Date/Time: Fri, 07 Feb 2025 10:23:03 +0000
Value area and POC are not hightlighted
View Count: 617
[2020-05-30 01:39:14] |
User644082 - Posts: 4 |
Volume at price study not working. Value area and POC are not hightlighted after both of the setting are set to Yes. I noticed they only show up when I also set the extending option to yes.
[2020-05-30 10:11:14] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image It could be the color settings for those are not correct or the Ticks per Volume Bar Input setting is set too low. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
