Date/Time: Fri, 07 Feb 2025 10:20:08 +0000
SC Web Order Entry - what fields should populate?
View Count: 530
[2020-05-29 10:32:18] |
ochocinco - Posts: 29 |
Hi and happy Friday! I'm not sure if what I'm seeing is as expected for the current state of functionality or not. (screenshot attached) On the Trade Account Data and Order Entry page I've selected: Server: Live SC Order Routing - Server1 (Chicago) symbol: MNQM20 Refresh Quote button has been clicked. Is the "Instrument Price" supposed to show a quote other than "0.0"? Is the "Required Margin" supposed to populate (my acct is at Advantage Futures)? thank you |
Attachment Deleted. SC Web Order Entry.png / V - Attached On 2020-05-29 10:31:29 UTC - Size: 133.11 KB - 197 views |
[2020-05-29 10:33:53] |
The margin fields are not supported and the price field is not currently supported. So there is no market data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
