Date/Time: Sat, 08 Feb 2025 02:07:02 +0000
Numbers Bars Calculated Values
View Count: 1314
[2020-05-29 22:54:23] |
User123235 - Posts: 46 |
Hi, I see AskT-BidT difference, where is total AskT and total BidT? |
[2020-06-01 16:10:22] |
Those values are not in the Numbers Bars Calculated Values. Rather, you can get them from the following studies: Number of Trades - Ask Number of Trades - Bid It is possible to do these kinds of calculations using other studies. Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-01 16:11:44
[2020-06-10 17:15:13] |
User237090 - Posts: 14 |
Hello SC, I notice you updated the "Overlaying a Numbers Bars Calculated Values Study from Another Chart" instructions today June 10... I wanted to ask whether its possible to keep the original "source" chart periodicity when overlaying the numbers bars calculated values from same? I've been able to accomplish the overlay with no problems.. but I'd very much like to retain the longer time frame information as its being updated at the source on my faster "trade" chart.. What is happening now is that as soon as the "numbers bars calculated values" or "numbers bars calculated values 2" are added and pointed towards the "source" chart for inputs and applied the "source" chart periodicity is changing to the destination chart settings... Could I also ask how to "call" the pullback column values from the Numbers Bars Calculated Values table (in an alert)? There doesn't appear to be an "SG" # for that column.. best regards, Date Time Of Last Edit: 2020-06-11 19:30:10
[2020-06-24 04:09:25] |
We did not update that particular section. The tag at the bottom of each page is when that page was last updated, not just the section. In this case, we updated some information on how Numbers Bars Calculated Values are displayed. To directly answer your question though, the answer is No, you cannot use the overlay option for the Numbers Bars Calculated Values for different timeframes. But, you can use Text Display for Study from Chart to view the data from the last bar in your higher timeframe chart on the lower timeframe chart. Refer to the information here: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-24 04:14:27] |
The pullback data is simply referenced by using a positive offset with the Subgraph: [1]. Refer to: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-24 04:14:43
