Date/Time: Fri, 07 Feb 2025 08:04:22 +0000
Line angle
View Count: 813
[2020-05-28 15:34:05] |
User459170 - Posts: 262 |
The angle of line set at 45 draws something like a 15 degree angle, have you noticed that?
[2020-05-28 21:01:29] |
Refer to the information here: Chart Drawing Tools: Viewing Angle in Degrees, Related Settings, Understanding Angled Lines on Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
