Date/Time: Fri, 07 Feb 2025 16:53:46 +0000
Replay chart when chart period is Daily
View Count: 669
[2020-05-31 15:28:21] |
User189132 - Posts: 63 |
Hi, When trading I am looking at real time data on daily chart. I am using indicators that change according to daily data. To test my strategies I want to replicate the same in replaying the chart, namely I want to set chart period to daily and "play" the chart. So far I am able to replay the chart only when the period is 30min or so Please see attached my Message Log. Please advise. Date Time Of Last Edit: 2020-05-31 15:38:44
[2020-06-01 16:12:31] |
If you are running back testing on a daily chart, then you need to use the Bar Based Back Testing, as this is the only one that supports daily charts. Refer to the information here: Auto Trade System Back Testing: Bar Based Back Testing Also, Replay mode only works for Intraday charts as well. Refer to this section here: Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 11:31:14] |
I tried again "Also, Replay mode only works for Intraday charts as well. Refer to this section here: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayingHigherTimeframeCharts". It worked. Thank you. |
