Date/Time: Fri, 07 Feb 2025 07:48:06 +0000
TC1 by default configuration question
View Count: 1053
[2020-05-28 16:32:28] |
User873130 - Posts: 47 |
Hi When I create a drawing, it is using TC2 by default. Where do I change the setting so that every time I make a drawing, it uses TC1? thanks |
[2020-05-28 19:33:53] |
Whatever is the last selected Tool Configuration is the one that gets used going forward. So next time when you select a Drawing Tool, before drawing go to Tools >> Current Tool Config >> Config 1. From that point forward Config 1 will be the default. Refer to the third paragraph here: Chart Drawing Tools: Using Multiple Drawing Tool Configurations Also, if you want to ensure you get a specific Tool Configuration, then refer to the following for how to do this: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
