Date/Time: Fri, 07 Feb 2025 09:40:31 +0000
AMP Account not connecting
View Count: 532
[2020-06-01 05:20:24] |
User210127 - Posts: 23 |
Hi Support, AMP account enable to connect today. Can you please help? Thank you v much.
[2020-06-01 05:39:18] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed with File >> Connect to Data Feed. After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-01 05:44:58] |
Dear Support, auto solved with FCM, thank you.
