Date/Time: Fri, 07 Feb 2025 10:19:56 +0000
Denali data feed only via CQG routing
View Count: 803
[2020-05-30 01:12:50] |
User873130 - Posts: 47 |
I am looking to integrate Denali Data into my CQG routing. Some of the symbols seem to be integrated like MESM20 (i don't know if there are any others) but others like ESM20, CLN20 are currently not working.
[2020-05-30 09:57:16] |
With the Denali Exchange Data Feed you did subscribe to the entire CME group. You need to make sure Sierra Chart is set to use CQG: CQG Trading Platform Service: Setup Instructions And then translate the symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
