 2020-06-01 06:26:25.705
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:26:25.706
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52527. Current folder: C:\SierraChart\Rim | 2020-06-01 06:26:25.727
Rithmic Trading | Bridge process is running. | 2020-06-01 06:26:27.715
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52527 | 2020-06-01 06:26:27.715
DTC Client socket (1) | Creating socket. | 2020-06-01 06:26:27.715
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:26:27.715
Rithmic Trading | Connected to server. | 2020-06-01 06:26:27.718
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:26:27.718
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:26:27.719
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:26:27.720
Rithmic Trading | Sending logon request message. | 2020-06-01 06:26:27.720
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:26:27.723
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:26:27.725
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:26:27.725
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:26:28.115
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:26:28.315
Rithmic Trading | Received logon response. | 2020-06-01 06:26:28.315
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:26:28.315
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:26:28.315
Rithmic Trading | Logon error received from server | 2020-06-01 06:26:28.315
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:26:28.315
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:26:28.315
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:26:28.325
Rithmic Trading | Disconnected. | 2020-06-01 06:26:28.325
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:26:28.325
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:26:28.325
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:26:30.782
DTC Client socket (1) | Closed. | 2020-06-01 06:26:30.782
Rithmic Trading | Port for executable: 52559 | 2020-06-01 06:28:28.332
Listening socket (1708). Port 52559 | Closed. | 2020-06-01 06:28:28.332
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:28:28.333
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52559. Current folder: C:\SierraChart\Rim | 2020-06-01 06:28:28.354
Rithmic Trading | Bridge process is running. | 2020-06-01 06:28:30.342
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52559 | 2020-06-01 06:28:30.343
DTC Client socket (1) | Creating socket. | 2020-06-01 06:28:30.343
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:28:30.343
Rithmic Trading | Connected to server. | 2020-06-01 06:28:30.346
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:28:30.346
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:28:30.346
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:28:30.348
Rithmic Trading | Sending logon request message. | 2020-06-01 06:28:30.348
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:28:30.350
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:28:30.352
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:28:30.352
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:28:30.735
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:28:30.914
Rithmic Trading | Received logon response. | 2020-06-01 06:28:30.914
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:28:30.914
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:28:30.914
Rithmic Trading | Logon error received from server | 2020-06-01 06:28:30.914
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:28:30.914
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:28:30.914
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:28:30.921
Rithmic Trading | Disconnected. | 2020-06-01 06:28:30.921
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:28:30.921
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:28:30.921
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:28:33.407
DTC Client socket (1) | Closed. | 2020-06-01 06:28:33.407
Rithmic Trading | Port for executable: 52586 | 2020-06-01 06:30:30.924
Listening socket (2068). Port 52586 | Closed. | 2020-06-01 06:30:30.924
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:30:30.927
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52586. Current folder: C:\SierraChart\Rim | 2020-06-01 06:30:30.949
Rithmic Trading | Bridge process is running. | 2020-06-01 06:30:32.935
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52586 | 2020-06-01 06:30:32.935
DTC Client socket (1) | Creating socket. | 2020-06-01 06:30:32.935
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:30:32.935
Rithmic Trading | Connected to server. | 2020-06-01 06:30:32.938
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:30:32.938
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:30:32.939
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:30:32.940
Rithmic Trading | Sending logon request message. | 2020-06-01 06:30:32.940
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:30:32.943
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:30:32.945
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:30:32.945
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:30:33.304
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:30:33.485
Rithmic Trading | Received logon response. | 2020-06-01 06:30:33.485
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:30:33.485
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:30:33.485
Rithmic Trading | Logon error received from server | 2020-06-01 06:30:33.485
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:30:33.485
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:30:33.485
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:30:33.498
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:30:33.498
Rithmic Trading | Disconnected. | 2020-06-01 06:30:33.498
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:30:33.498
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:30:36.000 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:30:36.000
DTC Client socket (1) | Closed. | 2020-06-01 06:30:36.000
Rithmic Trading | Port for executable: 52613 | 2020-06-01 06:32:33.509
Listening socket (2116). Port 52613 | Closed. | 2020-06-01 06:32:33.509
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:32:33.510
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52613. Current folder: C:\SierraChart\Rim | 2020-06-01 06:32:33.527
Rithmic Trading | Bridge process is running. | 2020-06-01 06:32:35.520
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52613 | 2020-06-01 06:32:35.520
DTC Client socket (1) | Creating socket. | 2020-06-01 06:32:35.521
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:32:35.521
Rithmic Trading | Connected to server. | 2020-06-01 06:32:35.524
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:32:35.524
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:32:35.524
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:32:35.526
Rithmic Trading | Sending logon request message. | 2020-06-01 06:32:35.526
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:32:35.528
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:32:35.530
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:32:35.530
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:32:35.924
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:32:36.090
Rithmic Trading | Received logon response. | 2020-06-01 06:32:36.090
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:32:36.090
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:32:36.090
Rithmic Trading | Logon error received from server | 2020-06-01 06:32:36.090
