Date/Time: Fri, 07 Feb 2025 09:44:47 +0000
ZigZag Study to Plot at Pivots?
View Count: 741
[2020-05-28 21:20:16] |
User628616 - Posts: 132 |
I want this zigzag study to plot basically at pivots, in the included pic is two images. the top is original version indicator plots and the bottom is the way i want indicator to plot(yellow lines at pivots[ignore purple line]) The current settings on indicator are the default, what needs to be changed to have it my way? |
[2020-05-29 19:36:03] |
This is just a matter of changing the Inputs for the Reversal %/Value and Number of Bars Required for Reversal in the study to get what you want. Refer to the Inputs starting here: Zig Zag: Reversal % for Calculation Mode 1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
