Date/Time: Wed, 26 Feb 2025 23:15:32 +0000
[Programming Help] - Power/Strength meter (Depth)
View Count: 2626
[2020-05-30 11:31:36]
Andy87 - Posts: 7
Dear All,
May I know does any sierra chart member know how to add Power/Strength meter?
Include 1) traded meter 2)Bid/Offer meter and 3)Stacking/pulling meter.
Please advise,
Thank you
image2.png / V - Attached On 2020-05-30 11:27:39 UTC - Size: 333.18 KB - 725 views
[2020-05-30 11:37:58]
Ackin - Posts: 1865
I only have a Strength meter
Strength Meter
The trader Ticino has another one mentioned by you in his portfolio
[2020-05-30 13:21:31]
Andy87 - Posts: 7
Dear Ackin,
Noted with many thanks.
Thank you.
[2020-05-31 06:47:12]
ticinotrader - Posts: 403
https://youtu.be/roYSSZZRTaw
[2020-05-31 13:07:44]
Andy87 - Posts: 7
Dear Ticinotrader,
You are so genius to play SC those setting like a magic.
I am so shock while you can well think about how to change from chart became meter pattern.
Really awesome!!
The duration of time period (10sec, 60sec and so on) for power meter (traded bid vs traded ask), does it mean every next duration period (10sec, 60sec and so on) start is refreshing data or it is accumulate date?
Can I clear/refresh Power meter when the price reach my level?
Please confirm.
Thank you so much.
[2020-05-31 13:28:55]
The powermeter shows the cumulative executed volume over a specific period and automatically refreshes.
As far as I know there is no possibility to reset it manually.
[2020-06-21 12:22:12]
Ackin - Posts: 1865
it is possible ... but not through this kind of calculation.
[2021-06-08 12:26:45]
User468483 - Posts: 12
Hi ticinotrader,
Thanks a lot for your help.
I have set Power meter and Strenth meter following you step by step, but I have 2 problem.
1) They do not actuaalize and don't move at all.
2) I would like to have meter moves to reflect the change in the combined pulling Stacking column and not the Bid/Ask depht. Is that possible ?
Thierry
Date Time Of Last Edit: 2021-06-08 12:27:52
imagePower Meter.jpg / V - Attached On 2021-06-08 12:27:35 UTC - Size: 565.36 KB - 619 views