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:32:36.090
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:32:36.090
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:32:36.100
Rithmic Trading | Disconnected. | 2020-06-01 06:32:36.100
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:32:36.100
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:32:36.100
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:32:38.586
DTC Client socket (1) | Closed. | 2020-06-01 06:32:38.586
Rithmic Trading | Port for executable: 52667 | 2020-06-01 06:34:36.112
Listening socket (1756). Port 52667 | Closed. | 2020-06-01 06:34:36.112
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:34:36.114
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52667. Current folder: C:\SierraChart\Rim | 2020-06-01 06:34:36.129
Rithmic Trading | Bridge process is running. | 2020-06-01 06:34:38.126
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52667 | 2020-06-01 06:34:38.126
DTC Client socket (1) | Creating socket. | 2020-06-01 06:34:38.126
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:34:38.126
Rithmic Trading | Connected to server. | 2020-06-01 06:34:38.127
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:34:38.127
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:34:38.127
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:34:38.128
Rithmic Trading | Sending logon request message. | 2020-06-01 06:34:38.128
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:34:38.129
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:34:38.130
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:34:38.130
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:34:38.500
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:34:38.677
Rithmic Trading | Received logon response. | 2020-06-01 06:34:38.678
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:34:38.678
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:34:38.678
Rithmic Trading | Logon error received from server | 2020-06-01 06:34:38.678
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:34:38.678
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:34:38.678
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:34:38.689
Rithmic Trading | Disconnected. | 2020-06-01 06:34:38.689
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:34:38.689
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:34:38.689
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:34:41.178 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:34:41.178
DTC Client socket (1) | Closed. | 2020-06-01 06:34:41.178
Rithmic Trading | Port for executable: 52696 | 2020-06-01 06:36:38.692
Listening socket (1756). Port 52696 | Closed. | 2020-06-01 06:36:38.692
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:36:38.694
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52696. Current folder: C:\SierraChart\Rim | 2020-06-01 06:36:38.716
Rithmic Trading | Bridge process is running. | 2020-06-01 06:36:40.703
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52696 | 2020-06-01 06:36:40.703
DTC Client socket (1) | Creating socket. | 2020-06-01 06:36:40.703
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:36:40.703
Rithmic Trading | Connected to server. | 2020-06-01 06:36:40.706
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:36:40.706
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:36:40.706
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:36:40.708
Rithmic Trading | Sending logon request message. | 2020-06-01 06:36:40.708
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:36:40.710
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:36:40.713
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:36:40.713
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:36:41.103
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:36:41.275
Rithmic Trading | Received logon response. | 2020-06-01 06:36:41.275
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:36:41.275
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:36:41.275
Rithmic Trading | Logon error received from server | 2020-06-01 06:36:41.275
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:36:41.275
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:36:41.275
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:36:41.281
Rithmic Trading | Disconnected. | 2020-06-01 06:36:41.281
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:36:41.281
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:36:41.281
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:36:43.767 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:36:43.767
DTC Client socket (1) | Closed. | 2020-06-01 06:36:43.767
Rithmic Trading | Port for executable: 52752 | 2020-06-01 06:38:41.279
Listening socket (1072). Port 52752 | Closed. | 2020-06-01 06:38:41.279
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:38:41.280
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52752. Current folder: C:\SierraChart\Rim | 2020-06-01 06:38:41.295
Rithmic Trading | Bridge process is running. | 2020-06-01 06:38:43.293
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52752 | 2020-06-01 06:38:43.293
DTC Client socket (1) | Creating socket. | 2020-06-01 06:38:43.293
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:38:43.293
Rithmic Trading | Connected to server. | 2020-06-01 06:38:43.294
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:38:43.294
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:38:43.294
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:38:43.294
Rithmic Trading | Sending logon request message. | 2020-06-01 06:38:43.294
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:38:43.295
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:38:43.296
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:38:43.296
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:38:43.813
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:38:43.979
Rithmic Trading | Received logon response. | 2020-06-01 06:38:43.979
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:38:43.979
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:38:43.979
Rithmic Trading | Logon error received from server | 2020-06-01 06:38:43.979
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:38:43.979
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:38:43.979
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:38:43.980
Rithmic Trading | Disconnected. | 2020-06-01 06:38:43.980
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:38:43.980
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:38:43.980
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:38:46.330
DTC Client socket (1) | Closed. | 2020-06-01 06:38:46.330
Rithmic Trading | Port for executable: 52806 | 2020-06-01 06:40:43.977
Listening socket (1472). Port 52806 | Closed. | 2020-06-01 06:40:43.977
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:40:43.978
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52806. Current folder: C:\SierraChart\Rim | 2020-06-01 06:40:43.994
Rithmic Trading | Bridge process is running. | 2020-06-01 06:40:45.991
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52806 | 2020-06-01 06:40:45.991
DTC Client socket (1) | Creating socket. | 2020-06-01 06:40:45.991
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:40:45.992
Rithmic Trading | Connected to server. | 2020-06-01 06:40:45.994
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:40:45.994
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:40:45.994
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:40:45.997
