Date/Time: Fri, 07 Feb 2025 10:10:27 +0000
c++ version
View Count: 688
[2020-05-29 12:59:47] |
User62448 - Posts: 13 |
Hello! Can somebody pls tell me, which c++ version does Sierra Chart custom studie use? For example, c++17. Thanks! |
[2020-05-29 13:16:52] |
You can use any C++ version that you want. It does not matter. And these versions really only apply to the particular language features being used.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-29 13:17:22
[2020-05-29 16:07:04] |
thanks four your answer!
