Date/Time: Fri, 07 Feb 2025 21:32:51 +0000
Daily charts compressed to one candle
View Count: 722
[2020-05-30 14:00:39] |
User144790 - Posts: 2 |
Hello, i am currently doing backtests on daily charts of E-mini NasdaQ 100 but Sierra is not able to properly show me data of any sort. It's just one huge candle with a range of all the days i am trying to load. Have no idea, what i am supposed to do. Colleague has the same setting, pricing of a data provider ... no problems there. In the attached file is the screen of the candle. Thank you very much for reply. |
candle.PNG / V - Attached On 2020-05-30 13:58:54 UTC - Size: 20.19 KB - 213 views |
[2020-06-01 16:26:33] |
Can you tell us what is the method that you used to start this back test? Check the Days to Load setting: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Also refer to: Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-01 16:27:24
[2020-06-15 09:51:25] |
Thank you for your reply. Matter is resolved. Don't know what was the problem but when I tried to load daily charts on NASDAQ it worked on Micro as well. Unfortunately I have another problem being I can't load data from SAP sectors (IXY, IXU...). Chart is completely blank, no data downloaded. Isn't there something I could do? Thanks again. |
[2020-06-17 06:39:48] |
I can't load data from SAP sectors (IXY, IXU...). Tell us the exact symbols you are referring to. We must have exact symbols.
