Date/Time: Sat, 22 Feb 2025 23:15:44 +0000
show unused (unassigned/inactive) chart link number
View Count: 870
[2020-05-31 04:03:18]
whats1thingnow - Posts: 407
how do i know which chart linking number is NOT used yet?
is there a way to find this?
i'm looking through the cw menu and i have 30+ charts
some of the charts have longer names and hence the "L:" doesn't show in the row because it's pushed too far to the right
@support - please help
[2020-06-09 20:08:20]
@support
please help
any hints?
there must be a way to identify which link number IS NOT USED
every time i link it to something that already has a number, it messes up my other charts
[2021-02-03 00:34:30]
anyone else know how to do this?
i have mostly detached charts and so Color Chart Tabs with Chart Link Number Color (Global Settings >> General Settings >> General 4) (General Settings Window: Color Chart Tabs with Chart Link Number Color (Global Settings >> General Settings >> Charts >> Charts)) doesn't work
so i look at Window >> Windows and Chartbooks:
Window, CB and CW Menus
but it's all listed in a single column and scrolling through each to look for "L:#" is a pain
if only the linked charts are color coded in the 'cw' menu, or 'Windows and Chartbooks'
hummmmmmmmm
[2021-02-03 02:01:01]
user_xyz - Posts: 446
I have linking with the link/color number displayed in the corner of chart header... See attached. This makes it pretty easy to see a color and number for used links.
imageScreenshot 2021-02-02 165923.png / V - Attached On 2021-02-03 02:00:10 UTC - Size: 2.19 KB - 231 views
imageScreenshot 2021-02-02 165946.png / V - Attached On 2021-02-03 02:00:16 UTC - Size: 4.21 KB - 245 views
[2022-10-06 20:57:07]
any chance this can be implemented?
i'm running like 60+ charts on a chartbook
it's a real pain to manually check which link number HAS NOT BEEN USED yet...
unfortunately chart header method won't work because i have many charts hidden as they are for study/overlay only... so right now i have to go through the 'cw' menu to check :(
thank you in advanced
