Date/Time: Mon, 25 Nov 2024 07:45:08 +0000
Back testing the cross overs of two simple moving averages for loss and gain
View Count: 1092
[2014-01-23 05:09:32] |
User35749 - Posts: 32 |
Dear Sir or Madam: Per your instruction in posts 8323, I read and follow "AUTO TRADE SYSTEM BACK TESTING" document to simulate a back test for cross overs of two simple moving avarages (SMA15 cross above SMA50= long and then exit and then short when SMA15 cross below SMA50) for profit and loss; however, it does not work. Would you please tell me if I do some thing wrong here? Thanks, Van |
[2014-01-23 23:41:38] |
There is not enough information here to help with. It does not tell us much to say that it "does not work" when there is a whole procedure to create a trading system and back test it. How do we know where you have gone wrong? Are you using the Spreadsheet System for Trading study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
