Date/Time: Fri, 07 Feb 2025 10:12:19 +0000
cqg data from NT* to sim
View Count: 677
[2020-05-29 05:39:47]
lagjan - Posts: 5
CQG
Hello i would like to login to a CQG data connection. Not my live trading account. The problem is NT8 broker give me only one conncetion. If NT8 is closed i would like to open sierra en make connection to a sim account and check it out. later in time i wil pay for a second login. How to make conncetion to a sim trading account whit the whit the usename and password i already have for this one conccection. Now i get the massegge trading is not enabled to sierra. But i only would like to check data on a sim account ? and not login to the live trading account
[2020-05-29 06:15:19]
We are not sure about this. We can only refer you to the documentation here to use a CQG live account:
CQG Trading Platform Service: Setup Instructions
Simulated accounts are not supported:
CQG Trading Platform Service: CQG Demo Accounts Not Supported
Date Time Of Last Edit: 2020-05-29 06:15:30
[2020-05-29 07:28:12]
lagjan - Posts: 5
Thanks for the fast respons
If simulated account are not supported it wil not work. if i take Denali data wil it work on a sim account? wil it deliver me the data login details in a few hours.
The big problem is i would like to run data in sierra, not for a live account,,,just the cme bundel. What do you think would fit the best and get it set up in w few hours.
Thansk for the support sir
[2020-05-29 11:02:35]
The best thing to do for now is to use the delayed data feed:
Delayed Exchange Data Feed
And then for real-time data, we recommend that you follow this solution to authorize the real-time CME data when using the Denali data feed:
Easy Solution to CME Funded Trading Account Requirement
[2020-05-29 13:58:50]
JohnR - User831573 - Posts: 309
Another possibility is to sign up with a different broker for a trial. When you do this, you will also get a trial of data access. Amp Futures is one, but there are many.
JohnR
