Date/Time: Fri, 07 Feb 2025 11:17:10 +0000
Do SC support warrant for SEHK in HK via IB?
View Count: 657
[2020-06-01 07:23:43] |
User189399 - Posts: 43 |
I want to trade warrant for the exchange SEHK in HongKong via IB. From the IB symbol format link below, I cannot find the format for WAR (warrant). I simply change IOPT with WAR but it seems not working. If SC support WAR, pls advise the correct symbol format. Interactive Brokers Symbols |
[2020-06-01 18:17:11] |
Yes warrants are supported. Refer to the symbol format here: Interactive Brokers Symbols: Warrants Format You will also need the latest version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-01 18:17:18
