Date/Time: Fri, 07 Feb 2025 10:21:19 +0000
Can't connect to rithmic
View Count: 887
[2020-05-30 01:44:14]
User644082 - Posts: 4
Getting this error message: Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. Note: Rithmic bridge needs installing. To install select 'Help >> Download Current Version'. On the installer enable 'Install Optional Components' | 2020-05-29 21:42:20.774 *
I did the install and restarted still getting the same message.
[2020-05-30 08:29:42]
We have discontinued support for Rithmic. Refer to:
Regarding Rithmic (Our Final Post on this Subject)
But you can access the needed bridge files here:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward
Date Time Of Last Edit: 2020-05-30 11:43:30
