Date/Time: Fri, 07 Feb 2025 10:06:13 +0000
How to change datafeed of chartbook
View Count: 534
[2020-05-29 14:57:38]
User452630 - Posts: 12
I have a chartbook which I use with BTC / Bitmex data. I want to apply the same chartbook settings to different markets. I am thinking the only thing changing is the data - ie. es futures, XAU, ZB , SPX and so on. How do I do this? I can duplicate the chartbooks but just need to change the data.
[2020-05-29 19:44:04]
You need to make a copy of the Chartbook by opening it and then using Save As:
File Menu: Save As (File)
And then change the symbol of the charts as required in that Chartbook copy. Refer to:
Changing the Symbol of a Chart
