Date/Time: Fri, 07 Feb 2025 10:06:21 +0000
Historical data will not download for commodities. Example ZCN0
View Count: 531
[2020-05-30 21:46:20]
Dyoung - Posts: 11
I am using the Standard Version of Sierra Charts and support documentation indicates I should have the ability to use the Historical Chart for commodities. The Historical feature works along with my data provider when I am using ES. However, I am trying to open some grain charts (CBOT) and the daily, weekly, etc does not show any bars in the chart. If I try to download intraday times (like a 5 minute chart), the bars show up in the chart. Any suggestions as to why I cannot get the bars to appear for the daily data? Thanks in advance. I am not sure if you are going to charge me for this question.
[2020-05-31 00:28:21]
We are looking into this. This is a server problem.
[2020-05-31 09:02:31]
This is now resolved.
Use this command to update the charts:
Edit Menu: Edit >> Download Data For All Historical Charts
