Date/Time: Fri, 18 Sep 2026 11:38:45 +0000
[User Discussion] - ohlc bar change colored based on total volume value
View Count: 1389
| [2020-05-31 10:04:44] |
| User156295 - Posts: 105 |
Hello It should be somehow easy but can not find any way to change ohlc bars color depending on the total bar volume value. I thought that Color Bar Based on Alert Condition study would help but this is for alert. I just only would like to have a color change. |
| [2020-05-31 10:25:20] |
| User745789 - Posts: 398 |
You are doing it right, you just need to research the Study a little more. The alert trigger will change the bar color.
| [2020-05-31 11:33:46] |
So firstly I would need to create an alert for volume than link this in some way with Color Bar Based study? Description of this study is a little overhelming for me, I did so many things so far in SC, some with the help of online searches but this one is not so easy.
| [2020-05-31 12:20:42] |
| Sawtooth - Posts: 4354 |
Just create a formula on the Alerts tab of the color bar study that goes TRUE based on your total volume condition.
| [2020-05-31 12:33:24] |
| Ackin - Posts: 1865 |
Collection Examples: Additional Files (Study Collections, Spreadsheets, Chartbooks) Available Main Price Graph Identifiers/Variables Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables And last but not least, there is Tomgilb who has solved several hundred different situations through alerts here on the forum. So if you give yourself your time, you should always find the answer to your question here on the forum. https://www.sierrachart.com/SupportBoard.php?do=Search&Query=Color+Bar+Based+on+Alert+Condition&Submit_Search=Search Date Time Of Last Edit: 2020-05-31 12:34:16
| [2020-05-31 13:10:21] |
So for others searching similar thing: open Color Bar Based study settings, go to Alert Tab, input there: "V>x" where x is your volume value above which you want to highlight your bar.
