Date/Time: Fri, 07 Feb 2025 10:05:33 +0000
Order fills Arrow
View Count: 1378
[2020-05-31 07:03:44]
User235292 - Posts: 10
Hi Guys, how can i make order fills arrows bigger? Thank You
imagearrow.PNG / V - Attached On 2020-05-31 07:01:07 UTC - Size: 6.49 KB - 283 views
[2020-05-31 09:10:43]
This is controlled through the Order Fill Marker Size setting:
Global Trade Settings Windows: Fill Marker Size (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills)
[2020-05-31 12:07:32]
Order Fill Marker Size setting dont work, have try it many times and arrow always small
[2020-05-31 12:10:10]
File attached
imagearrow.PNG / V - Attached On 2020-05-31 12:09:25 UTC - Size: 67.64 KB - 250 views
[2020-05-31 14:02:08]
We want you to update to prerelease 2114 for the updated setting:
Then you will be able to change the setting according to the specified number of pixels.
