Date/Time: Fri, 07 Feb 2025 12:20:25 +0000
TPO Charts -Exclude Evening Session Profile Except For Last Day NOT working
View Count: 1405
[2020-05-29 03:34:25]
Meklon - Posts: 223
Support,
I have a TPO chart configured to "Exclude Evening Session Profile Except For Last Day". It consistently leaving the prior days evening profile in place when session migrates to next day. If I "Reload and Recalculate" the chart using Insert key the chart looks correct and only the last night evening profile is displayed (or a current day evening profile if we are on the ETH). However, after the close of the next day RTH the prior day still remains. Same happens going forward keeping the trail of ETH profiles behind.
Shouldn't this automatically remove the last night ETH profile and only display the current one?
See attached slides.
imageSlide-2png.png / V - Attached On 2020-05-29 03:29:25 UTC - Size: 67.69 KB - 274 views
imageSlide-1png.png / V - Attached On 2020-05-29 03:29:41 UTC - Size: 20.15 KB - 254 views
[2020-06-02 15:40:26]
Meklon - Posts: 223
Support, are there any plans to answer this ticket or will this go down as another ignored topic?
[2020-06-02 19:42:51]
The documentation does explain the behavior that you see:
Time Price Opportunity (TPO) Profile Charts: Exclude Evening Session Profiles Except For Last Day
You just need to do a recalculate to clear out the prior evening session profiles.
[2020-06-02 20:29:11]
Meklon - Posts: 223
I understand that. But what is the reason of having this feature "Exclude Evening Session Profile Except For Last Day" if it needs to be recalculated manually every day?
This makes NO sense.
[2020-06-03 04:05:36]
Well it certainly does what it is supposed to do. But there is no automatic removal of a prior profile because that does require a full recalculation, we do not want to abruptly do something like that. It has to be user initiated.
Date Time Of Last Edit: 2020-06-03 04:05:59
