Date/Time: Mon, 25 Nov 2024 07:42:39 +0000
Cumulative Delta Study
View Count: 1592
[2014-01-23 04:20:04]
Profile Trader - Posts: 174
I would like to apply 2 cumulative delta studies on one chart (subgraph 2 and 3) I would like to have one with a filter on it by the number of contracts and one without. Since you can not make that change in the study I have done it with the chart settings on the underlining data set in subgraph 1. is there a way to add an additional data set to the chart that is hidden and apply it to one of the cumulative delta studies?
Thanks,
Doug
[2014-01-23 07:30:13]
What you need to do is set up another chart and apply the Cumulative Delta Study to that chart and then overlay it on the other chart using the Study/Price Overlay study:
http://www.sierrachart.com/index.php?l=doc/helpdetails28.html
Date Time Of Last Edit: 2014-01-25 02:42:51
[2014-01-25 02:23:03]
Thank you for that insight it worked out great.
One more question. If I was too put this on 5 min chart and I wanted to zero out the delta on each 5 min bar is that possible. I see where you can reset at the start of each day. Or is there a different way of coming up with a cumulative delta per time period?
Thanks,
Doug
[2014-01-25 02:43:53]
We gave you the wrong link in the prior post. It was supposed to be help topic 28. Not the one we gave.
Sounds like what you are interested in is the Ask Volume Bid Volume Difference Bars study.