Rithmic Trading | Sending logon request message. | 2020-06-01 06:40:45.997
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:40:45.999
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:40:46.001
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:40:46.001
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:40:46.664
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:40:46.837
Rithmic Trading | Received logon response. | 2020-06-01 06:40:46.837
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:40:46.837
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:40:46.837
Rithmic Trading | Logon error received from server | 2020-06-01 06:40:46.837
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:40:46.837
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:40:46.837
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:40:46.851
Rithmic Trading | Disconnected. | 2020-06-01 06:40:46.851
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:40:46.851
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:40:46.851
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:40:49.031 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:40:49.031
DTC Client socket (1) | Closed. | 2020-06-01 06:40:49.031
Rithmic Trading | Port for executable: 52837 | 2020-06-01 06:42:46.854
Listening socket (1764). Port 52837 | Closed. | 2020-06-01 06:42:46.854
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:42:46.857
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52837. Current folder: C:\SierraChart\Rim | 2020-06-01 06:42:46.878
Rithmic Trading | Bridge process is running. | 2020-06-01 06:42:48.866
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52837 | 2020-06-01 06:42:48.866
DTC Client socket (1) | Creating socket. | 2020-06-01 06:42:48.866
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:42:48.866
Rithmic Trading | Connected to server. | 2020-06-01 06:42:48.869
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:42:48.869
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:42:48.869
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:42:48.871
Rithmic Trading | Sending logon request message. | 2020-06-01 06:42:48.871
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:42:48.873
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:42:48.876
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:42:48.876
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:42:49.264
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:42:49.441
Rithmic Trading | Received logon response. | 2020-06-01 06:42:49.441
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:42:49.441
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:42:49.441
Rithmic Trading | Logon error received from server | 2020-06-01 06:42:49.441
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:42:49.441
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:42:49.441
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:42:49.444
Rithmic Trading | Disconnected. | 2020-06-01 06:42:49.445
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:42:49.445
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:42:49.445
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-06-01 06:42:51.918 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:42:51.919
DTC Client socket (1) | Closed. | 2020-06-01 06:42:51.919
Rithmic Trading | Port for executable: 52914 | 2020-06-01 06:44:49.450
Listening socket (2128). Port 52914 | Closed. | 2020-06-01 06:44:49.450
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:44:49.450
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:52914. Current folder: C:\SierraChart\Rim | 2020-06-01 06:44:49.466
Rithmic Trading | Bridge process is running. | 2020-06-01 06:44:51.464
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52914 | 2020-06-01 06:44:51.464
DTC Client socket (1) | Creating socket. | 2020-06-01 06:44:51.465
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:44:51.465
Rithmic Trading | Connected to server. | 2020-06-01 06:44:51.467
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:44:51.467
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:44:51.468
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:44:51.470
Rithmic Trading | Sending logon request message. | 2020-06-01 06:44:51.470
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:44:51.472
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:44:51.475
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:44:51.475
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:44:51.839
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:44:52.020
Rithmic Trading | Received logon response. | 2020-06-01 06:44:52.020
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:44:52.020
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:44:52.020
Rithmic Trading | Logon error received from server | 2020-06-01 06:44:52.020
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:44:52.020
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:44:52.020
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:44:52.038
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:44:52.038
Rithmic Trading | Disconnected. | 2020-06-01 06:44:52.038
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:44:52.038
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:44:54.520
DTC Client socket (1) | Closed. | 2020-06-01 06:44:54.520
Rithmic Trading | Port for executable: 53086 | 2020-06-01 06:46:52.025
Listening socket (2140). Port 53086 | Closed. | 2020-06-01 06:46:52.025
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-01 06:46:52.025
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:53086. Current folder: C:\SierraChart\Rim | 2020-06-01 06:46:52.040
Rithmic Trading | Bridge process is running. | 2020-06-01 06:46:54.047
Rithmic Trading | Connecting to the server 127.0.0.1. Port 53086 | 2020-06-01 06:46:54.047
DTC Client socket (1) | Creating socket. | 2020-06-01 06:46:54.047
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-01 06:46:54.047
Rithmic Trading | Connected to server. | 2020-06-01 06:46:54.048
Rithmic Trading | Starting socket receive thread. | 2020-06-01 06:46:54.048
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-01 06:46:54.048
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-01 06:46:54.049
Rithmic Trading | Sending logon request message. | 2020-06-01 06:46:54.049
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-01 06:46:54.049
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-01 06:46:54.050
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-01 06:46:54.050
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-01 06:46:54.433
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-01 06:46:54.623
Rithmic Trading | Received logon response. | 2020-06-01 06:46:54.623
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-01 06:46:54.623
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-01 06:46:54.623
Rithmic Trading | Logon error received from server | 2020-06-01 06:46:54.623
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-01 06:46:54.623
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:46:54.623
DTC Client socket (1) | CloseSocket call. | 2020-06-01 06:46:54.626
Rithmic Trading | Disconnected. | 2020-06-01 06:46:54.626
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-01 06:46:54.626
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-01 06:46:54.626
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-01 06:46:57.096
DTC Client socket (1) | Closed. | 2020-06-01 06:46:57.096
[2020-06-02 11:23:24]
Refer to:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward
