Date/Time: Fri, 07 Feb 2025 09:52:07 +0000
How to Decrease Size of Volume Profile on Chart?
View Count: 1613
[2020-05-29 18:44:01] |
User344276 - Posts: 68 |
How do I decrease the size of the volume profile on a chart? It's getting in the way of the price bars and I just want it to stay on the right hand of the chart. Thank you.
[2020-05-30 02:48:12] |
Refer to the information in this section of the documentation. Make sure you look through the entire section, as there is a Sub-Section on creating space on the right side of the chart. Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
