Date/Time: Fri, 07 Feb 2025 09:41:40 +0000
Reducing trail offset
View Count: 673
[2020-05-29 06:28:33] |
User745789 - Posts: 358 |
For a triggered trailing stop loss, is there anyway to reduce the trail offset when a second trigger offset is hit? eg Step 1: at Trigger Offset = 15, Trail Offset = 7 Step 2: at Trigger Offset = 25, Trail Offset = 3 If I understand, this is not possible? The closest I can work is multiple OCO groups with the two separate triggered trailing stops applied to separate quantities of the same position. |
