Date/Time: Fri, 07 Feb 2025 10:14:47 +0000
Cannot connect to Rithmic
View Count: 608
[2020-05-31 22:31:28] |
User158479 - Posts: 5 |
Rithmic Trading | Port for executable: 65062 | 2020-05-31 17:30:32.472 Listening socket (1472). Port 65062 | Closed. | 2020-05-31 17:30:32.472 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-05-31 17:30:32.474 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:65062. Current folder: C:\SierraChart\Rim | 2020-05-31 17:30:32.477 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-05-31 17:30:34.318 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-05-31 17:30:34.318 DTC Client socket (1) | Closed. | 2020-05-31 17:30:34.318 Rithmic Trading | Bridge process is not running! | 2020-05-31 17:30:34.477 Rithmic Trading | Connecting to the server 127.0.0.1. Port 65062 | 2020-05-31 17:30:34.477 DTC Client socket (1) | Creating socket. | 2020-05-31 17:30:34.477 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-05-31 17:30:34.477 |
[2020-05-31 22:33:05] |
Make sure you have downloaded and saved the latest Rithmic TLS certificate files which are here: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-31 22:33:16
[2020-05-31 22:44:01] |
So I downloaded the files into that folder. Restarted Rithmic, connected to R trader no problem, but cannot connect via Sierra. AMP is saying to contact you guys.
[2020-05-31 23:50:26] |
We are not sure about this. Refer to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward | Post: 221116 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
